Question about Myron & Davis Myron Davis 6.0 " TFT/LCD Headrest Mount Monitor
My headrest is damaged thanks to someone fixing something on my car they clipped some wired and I think the screen is shot.Is there a site were i can buy a replacement moniter to put in myself
  • johnwaynezob May 21, 2008
    I have just purchased a 02 Ford Explorer with Myron & Davis 6 in headrest system installed. One monitor works and one monitor will not power on. the dvd player has been changed to a audiovox. It works but there are no earphones to hookup to the system. Were can I get a manual for the 2002 model 6 inch system, where can I get a replacement monitor and replace it myself, and where can I get the original dvd player with earphones cheap. thanks, John Guetterman, email to gboys1000@yahoo.com
Tip
Bothersome Headrest Fix
I just got a 2008 Cobalt and I didn't like the way the headrest tilted my head forward. I found that I could remove the headrest and turn it around. It is much more comfortable that way.
The first step is to lift the headrest to the highest height.
Then insert a paper clip in the little hole on the side of the headrest slide. (You may have to press the realease ad lift on the other side first)
The headrest will then lift out completely.
Flip it around and put it back in.
You will need the paper clip to adjust the height, but this seems like a one time adjustment.
on Jun 20, 2008 | 2008 Chevrolet Cobalt
Where can I find a hummer h3 original headrest control box? I have a headrest DVD player and my box got damage by water. If anyone know or have one for sale please let me know........
que ce que ca veut dire
Where can I find a hummer h3 original headrest control box? I have a headrest DVD player and my box got damage by water. If anyone know or have one for sale please let me know..... rodneyzayas@yahoo.com Thanks
Aug 16, 2013 | Car Audio & Video
How do you remove the headrest from a 2005 Dodge Neon? I have tried pressing the clip on the side of the headrest retainer but the headrest extends about 5 inches and will not pull out.
there is a round plastic thing with tabs sticking out if you turn it counter clockwise you can pull it backwards over the wire and then pull the bulb out
Mar 26, 2011 | 2005 Dodge Neon
I need to remove my headrest to change my seatbelt guide ; i can t get headrest to come off. Thank you
Pull the seat fabric down in front to expose the plastic piece that the headrest bar inserts through. You will see a small wire clip inserted through plastic. Remove it by prying with small flat head screwdriver. Repeat on other side. Headrest will then slide out.
Jul 02, 2010 | 1997 Chevrolet Cavalier
How do you remove the headrest on a 1998 daewoo
hi normally you can do this by...pulling the headrest top its maximum height , at the bottom you should see two black plastic rings, on either side of these rings are little partitions push these inward and pull the headrest at the same it can be a bit awkward but if you do one side at a time or get someone to pull the headrest while you push the clips in can be very helpfull...hope this helps please vote thanks
May 11, 2010 | 1999 Daewoo Lanos
How do i remove headrests VW conv
Raise up the headrest, you'll see 2 plastic round parts the rods for the headrest go in. There is a hairpin type clip that goes thru the plastic round parts. Pull that clip out of each, the headrest will come right out.
Nov 01, 2009 | 1990 Volkswagen Cabriolet
How do you remove the front headrest for a 2009 bmw 335i
You can't remove the front headrests from 2009 or later BMW's without first disconnecting internal wiring that runs inside 1 of the posts for each headrest to the inside the seat. This wiring is part of the Active Restraint Safety System that was new for 2009.
If you force it and break the wire you will at a minimum need to spend about $300 at the dealer to resplice the wire by taking the back off the seat.
Sep 02, 2009 | 2009 BMW 3 Series
Front Headrests
There is a plastic cover, about 1 1/8" diameter, on the base of the post on each side. You can remove it with a screw driver by carefully prising upwards at the edge. They just clip down.
Once these are lifted away from the seat, you will see the wire clip that locks the headrest into the seat. Remove the clip on each post, and you can then remove the headrest.
Reassembly is the reverse.
Feb 12, 2009 | 1992 Audi 80
2002 pt cuiser does the headrest come off i have new seat covers.
small hole in headrest base use small pin punch (or very stiff wire) press in hole and pull headrest up
Jan 07, 2009 | 2001 Chrysler PT Cruiser
Myron & Davis Myron Davis 6.0 " TFT/LCD Headrest Mount Monitor Logo
47 people viewed this question
Top Myron & Davis Car Audio & Video Experts
xxxxxx xxx
Tom Chichester
Joe Ball
Joe Ball
Are you a Myron & Davis Car Audio and Video Expert? Answer questions, earn points and help others
