Question about Insignia 37" LCD Flat-Panel HDTV
The source list box appears every 2 minutes while
Hi I have an Insignia and the source list box pops up on its own while watching anythihg or while the tv is on. How to stop the source list box appearing every 2 minutes while the tv in on? It is very annoying to watch tv r a movie when this box keeps popping up on its on. Is there a solution to fix this problem? I have tried to disconnect the tv from the power source and it still happens.
  • 8 Answers
SOURCE: Channels change by themselves after 20-30 minutes of tv being on
Have you tried covering the IR eye on the front of the TV when this starts occuring? Sometimes other devices in your home can emit infrared light that in rare cases can be picked up by your TV as a command from the remote. If covering the eye seems to stop the problem, I would say my guess is correct. If the problem continues even with the IR eye blocked I would say that the internal tuner of the TV might be defective. good luck!
Posted on Jun 17, 2008
  • 8 Answers
SOURCE: BLACK BOX PROBLEMS: Insignia TV/DVD combo
The black box is caused by the Closed Caption option of the tv. Go into the menu and turn it off.
Posted on Aug 21, 2008
  • 814 Answers
SOURCE: I have a 37 inch Insignia flat screen tv. This
This unit needs to be tested in a service center because it has problems with the operation of the video card. This could be caused by a loss of voltage supplying the video card from the power supply card. Or a failure on the video card itself. You can purchase parts for unit from Best Buy Parts at !-888-237-8289 and get customer service at 1-877-467-8289. You should get an estimate from the service center, That should tell you which parts are bad and then you can proceed from there. If the prices seem too high for parts and labor from the service center, try buying the parts yourself and have them install them for you. You should try to check the prices on the parts , just to make sure you are getting a fair deal.You can do this by getting the part numbers, you should ask the service center to provide the part numbers needed if they need to replace the power supply board or video board and with your model number of television check out the prices and availability at the Best Buy Parts website.Of course if the television is still under warranty send it in for warranty service. Hope this helps you with your problem.
Posted on May 13, 2009
ipodslinger
  • 688 Answers
SOURCE: cant play my xbox 360 on my 22 inch Insignia tv
Is the TV an High Definition TV?
If it's not an HDMI compatible tv them you will need a regular audio video cable for your XBOX 360
you cn get them all day on ebay or at any store.
Posted on May 25, 2009
rhozel2010
  • 269 Answers
SOURCE: no picture, no sound, have power
you have defective flyback
Posted on Aug 04, 2009
Insignia Ns-15MS0832 How do I in large the TV picture when using HDMI
Hi, On your remote select menu in the list should be something called (aspect ratio) 4:3 , Zoom, Full , 16:9 etc.. These settings should make the screen larger or smaller. Also in the list should be something called HDMI for source connections (DVD, Cable box, Dish) etc. You should be using HDMI cables for these for better quality signal. Good luck.
Jun 06, 2015 | Insignia Televison & Video
My input source screen keeps popping up and scrolling through the options - once I select source (example TV) the TV will come on then the input source comes back on and keeps scrolling on its own
My new 4K Vizio 60" M60-C3 started scrolling through input channels on it's own and after a minute would stop and "land" on an input, then I would have to change it to the correct one. Then the volume started "racing" to 100 making it impossible to watch. Vizio repairman came and replaced a small board about 1.5 in. x 5 in. and it is back working again. It fell within the 1 year warranty, so no charge, and he suggested I go back to Wal-Mart where I bought it and spend $59 on the extended warranty. I am certainly going to try and do that.
Feb 11, 2011 | Insignia IS-LCDTV32 32 in. Television
Could you tell me why the tv insignia channels swich fron 2 to 3 channel, and the tv value is going up and down by itself? Because I"m not able to watch my programs. Can You help with this?
if you have set top box ,go to main menu ,check on restore factory settings ,put in default password 0000 and press ok,restarting the set top box automatically,waiting for some minutes.
restarting starts scanning all channels one by one and put them on their respective location in channel store.
now ,enjoy with all channels.
same process is done with tv if u have't any set top box ,only RF input from ur cable operator.
Nov 29, 2009 | Insignia IS 20" TV040919 TV
Access database was copied now no tables in dropdown list
Your version of Access may require slightly different menus and clicks than mine, but the procedure is straightforward and should be very similar to what you will need to do. Read the whole post first!
Make sure you have permission to modify the database, then go to the form (I assume the drop-down table is in a form) and go to design view.
In design view, click once on the dropdown box you are having a problem with, and a properties screen with several tabs should pop up; click on the data tab, and look at 'data source'. In the list look for 'row source type' to see if the source of your data is a) a table or a query, b) a value list or c) a field list. Most dropdown boxes use either a value list or data from another table or a query (based on a table).
Check the source of data by going down to the next line in the list titled 'Row Source' (this is the list on the data tab that popped up when you clicked on the dropdown box in design view).
If the source is a table/query type you should see some code in the Row Source box like "SELECT....". Without changing anything, click once immediately to the right of the box, and whatever source the rows are coming from should pop up--if a query, for instance, it will pop up the underlying query in design view.
You should be able to troubleshoot the underlying query to see why no data is given in the dropdown box.
Another point where underlying query or table is used: If the table was based on a query that pulls data from the records in the current database, the drop down list will be blank until new records are added so the query has something to list.
And if the source is a 'value list', the values should be included in the row source box below, separated by semicolons. If not you simply need to add them in.
If your source is a field list, go back to whomever copied the database and tell them you need help with the copy they gave you...
Sep 13, 2009 | Microsoft OFFICE 2003 BASIC OEM ENGLISH MS...
Insignia tv, universal remote, and.....
Follows steps below to program your Insignia Converter Box:
1. Turn on your TV using your TV remote control and change its channel to 3 or 4.
2. Turn on the convert box; the blue light on the converter box is on. If you press the power button again, the red light on the converter box will be on, but do Not turn it to Red!!! Your insignia's other buttons will not response if it in red light mode!!!
3. Then press the Menu button on the Insignia remote control. A wizard will appear. The wizard does not appear if your TV is not in channel 3 or 4.
4. Follow the wizard instructions to scan channels.
Jun 13, 2009 | Insignia Digital-to-Analog Converter for...
Large black box appears in center of screen with date and other numbers on it. Push any button and it goes away for short time
You can try resetting the television controls by unplugging the television from the power source for a few hours. This means physically removing the power plug form the source of power. This may allow the controls to reset out of the latching position they are in now. If this does not help, you are having a problem with the main board.This board is master control for all the televisions functions,like audio, video and switching controls. You can call the Insignia customer support at this telephone number. 1-877-467-4289. Give them the model number of your television and ask them how you can find service for it. You can also use the customer support website. www.insignia-products.com. go to the customer support section and ask them for help with your problem. I hope this information helps you with your problem.
May 24, 2009 | Insignia IS-LCDTV32 32 in. Television
Black box in front of picture
If it's the box,just press the CCD button on the controller until you see CCD off .(Try this one first since it just started with the box)
If it's the TV,just go into the setup options and turn off the closed caption feature.
Jan 07, 2009 | Insignia Digital-to-Analog Converter for...
Insignia digital converter box NS-DXA1 saying no signal
Connect your Insigna unit to your television video 1 input. Connect your antenna to the Insigna. Turn on the television to video 1 source. Power on the Insignia. Now go through the auto-detect routine to set up your television stations.
Dec 29, 2008 | Insignia Digital-to-Analog Converter for...
Insignia 42" LCD resolution > 1280x1024 w/ computer source
Salutations RandomDrone,
From reading your owners manual it appears the max resolution of the television would be 1280X1024 when using the VGA connection.
If you would like to review the manual it should be available at:
http://www.insignia-products.com/skins/skin_1/Topics/Documents/07-290%20NS-LCD42HD_WEB.pdf
Sorry, I didn't have better news.
Jon
Go Ahead. Use Us.
Jun 01, 2008 | Televison & Video
Insignia 37" LCD Flat-Panel HDTV Logo
83 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
