Question about Miller Welding Tools
My miller sychrowave tig welder is not blowing sheilding gas when it strikes an arc. The gas is on at the tank. I can hear what sounds like gas or a valve opening when I press the foot control, but my sheet metal immediately rusts when I strike the arc. The hose is not obstucted. The manual doesn't mention this problem.
  • 3 Answers
Remove the tig torch twist lock from the front of the machine. Step on the pedal as if you were striking an arc and gas should flow out of the twist lock port. If gas comes out of the port, your torch probably has a valve built in (many do) often this is a sleeve on the torch body which you rotate but may not be obvious.
If no gas out of port then its the solenoid or regulator.
You do have the machine in TIG mode and not stick?
Posted on Jun 04, 2010
Testimonial: "Your solution didn't solve the problem directly, but it led me to the solution. I had the tig torch hooked up to the "work" plug when it needed to go into the "electrode" plug. Removing the side panel to find the valve showed me where the argon hose went. Thank you!"
Miller welder 330a/bp it will not weld in D/C straight or reverse no ark but will work in A/C its like there is very low volts I was welding and then could not strike a ark
It's likely that your pedal is the problem. Pull the cover and check it electrically - these have been problematic in the past. You can further troubleshoot by selecting constant output and test the output.
Nov 09, 2011 | Miller SYNCROWAVE 250 DX TIG RUNNER WELDER...
The tig welder will arc but there is no amperage and nothing is heated up it acts l;ike there is no amperage?
Make sure you have a good ground. With high frequency you can get it to still arc but have a bad ground.
Jun 11, 2010 | Miller Hf 251D 042388 Tig Hi Freq For...
No gas flow
If theres a pre or post flow set it will deley gas flow when using a foot pedal or strike arc.
Jun 05, 2010 | Miller Welding Tools
Hi, starts to weld fine after a few seconds hi
It sounds like you need to change out your SCR chip on your motherboard; Miller makes one that i have installed on all our 350xl's, I don't have the number on hand but i can get it for you tomorrow.
Oct 20, 2009 | Welding Tools
Miller Syncrowave 250 / no tig arc start
seems that you have a ground issue. make sure the ground clap is on barte metela and secured tight. make sure your tungsten electrod is about 1/8 of an inch form the edge of the cone. you will find that you will get a faster arc this way.
Apr 10, 2009 | Miller SYNCROWAVE 250 DX TIG RUNNER WELDER...
I NEED TO AIR ARC CAN THIS MACHINE DO THIS AND HOW
hook up to the stick position on the machine - to work + to the stinger hook stinger to the air arc hook up air to the air arc turn welder up to top {350}turn air on at the push button on the air arc & get busy
Apr 09, 2009 | Miller DYNASTY 350 TIG WELDER w/TIG TORCH...
Welding Tools Logo
270 people viewed this question
Top Miller Welding Tools Experts
Kory Ronning
hubiam
hubiam
Level 1 Expert
John Trevino
Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
