Question about Microsoft Xbox 360 Console
I need to know how i can get xbox live with the ethernet cable
    Problem Solver:
  • 16 Answers
1.Simply connect your xbox 360 to the internet with the Ethernet cable. Go from the xbox 360 to a router or directly to your internet source; internet modem or internet cable if you have fiber optic internet connection.
2. Turn on your xbox 360 and go to the xbox live tab.
3. Go wher it says Join and follow instructions.
You can put your credit card info. or buy a prepaid xbox live card
Posted on May 28, 2010
2 Suggested Answers
  • 5 Answers
SOURCE: Xbox not recognizing ethernet presence
did you buy a new ethernet cable if you didnt i recomend the cat 5 (blue from staples depending on your length get what you think is good trust me it lasts and mine was only 15 bux (100 footer) if youve already tryed this cord it might b the socket of the plugin try blowing on it or have it sent in (if the warranty is good your on the house if its not your goona have to pay a lil cabbage ;) ) dont worry its not sent in forever
Posted on Aug 17, 2009
What do you need to do to get xbox live
You will need an active internet provider and depending on what Xbox you have, either an ethernet cable or an adapter.
the new Xbox has WiFi built in and the old one will need an adapter for WiFi.
If you do not have wireless or the new xbox, both models just require an ethernet cable going to the router.
Dec 07, 2011 | Microsoft Xbox 360 Slim
I dont know how to set up my xbox live with an eathernet cable can you help?
Hi there
Turn off the Xbox 360 by pressing the power button on the front of the console. Afterward, shut off your modem by unplugging its power cord.
  • 2 Insert one end of the Ethernet cable into the Ethernet port located at the back of your Xbox 360 console. After that, insert the other end of the cable into your modem.
  • 3 Replug the power cord into your modem to turn it back on. Once it is active, press the power button on your Xbox 360 to turn it on.
  • 4 Navigate to "My Xbox" then "System Settings." Afterwards, select "Network Settings" then "Test Xbox LIVE Connection." You will be notified on-screen if the connection is successful.
  • Read more: How to Set Up Xbox LIVE with an Ethernet Cable | eHow.com http://www.ehow.com/how_6714462_set-xbox-live-ethernet-cable.html#ixzz0xBK8Zctz
    GOODLUCK!!
    Aug 20, 2010 | Microsoft Xbox 360 Console
    I have a Cayman 3347w wireless router and I am trying to use one of the wired slots to connect my xbox 360 to the internet. the xbox will not connect. is this router xbox compatable?
    Please try the following steps below;
    To make a router connection to Xbox LIVE:
    1. Before you connect any cables, turn off your router, modem, PC, and Xbox 360 console. (Unplug your modem from its power source to turn it off.)
    2. Connect one end of an Ethernet cable to the Ethernet port on your modem and the other end to the Ethernet input port on the back of your router.
    3. With another Ethernet cable, connect one end to one of the router's Ethernet output ports. Connect the other end to your PC's Ethernet port.
    4. With the third Ethernet cable, connect one end to another of the router's Ethernet output ports. Connect the other end to the Ethernet port on the back of the Xbox 360 console.
    5. Turn on your modem, then your router, then your PC.
    6. Make sure your PC can access the Internet. If not, you may need to configure the router for Internet access. For help configuring the router using your PC, check the instructions that came with the router.
    7. Turn on your Xbox 360 console and sign in with your profile.
    8. If this is the first time you've turned on your Xbox 360 console, see Create Your Gamer Profile to get started with both the Xbox 360 system and Xbox LIVE play.
    If you're unable to connect to Xbox LIVE, you can try to diagnose the problem right on your console. Go to My Xbox and open System Settings, then select Network Settings (setup XBOX using Automatic Configuration DHCP), Test Xbox LIVE Connection.
    Hope this helps!
    Mar 28, 2010 | Netopia Cayman 3347W-Ent Wireless Router
    How do i hook my xbox up to my computer to get on xbox live?
    hi,
    just to elaborate on zombies post.....
    Zombie is correct in what she says...but in 'Laymans' terms.........
    you dont need to hook up your xbox to ur computer to get 'On Live' .
    The easiest way is a direct 'Ethernet' lead (plugged into the back of ur 360....(dont worry....u cant put it in the wrong slot....an ethernet lead will only fit an ethernet slot)) & the other end into an empty Ethernet slot on your broadband suppliers router (the little box they sent you which is plugged into ur fone line)....there are usually '4' ethernet slots on most routers ! once the ethernet lead is plugged in just follow on screen instructions (xbox) for 'signing' up to 'Xbox Live' :-)
    hope this is a little easier to understand ??
    p.s. Dont get ripped off buying an ethernet lead if u havnt got one long enuf ! dont let the shops tell you ur better off with 'Gold' plated ones !! its rubbish !! u dont need gold plated !
    the usual 'bay' shop (u know who i mean??) have numerous suppliers....u dont want to be paying more than £5 for at least a 5 metre one !
    p.p.s dont bother with the wireless adapters !! there pants !
    good luck :-)
    Feb 13, 2010 | Microsoft Xbox 360 Console
    Can you connect to xbox live w/out ethernet cable???
    only wirelessly
    In case you want to avail a free technical support,
    just get in touch with one of the techbuddies they provide free
    technical support, you can find them on http://tinyurl.com/n29l7c
    Jun 18, 2009 | Microsoft Wireless Network Adapter Xbox...
    Help deciding about xbox live please
    doing it the way ur talking bout u should not have any problems
    Dec 18, 2008 | Belkin (F5D7230-4) Router (587009)
    Xbox Live
    i would just use a Ethernet cable easier and faster Ethernet cable from xbox 360 to dlink router
    Aug 23, 2008 | Microsoft Xbox 360 Console
    Why isnt my xbox connecting? i plugged the cble into the rouder and then put the other cable into the xbox and its not letting me connect.
    To make a router connection to Xbox Live:
    7. Turn on your Xbox 360 console with no disc in the disc tray.
    8. If you've already used your Xbox 360 system for offline play, the Xbox Dashboard will open to the Xbox Live area. Select the Xbox Live banner. When you see the Xbox Live Marketplace you'll know you're connected to Xbox Live.
    Jul 02, 2008 | Video Game Consoles & Games
    Xbox 360 to wireless laptop
    Make sure ethernet cable from XBOX 360 is connected to one of the 4 access ports on the back of the router.
    Mar 16, 2008 | Microsoft Xbox 360 Console
    Xbox live
    Either buy a wireless xbox live adapter or take off your Hard Disk Drive (HDD) take out your ethernet cable turn off your 360 put your HDD back on and plug in your ethernet cable. If it doesn't work then i can't help, Sorry.
    Mar 05, 2008 | Microsoft Xbox 360 Console
    Microsoft Xbox 360 Console Logo
    108 people viewed this question
    Top Microsoft Video Game Consoles & Games Experts
    marley mcelhinney
    Tre Elkins
    Martin Murray
    Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
