Question about IBM NetVista PC Desktop
Suitable sound deriver
System configration
motherboard 915 ibm
processor 3ghz(HT) intel
ram 512mb
    Sergeant:
  • 260 Answers
You should be able to get the driver straight from IBM. Go to ibm.com, then go to Support & Drivers, then go to Downloads, then choose Fixes, Updates, & Drivers. After that you will have to select your computer system from their choices available or type it into the search box. Once you jump thru all of the hoops they have, you should be taken to a page that has a list of drivers that go to your particular computer.
Posted on May 28, 2010
The comptuer is ringing everytime i cut it on and won't boot up
Open cpu cabinet then reconnect RAM memory . Reconnect both connection to harddrive. Make sure motherboard is not ground with cabinet. Pull processor and it's fan. Reconnect PCI or vga card if any. then check. Make sure bios recognized harddrive. Let me know if you need further assistance. Thanks for using FixYa.
Dec 27, 2010 | Gateway 560GE Intel Pentium 4 630 3GHz(HT)...
I have an ASUS P5S800-VM Motherboard socket LGA775
To answer your question, yes it's possible.
I'm sure you wouldn't like it if I left it at that, so I'll explain a bit more.
It's about as simple as this: The processor you want to install into the motherboard is for an LGA 775 mobo such as yourself. Therefore, it should have no problems when you put it in.
Hope I was of assistance.
Nov 28, 2009 | ASUS P5S800-VM Motherboard
I have a intel 845GL motherboard with 1.7Ghz
2 x 184-pin DDR DIMM socket support up to 2 GB
recommended: 1GB x 2 DDR 333
http://www.svbinternational.com/motherboards/motherboard_845_chipset.htm
contact ur system admin/vendor for more details....
Nov 02, 2009 | Computers & Internet
What mb to update from kk266plus for modern pc
you can buy DG31PR,GL / DG45PR these series mother board but you have to change your processor too with core2 duo 2ghz series, if you want to upgrade the RAM to 4GB means this is the only way have to change the following specifications (DG31 or DG 41 series board, core2duo procc,SATA seagate hard disk 500GB, 4GB RAM) this is the complete solution .
Oct 20, 2009 | Gateway 560GE Intel Pentium 4 630 3GHz(HT)...
In vista i m getting booting problem
It sounds like your vista boot files are corrupt. You can reinstall vista and leave your files intact. Just select install when you boot your system and choose not to format hard drive. This should clear your problem.
Good Luck
C2S
Sep 15, 2009 | Intel Single Pack, mATX G965 Exp Chi...
Finding Intel 845GVSR & 915GLVG Compatible Motherboard & Proc
you can use intel dg41 mbd , dualcore processor,1 gb ram,160 gb hdd or use intel atom for support contact 91-9645071021
Aug 11, 2009 | Intel D845GVSR Motherboard
I have IBM p6 motherboard with processor Intel 1.8ghz/256/400/1.75v Processor had demaged. I replaced with Intel 1.8ghz/512/400/1.525v When I starts the system it gave error "0167 no processor bios...
I suggest this is not going to work.
1.Your motherboard is supplying 1.75 DC volts of electricity to the processor socket.
You have installed either a SSpec number SL68Q, or SL62P,
Intel Pentium 4 processor. (The sSpec number is on the top of the processor case)
These Intel Pentium 4 processors use 1.425 to 1.525 DC volts of electricity. If you haven't already, you are going to burn this processor up.
Also, the Intel Pentium 4 that you had before, is based on the Willamette Core. (180nm) These earlier Pentium 4's did not have HT.
Hyperthreading Technology.
The Intel Pentium 4 you have in it now, is based on the Northwood Core. (130nm) These Pentium 4's come with HT.
Even if you could go into your BIOS Setup utility, and change the CPU voltage, and lower it, the HT in the processor you have now, wouldn't work on this motherboard.
(CPU stands for Central Processing Unit. Another name is Microprocessor, or simply -> Processor)
You won't be able to lower the voltage in BIOS Setup, for this processor. IF you did, then you would change the Front Bus Speed, and the ram memory wouldn't work.
Solution?
Obtain an Intel Pentium 4 processor, that uses the Socket 478 processor socket, has a 400MHz FSB, and is based on the Willamette Core.
Here is a list of Willamette Core, Intel Pentium 4 Microprocessors, that will work,
http://en.wikipedia.org/wiki/List_of_Intel_Pentium_4_microprocessors#.22Willamette.22_.28180_nm.29
Apr 13, 2009 | IBM (25P3294) Motherboard
Multimedia Problem
My name is Vijay i having pentium 4 desktop configration pentium 4, 250GB hard Disk, DG965 motherboard BTRY728000WW,Processor Intel core 2.0 Duo 2.20 GHZ (4500) 1GB Ram, configration.So, I am using Windows XP and 2003 Operating Systems. But my mother board sound drivers not installed in 2003 operating system. The sound drivers working in Windows XP. Please tell me the
solution.kindly send me details below mentioned e-mail id or through mail address.
krishna.nv556@gmail.com
P.No:90101 90419
I am awaiting your early reply.
Kind regards,
Sep 18, 2008 | Intel Motherboard
Cpu upgrade
You can upgrade your pc to intel chipset original motherboard...and do it to intel core 2 duo processor. if u want to upgrade ur ram then go for 1GB ram... and 250 GB hard disk and finally go for pentium-IV and dvd writter... and use microsoft mouse and keyboard bcoz it does not require driver to be installed
Oct 01, 2007 | IBM I System Board (61H2600) Motherboard
IBM NetVista PC Desktop Logo
117 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
