Question about Honeywell CT3200 5-2 Day Electronic Programmable Thermostat Heater
No cool air
The air is blowing but it's not cold and the snowflake is still flashing.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 195 Answers
Is the AC unit running outdoors? if not , check breakers , and in the electrical disconnect mounted on the wall or unit, there are time delay fuses that can go n
bad. IIf fine with electricity, remove the A/C panel to elec components and depress the contactor to make compressor and fan run, if it does the low voltage(24 volts) isnt making it on yellow and common wire of 24 volt control circuit.
Posted on May 29, 2010
Flashing snowflake on ac no idea name of thermostat
Usually a flashing snowflake means you are in a time delay for cooling. If the snowflake becomes solid, cooling should start. If it never stops flashing, possibly it's bad. Turn power off to air handler, remove stat and put red green and yellow together and turn power back on. If indoor AND outdoor work and cooling begins the tstat is definitely bad.
Aug 18, 2017 | Heating & Cooling
What does the snowflake mean on a Honeywell thermostat in cooling mode. Also had the problem in the heating mode.
The snowflake means it's cooling. If the outdoor unit is not running then the problem is likely outside.
May 21, 2017 | Honeywell Heating & Cooling
Flashing snowflake
The flashing snowflake means it is in the cooling mode, but is waiting for itself to 'time out' after a call for cooling. It should be about a 5 minute delay then should come on automatically. At that poing, the flashing snowflake becomes steady.
Try it one more time and set the timer on your smart-phone to ten minutes before you touch it again. If that time elapses and no cooling and it is still flashing there's possibly a problem in the thermostat that will necissitate replacement.
Aug 02, 2014 | Honeywell Heating & Cooling
Why car isn't blowing cool air except while driving fast?
Are you saying the air coming out of the vents is not cold unless you are moving ? Or there is no air unless you are moving ?
And are you sure the radiator fan is running with the ac on ? Can you feel air being pulled thru the condenser ? What are the gauge readings with the ac on and the engine at idle ?
May 18, 2013 | 2003 Mitsubishi Eclipse Coupe
Honeywell Thermostat RTH110B
It probably has stopped outdoor unit and the blinking is to be done when working anamoni.afto heating and not to bring in cold air flashes the LIGHT as long heated air into the condenser.
Nov 01, 2011 | Honeywell Electronic Programmable...
HAIER CPN11XCJ new, doesn't blow cold
There are three settings. If you have it on FAN, it won't blow cold. The raindrop picture is for dehumidifying, and the snowflake picture is the setting for COLD. If you shut the unit off and on too quickly, it takes a minute or two to cycle back to cool.
* Make sure the 'snowflake' setting/picture is selected...
Ours works too good! We sleep with 2 blankets! Nice...
Jul 25, 2010 | Haier Heating & Cooling
Flashing snowflake symbol and a/c is not blowing upstairs
flashing snowflake normally means it is in a time delay. give it five minutes and see if it continues.
Jul 20, 2009 | Honeywell Electronic Programmable...
Problem understanding Icons on Remote control
The snow flake icon is for your cooling, the sun icon is for heating, please rate this as it will help us if this was helpful to you, thanks,
mr.grzz
Jan 23, 2009 | Continental CE-AC75271 Ductless Mini Split...
2004 camry a/c
You have a faulty a/c snowflake switch or wiring broken that's why no cold air is coming in. This will not let the a/c compressor engage to give you that cold air you wanted. Your problem to be specific is from the fuse in which you said is good and through that a/c snowflake switch.
Aug 23, 2008 | 2004 Toyota Camry
Re: 1998 Mitsubishi Diamante Air Conditioner problem
check the refrigerant it might have 2 be recharged
Aug 18, 2008 | 2002 Mitsubishi Galant
Heating & Cooling Logo
796 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
