Question about Apple MacBook 13"White /2.0Ghz Intel Core2 Duo White/2GB (2x1gb)/80GB/SuperDrive (Z0DT) Mac Notebook
Macbook start up problems
While working on a paper my macbook froze, so i forced a shut down. then after waiting a while i restarted it, only to get a grey screen with a flashing file icon with a ? inside of it. what should i do?
  • 1 more comment
  • daviemacbook May 08, 2008
    ?????????????????????HELP.............ME...........PLEASE......I have the same problem...........???????????????????PLEASE??????????????
  • daveclark5 Dec 18, 2008
    grey screen on load up with flashing file and ? in centre
  • Anonymous Apr 27, 2009
    I have the same problem - when starting my machine I just get a grey/blue screen which a flashing folder with a ? inside it - any help much appreciated
    Cheers
    Neil
We'll that happened to me also.. i researched and found if you goto apple.com and look up support for macbook. Look for .pdf macbook repair manuel. There you'll get start up procedures. turn off power. Then load start disk, hold down "alt/opt" button and then turn power on. Wait for a min or two and then you'll see your hard drive and start disk to choose from. Choose start disk and click enter. Be sure your disk isn't scratched.. i had that problem. Then wait... it takes awhile so be patient. You'll get the whole set up again. DONT ERASE YOUR PRIOR DISK!!! Thats where i screwed up! So.... you should be able to get what you want .. if not.. its a new hard drive you'll need to buy... i'm heading to Best Buy and the Geek Squad for my help!
good luck!
Posted on Jun 01, 2008
  • 22 Answers
Here is apple solutions to the problem
http://docs.info.apple.com/article.html?path=Mac/10.4/en/mh2239.html
Posted on Apr 18, 2008
  • 4 Answers
Http://www.retrodata.co.uk/notice_apple_seagate_drives.php
Posted on May 15, 2008
Hey, i got a problem thats different from that.Wen i click safar or anything else to open up, it doesn't work, and my menu bar is screwed up too. Any suggestions on how to fix it. I tried restarting and its still the same.
Posted on Nov 15, 2008
SOURCE:
Why macbook not turn off blank screen
If the Apple laptop (or desktop) doesn't shut down properly, try pressing and holding in the power button for 3-5 seconds. This will force a shut down. Good idea to wait a few minutes before attempting a restart again.
Aug 30, 2014 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Force eject CD from Macbook
A few ways of doing this
restart mac and press down the trackpad after you hear the startup noise
if that does not work try opening up disk utility and click on the icon of your disk under the left hand column then go up to eject button and click eject
or open up terminal found in the utilities folder within your applications folder and then type in
drutil tray eject and then press return
Finally what to do is try pick up your macbook tilt the macbook to the one side and press the eject key and hopefully the effect of gravity will allow the CD to fall out.
Hope this helps.
Dec 19, 2011 | Apple MacBook Mac Notebook
My mac book air is not shutting down..i just can see a desktop background and a coloured disk..
To have a try like this,put off the power connect wire,and took off the laptop battery for Makbook,it must be shutter down.Then restart it again! Good luck.
Feb 28, 2011 | Apple MacBook Air
Computer froze, I tried to restart but it would not shut down. It is now stuck with only background showing. Can you help.
Press and hold the power button for about 10 seconds will power off the MacBook Pro.
You can then try turning it on again normally.
If the problem with freezing reoccurs on start up, then hold down the power button again, and turn it off. Unplug the MagSafe Power Adaptor from the MacBook and the Wall for several seconds. If the battery is removable, then remove it, wait for a few seconds and re-insert it. Plug the MacSafe back in if desired. You should now be able to start up the MacBook with no problems.
Sep 08, 2010 | Apple MacBook Pro Notebook
I watched a movie earlier on my epson projector with my macbook. but this evening all it shows is a blue screen and I have tried very much to get it going. I think some how now my mac in not connecting to...
You may have disconnected the projector while your laptop was about to go to sleep. Try (force) restarting the computer by holding down the power button for a few seconds, wait til it shuts down, then power-up again!
Aug 14, 2010 | Apple MacBook Mac Notebook
Computer froze and will not restart
You need to reset the firmware.
Remove the battery, and boot up but holing the power button down until you hear a loud Beeeeeeeeep, and the lights start flashing. Let go, and wait.
Regards.
Jul 21, 2010 | Apple MacBook Pro Notebook
It won't turn on
try booting in safe mode (hold shift key while booting)
Jun 08, 2010 | Apple MacBook Mac Notebook
Dell mini forced shut down, now runs slowly
go to start - accessories - system tools - system restore - choose a date when it was working fine, preferably the earliest date. then wait for it to shut down and restart. you will not lose any saved files or folders, you will only lose programs installed after the date you choose.
Jun 18, 2009 | Dell Inspiron Mini 10 Notebook
A Frozen 2008 Macbook Air
try You can force a frozen MacBook Air — or any current Mac laptop — to shut down and restart without removing its battery. You just hold down the power button for a few seconds until the machine shuts off, then wait a few seconds, then turn it on again.
Mar 08, 2009 | Apple 13.3 MacBook Air 1.8GHz 2GB RAM 80GB...
Macbook - BLANK SCREEN!
Itunes is very tricky and its freezes computers very badly.try to take out battery and than turn on computer slowly,Soon if you can you need to reinstall itunes maybe to start to work better.
Jun 04, 2008 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Open Questions:
HP PRINTER Technical Support Phone # I:888-67O-O271 Number This HP PRINTER USA phone number is ranked #2 out of 2 because 7,728 HP PRINTER USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:888:,:67OO27I is to reach the HP PRINTER USA Technical Support department for problems like Where to buy, Complaint, Technical support, Repairs, Returns. As far as we can tell, HP PRINTER USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. HP PRINTER USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about ************ and ways to call or contact HP PRINTER USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling HP PRINTER USA Calling HP PRINTER USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from HP PRINTER USA Technical Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with HP PRINTER USA's Technical Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare HP PRINTER USA's phone numbers against each other. Contacting HP PRINTER USA in General While ************ is HP PRINTER USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that ************ is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach HP PRINTER USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact HP PRINTER USA.
Oct 16, 2019 | HP Computers & Internet
CANON PRINTER Printer Technical Support Phone # I:888-67O-O271 Number This CANON PRINTER USA phone number is ranked #2 out of 2 because 7,728 CANON PRINTER USA customers tried our tools and information and gave us feedback after they called. The reason customers call ************ is to reach the CANON PRINTER USA Technical Support department for problems like Where to buy, Complaint, Technical support, Repairs, Returns. As far as we can tell, CANON PRINTER USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. CANON PRINTER USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about ************ and ways to call or contact CANON PRINTER USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling CANON PRINTER USA Calling CANON PRINTER USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from CANON PRINTER USA Technical Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with CANON PRINTER USA's Technical Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare CANON PRINTER USA's phone numbers against each other. Contacting CANON PRINTER USA in General While ************ is CANON PRINTER USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that ************ is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach CANON PRINTER USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact CANON PRINTER USA.
Oct 16, 2019 | Canon Computers & Internet
See all Apple MacBook 13"White /2.0Ghz Intel Core2 Duo Questions
Apple MacBook 13"White /2.0Ghz Intel Core2 Duo White/2GB (2x1gb)/80GB/SuperDrive (Z0DT) Mac Notebook Logo
6,371 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Ekse
Jeffrey Groves
Jeffrey Groves
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
