Question about Ruud Handler Air Conditioner
When i turn my ac off the fan continually runs the only way to shut it off is to pull the inspection cover off which kills the power to it, whats causing it?
  • mopar440man May 28, 2010
    did you check the t-stat to see if the fan switch is set to auto?
  • 674 Answers
Does it start again as soon as you put the cover back on it? If it does then your fan relay may be stuck. You could turn the power off and check for continuity across the contacts that power the fan. Let me know what you find. Some units use a sequencer to control the fan instead of a relay.
Posted on May 28, 2010
Compressor/Condensor fan need to be turned by hand to get it started. Do I need a new fan motor or could this be a larger issue.
If the fan does indeed run ok without any bearing noise and the blade spins freely when you push it and then runs ok your motor start capacitor is bad on the motor. This is usually a small metal oval shaped can with two wire leads attached to it to help kick the motor armature into spinning when your ac unit first turns on.
The capacitor is about 4 to 6 uf (microfarads) and at is available at a local electrical supply house and is under $10 and if your handy with small tools this could be replaced by yourself if you are willing. BE SURE TO PULL the OUTSIDE POWER DISCONNET before taking any covers off. 240 volts ac for the compressor motor and fan motor plus even the 110 volt control power will kill you before you can blink! The control relay from the thermostat in your home is 24 volts ac. Get a friend with a voltmeter to verify the circuits are truly dead before you attempt repairs. Good luck and use a voltmeter to make sure the power to the ac unit is off! Regards, Dennis
Aug 16, 2015 | Heating & Cooling
Why does my fan continue to run after car is shut off?
Which fan are you referring to? The pusher fan in front of the radiator is tied to the AC system. If it continues to run for an extended period after you turn off the key, then there is likely a problem with the relay. I think your model year has the 2 speed fan. Does the fan run at high speed or low speed when you turn off the car? Does it do it if the AC is off?
Oct 13, 2014 | 2000 BMW 528i
Very loud when fan is running
This is likely caused by a faulty blower motor bearings, or the fan has something in it or it could possibly have broken. Shut down power to unit, remove cover and inspect the fan shaft, blades, and spin it. it should freely spin. If it hangs up you likely have a bad blower motor.
Mar 03, 2014 | Carrier XHB123D X/Y Series Heat/Cool Air...
Triumph tiger 955i radiator fan doesnot shut off
Hi, Check that temp switch. replace if nescessary. If the engine is running too hot change the thermostat for a colder one. Good luck.
Mar 15, 2012 | Triumph Tiger Motorcycles
I have a 95 Gran AM GT with 3.1 auto. The motor will run until it gets overheated and boils over, but the fan will not start.I have totally flushed the system,pulled and inspected the water pump, changed...
Fan operates when coolant temp reaches 226 deg.F and shuts off at 219eg.F
fan is controlled by the PCM infuts from Eng. coolent temp. sensor & Intake air temp. sensor
the yellow wire is the 5V reference and the black wire the is the PCM ground sensor
make sure your not using teflon tape on the threads of the temp sensor.
it sounds like the PCM wont turn it on. check the harness for continuity between temp. sensor and PCM harness
clear connecter - pin 17 black, pin 31 yellow
Sep 12, 2010 | Pontiac Grand Am Cars & Trucks
1996 Buick Riviera Cooling fan won't shut off. we
COOLING FAN IS CONTROLLED BY COOLANT TEMPERATURE SENSOR (CTS). REMOVE THE CONNECTOR FROM IT AND IT SHOULD STOP THE FAN.
OR JUST REMOVE BATTERYGROUND CABLE.
ITEMS TO CHECK OUT :
CTS,RELAY,CIRCUIT FOR SHORTS.
NOT LIKELY BUT IS A POSSIBILITY, THR ECU.
Jun 09, 2010 | 1996 Buick Riviera
Shut off automatically, and I run it in fan only mode
Remove filter cover and see if front coils /fins are frosting up. Let me know
May 17, 2010 | Dometic Rooftop RV Air Conditioner
Fan motor
I have the same problem with mine, I would love to know what to do to fix it. I have turned the machine off at the power box.
Mine is a Kelvinator split system
Jul 13, 2008 | Heating & Cooling
Unit will not turn on.
I think we have the same problem only mine is flashes an F61 on the display then shuts itself off.
Jan 02, 2007 | Panasonic SC-HT650 System
Heating & Cooling Logo
88 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
