Question about Magellan RoadMate 2000 GPS Receiver
How do i decide if my magellan needs a new battery or a charger. the green light on the charger is on when i plug into the cig. lighter weather i have it plugged into the magellan unit or not. the unit when trying to charge it powers on momentarily then powers down. is there a way to tel if i need to replsce the battery,charger,or both? thanks, Judy
    President:
  • 1,111 Answers
The folowing advice pertains to the following magellan gps systems.
Magellan 800, 860, 2000, 2200t, 2500, 3000, 3050, 3100, 3140, 4000, 4040, 4050 and 6000t
i fix these 2000 and many other magellan gps daily so when considering my advice , please understand i do not google my solutions.
assuming your car charger is working (the little green light is on) and your 2000 still wont start up after holding the power button while its plugged in for up to ten seconds and still does not start..read below
this is actually a very common problem with these magellan power ports...they are poor quality from the factory and always and i mean always fail..the new ports that you find on ebay are 100% better then the factory port.
if your able to replace that power port yourself, you can get one HERE, if not, ask the fellow that sells them for help.
due to some dubious "experts" on fixya, im not permitted to help you directly, but please follow the link above to get further help.
let me know if you need more help or info
bill
Posted on May 29, 2010
My Magellan Roadmate doesn't work anymore when I plug it into my cigarette lighter. It says the battery is low and it is shutting down. The unit did not come with a battery charger so I am confused about...
there could be a few reasons why this is happening....
there should be a light on the car charger that comes on when you plug it in, if it isnt on when not plugged in to the gps, but while plugged in to the lighter...either the lighter fuse is blown, or the charger is defective.
if the light is on, on the charger and it still wont stay powered on, it probably has a bad usb port (very common on this model) but it could also mean the charger (if not factory) is not compaible with the unit.
another way you can try and charge it (if you determine the chargers at fault) is to hook it up to your computer via the usb cord that should of been supplied with your unit.
HERE is your manual..it will show you the differant charging options..there is also updates on that page if you need them
let me know if you need more help.
bill
Aug 17, 2010 | Magellan RoadMate 1470 GPS Receiver
Says battery is extremely low and will now go to sleep.
the folowing advice pertains to the following magellan gps systems.
i fix these and many other magellan gps daily so when considering my advice , please understand i do not google my solutions.
assuming your car charger is working (the little green light is on) and your magellan still wont start up after holding the power button while its plugged in for up to ten seconds and still does not start..read below
bill
May 17, 2010 | Magellan Maestro 4000 GPS
Won't turn on.
if you still have an issue with this, ill be glad to help you..just reply to this post ..(see my feedback)
YOU CAN NOT CHARGE A MAGELLAN 4040 WITH A USB CABLE!
if the green light is on, on your car charger, the charger is working..if its on (the green light) and still wont start after holding the power button for up to ten seconds, let me know and i will help you further.
May 06, 2010 | Magellan Maestro 4040 GPS Receiver
My magellan maestro shuts off after 10 seconds even if it's plugged in the cigarette lighter charger.
I had similar problem. While it was still on I pressed the recessed "reset" button and it magically fixed the problem. It retained all my prior settings and locations. Note: must press reset before unit powers off.
Mar 07, 2010 | Magellan MAESTRO 3100 98083401 GPS Device
I have a legacy item (Roadmate 800). The battery was dead so I ordered a new one. The new battery powers on the unit but when I plug in ac charger I don't get a solid orange light, but a flashing green...
This is very common problem with this and many model of magellans.
Try the car charger.
Make sure
green light is on the car charger and let it plugged in for awhile, then hold the power button (up to ten seconds) until it starts..if that fails
The following Magellan 2000, 2200t, 2500, 3000, 3100, 3140, 3000, 3050, 4000, 4040, 4050, 5310 and the 6000 are known to have faulty dc connectors...if your Magellan
gps is not charging or will not power up, its most likely the dc power port...
You can
buy the port or get it repaired, HERE
if the links dont work or If you need further help, just let me know.
Feb 07, 2010 | Magellan RoadMate 800 GPS Receiver
Looking for the cigarette lighter fuse
Check all fused related to audio, dome light or instrument cluster. Try plugging a cellphone charger into the socket for cig lighter, if this works then you need a new cig lighter.
The cig lighter is probably part of the circuit tied to radio instrument cluster or dome lights, if any of those are out too, then it is likely a bad fuse or bad ground. Look for corresponding fuse and kill 2 birds with one stone hopefully by replacing the faulty fuse.
If you locate and replace a faulty fuse and the problem persists, you may have a bad ground. This is a bit more involved. I would guess by your question that you will need to have someone service it for you.
Oct 29, 2009 | 1992 Mercury Grand Marquis
Magellan Roadmate 2200T -dark screen
its probably not charging...very common problem with this and many others.
make sure green light is on the car charger and let it plugged in for awhile, then hold the power button (up to ten seconds) until it starts..if that fails
the following magellan 2000,2200t,2500,3000,3100,3140,4000,4040,4050 and the 6000 are known to have faulty dc connectors...if your magellan gps is not charging or will not power up, its most likely the dc power port...
you can get it repaired, here
or buy the port here
if you need further help, just let me know.
Oct 09, 2009 | GPS
Magellen RoadMate 700 will not power up
if your sure its charged,(is the green light on the car charger) hold the power button for upto 15 seconds till it starts.
Jul 19, 2009 | Magellan RoadMate 700 GPS Receiver
1989 toyota corolla cigarette lighter doesn't work
The fuse should be beside the accellerator pedal behind a black cover. Should be a yellow 20amp in the middle row, at the end, closest to the front of the car.
Apr 10, 2009 | 1989 Toyota Corolla 2 Door
Magellan roadmate 2000 no power
the following advice pertains to the following magellan gps systems.
Bill
Standing Member of G.O.T.
Nov 16, 2008 | Magellan RoadMate 2000 GPS Receiver
Magellan RoadMate 2000 GPS Receiver Logo
229 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
