Question about Mackie SWA1501 Subwoofer
Back screws for Mackie 1501 amp.
All i need is to know where I can have the screws that hold the speaker in place shipped immediately?
Thanks
    Brigadier General:
  • 8,546 Answers
Literally, you're asking where you live.
Can't you just take it down to a hardware store and get them?
Posted on May 28, 2010
How to open my mackie swa 1501 subwoofer to change the fuse?
Service manual is available for free from https://www.manualslib.com it contains disassembly instructions. If you change the fuse and it blows again, then your amp will need service.
Oct 06, 2014 | Mackie SWA1501 Subwoofer
1501 sub will not power up. i opened, inpected and replaced power fuse 250v 6.3 amps replaced with same fuse and it blew as well immediately. what to do and how. I have some technical experience.
Isolate and look for possible shorted components.
Isolate the main power transformer from the board, and see if the
fuse still blow.
If it doesnt , then the rectifier and capacitors to the regulators.
But don't forget to check for possible shorted transistor
Sep 23, 2011 | Mackie SWA1501 Subwoofer
Hello there i have a mackie srm 450 speaker system and im not getting any high end tweeter sounds just bass only what coule be the problem manay thanks Paulie
The most common cause of this is a blown horn. A replacement can be ordered from Mackie directly. Remove the screws that hold the plastic horn in place. At the rear of this part will be the tweeter assembly that unscrews from the horn. This needs to be replaced.
Another possibility is that the tweeter driver has broken from the horn itself and is inside the cabinet. Remove the horn and you may find that the aluminum part has broken. Replace the horn which comes with that part and you should be fine.
Dan
Aug 12, 2010 | Mackie SRM-450 System
The Amp on Mackie SWA 1501 sparked and burned today
I don't think the amps are available from Mackie any more. You can have it fixed: www.alivesoundcenter.com
Nov 26, 2009 | Mackie SWA1501 Subwoofer
Need Schematic
  • this site will help you to get the schematics
  • audio.manualsonline.com/manuals/mfg/mackie/swa1501.html
Aug 07, 2009 | Mackie SWA1501 Subwoofer
Mackie SWA1501 Base Bin - Circuit Boards burnt.
They are not publicly available. Mackie authorized service centers are the only places that will have that information. The amp (if it has failed) requires a bit of skill to rebuild, and up to 100$ in parts alone. (not including the speaker driver if it's blown). I have repaired several of these in the past, and they aren't that simple. There is also a service bulletin about 2 diodes that usually need to be swapped with one another because of a defect during manufacture (the parts were installed incorrectly). (One is D20) if you rebuild the amp, and fail to address the diodes, it will fail again very shortly.
Jun 12, 2009 | Mackie SWA1501 Subwoofer
Mackie srm450 power light out
if its the blue front light you are talking about it is a fiddly but simple fix.
1 phone mackie and order an l.e.d. about £2
2 when it arrives take out the woofer and carefully lay to the side.
3 use a very small philips screwdriver, a tiny bit of blue tack, a mirror and a torch to remove the screw holding the small circuit board with the l.e.d.in place (the blue tack is to put on the tip of the screwdriver to hold the screw and the mirror and torch is so that you can see it)
4 remove the small circuit board and un-solder the l.e.d from it take note of the orientation of the contacts as they only work one way round) and resolder the new one in place.
5 check that it works and re-fit the board and screw ( this can take 2 seconds or 2 hours depending on how lucky you are and how sticky the blue tack is.
6 re-fit the woofer and grill.
the other way is to split the cabinet using the screws on the back and then the repair is obvious from number 4-5
Mar 30, 2009 | Mackie SRM-450 System
Mackie 1501 sub immediatley shuts down after powering up.
Hi There, There are 3 internal fuses to check that clip onto the main amp board. You can access them by undoing the two screws that are on the top and the bottom of the sub. They have flat large heads and you will need a hex key to unscrew them. If it is one of the fuses that has gone it will either be discoloured as in burnt or you will see the metal inside has split. Simply replace these with a new fuse and hey presto you should be back up and running. You might also want to check that none of the push on cable ends have dropped off fom the board as this may also stop connection going through. If you need any parts for the sub or fuses then www.LondonSpeakerShop.com will be able to supply them (that is if you're in the UK). Hope this helps. Grant (from www.LondonSpeakerHire.com)
Nov 14, 2008 | Mackie SWA1501 Subwoofer
Mackie SWA1501 Subwoofer Logo
80 people viewed this question
Top Mackie Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Mackie Audio Player and Recorder Expert? Answer questions, earn points and help others
