Question about Maytag Neptune MDG7500AW Gas Dryer
The flame goes out after about 30 seconds. I have
The flame goes out after about 30 seconds. I have replaced both coils and once again the flame goes out after about thirty seconds. I can see the heating element glow, then the flame comes on and then it goes out after thirty seconds. Any other suggestions?
  • frankiejayii Aug 24, 2010
    Okay, I am trying to get the parts on appliancepartspro.com and I can only find a flame sensor, and I do not know which ignitor assembly I should get! I am not able to find a thermal sensor... can you please help me find those items? thanks!
  • 1,531 Answers
One of the thermal sensors may be bad.
you may also have a faulty ignitor even though it glows it maynot be drawing enough current to keep the regulator open
Posted on May 28, 2010
  • seth adams Aug 25, 2010
    Here are two part number that should solve your problem.303395,4391996
I have a GE gas dryer DBVH512GF1WW. The heat is inconsistent. I noticed the ignitor glowing and then a flame shortly after on the initial time I turned the dryer on. Then after the flame going out after...
sounds like bad gas coils located on top of the gas valve,when the coils start to fail the ignitor will glow,the coils let the gas in until the coils heat up and then ignitor glows but no gas.when the coils cool down they might work again for a short time until they heat up and fail again.if the flame lights and goes out after like 30 seconds and goes out and keeps doing this you have a block either in the dryer or the vent line but it sounds like you have bad gas coils.unplug the dryer,get at the valve,pull off the wires going to the coils and check them with a meter,one should be open,just remove the two phillips screws pull off the cover and slide the coils up off of the posts,unplug them and put the new coils on,you'll see like a little piece of plastic on the top of the coils,this fits intoo the cover so they line up correctly and holds them in place,also on the larger coil there's a spacer on the post,if you don't see it look inside the old coil,poke out the spacer and slide it onto the post and then install the coil.
Oct 23, 2013 | GE Dryers
I have a 11 year-old york diamond 80 furnace. The flame sensor lights up and ignite the flame for about 5-6 seconds. Soon the flame goes out once again. There's this clicking sound that is heard every
You need to clean the sensor with steel wool so its very clean check sensor connections . If it is still not working you could change sensor also check out the pressure switch .
Jun 20, 2017 | Heating & Cooling
Rinnai Royale IB35R ,the flame goes off once I released the press button, it wont hold on as usual
pamgee - it may be a case of not holding the ignition button in long enough ( at least 15 seconds) so that the flame failure device (Thermocouple) will get hot enough, to maintain the pilot flame and the low burner. If it fails to light and hold the first time, push the igniter button again and release it. Wait 30 seconds and try lighting it again.
In case you have misplaced the Owner's Manual, I have provided a link that you can download & print for future reference. http://www.rinnai.com.au/images/stories/operating_instructions/Heating/Flames/Royale%20Inbuilt.pdf
I hope this helped you to solve the problem ... Cheers
Jul 12, 2011 | Heating & Cooling
Gas dryer mod.# MDG6000BWW, Igniter lights but no flame
Replace the flame sensor on the side of the heat canister. You may also have to replace the gas valve coils.
Aug 27, 2009 | Dryers
I have a similar problem. But I will provide a little bit of history first. My dryer just doesn't get hot enough (approx 100 degrees just prior to the exhaust vent). Three years ago, I had the same...
If the gas cycles on and off I do not think the coils are a problem.  Sounds like the flame sensor is not working correctly.  The flame sensor keeps the gas valve open after the ignitor shuts off.  Then the temperature sensor shuts off the gas when temperature limit is reached.  When the dryer cools down the gas cycle starts again (usually much more than 30 seconds).
May 29, 2009 | Dryers
Whirlpool model GGQ8858EQ1 gas dryer starts, gets flame and begins heating. then after a short while flame shuts off and i hear a chattering noise somewhere near the bottom of dryer. It lasts for about...
The problem is your gas valve solenoids (coils). There are usually two of them mounted on the burner assembly. One is the MAIN coil, the other is the SECONDARY coil. It is recommended that you replace BOTH of them at the same time. Replacements can be purchased on line at appliancepartspros.com. Just type in the model number you provided and look under the "Burner Assembly" section for items 13 and 14. I hope this helps you.
May 05, 2009 | Whirlpool Dryers
Flame will cut off in 30 second
check the loose blower wheel and lint in the filter housing phenom associated with these dryers. The operator coils will get hot and quit and cool down after several hours and work again making it imposible to pinpoint a solution. Replace those coils. $20 bucks.
Dec 17, 2008 | Maytag Neptune MDG5500AW Gas Dryer
The flame does not stay on for more than 30 seconds i have replaced the coils
Hi. thanks for the question . The problem is with the air flow. Maytag dryers are known to have a blower failure . replace the blower . And clean all vents. Thanks the appliance doc
Sep 30, 2008 | Maytag MDG7600AW Gas Dryer
Maytag Neptune MDG7500AW Gas Dryer Logo
247 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
