Intermittent sound from one channel (ch.3), sounds like variable wind blowing across an open mic. Makes this sound for about 3-4 seconds, about every minute or two. Happens wether or not anything is plugged in to input. If fader is up, there will be noise.
  • Scott Wright Apr 07, 2008
    It is an audio mixer...Behringer UB1832FX-Pro
  • 4,234 Answers
Is this a receiver or a mixer? In any case, the problem is most likely a noisy transistor in the front end of the unit. If you can supply the make and model number, I should be able to direct you tot the offending part or at least the correct circuit.
Dan
Posted on Apr 07, 2008
  • ABRsvcs Apr 07, 2008
    Thanks for the update. A couple of things to look for if you are comfortable working on electronics:
    1) Try looking for cold/poor solder joints close to the area of channel 3. You will find that the components for this channed reside inline with the channel slider.
    2) Loof for small 8 pin ICs that are markled either 4558 or 4560. These are small op amp ICs and sometimes they fail in this manner.
    3) Check the small capacitors in this area as well, Look for ones that have the flat tops bulged up. If you finmd any, replace them,
    Let me know how you make out.
    Dan
Ch. 1 on Behringer pmp4000 not working
A short on the XLR input board, or possibly a short within the XLR connector itself.
Nov 14, 2017 | Behringer Europower PMP4000 Powered Mixer
Ch. 1 No sound, Level Set LED on
This is a tough one because your LED for the Level Set is Illuminated, meaning that it sees a signal. With that being the case, the signal from the mic is getting from the input jack to the channel strip, but is not passing through to the preamp for that channel. So....either the channel strip is faulty, or the circuit going to the preamp is bad. As the other channels are probably ok, the trouble is most likely in the channel strip for Channel 1. Definitely have this looked at by a tech familiar with Behringer boards. If you can function without that channel, it will be cheaper than the repair, as the design of your board prohibits swapping out channel banks. I wish you luck and success with this issue.
Nov 29, 2017 | Music
Denon 1312 makes clicking sound will not turn on
If the front display does not light up at all when the press the power button, it is usually either the main power fuse or the power transformer. If the fuse is blowing, that usually means a short in the amp section.
Dec 26, 2012 | Denon Avr-1312 Home Theater Av A/v...
I recorded videos at a concert with the new nikon coolpix L810 and the sound on the video is horrible.What is causing the noise in my video? sounds like wind is blowing or a crackling noise
The problem is the microphone on the camera. The mic on the camera is for recording sound in more normal environments. The sound level on a typical concert is much higher than normal, and the mic on the camera just doesn't have what it takes to record sound at those levels.
One possible solution is to record the sound with a dedicated audio recording device, and combine the video and audio in your video editing software.
Jul 02, 2012 | Nikon Coolpix L810 16.1-Megapixel Digital...
Hello there, I've purchased on eBay my Sony TC-200 Reel to Reel recorder. I've opened and cleaned it to best of my knoweldge and ability. I am able to hear sounds on both speakers when I connect my...
http://freeservicemanuals.info/en/servicemanuals/viewmanual/Sony/TC200 Go here. when the page opens, click on the TC200 to download the service manual. There are 3 tubes and one transistor in each channel. Test the tubes first. They fail with age. You can still get tubes. You just have to google the tube number to find a seller.
May 15, 2017 | Quantegy 456 Reel-To-Reel Recording Tape
When plugged into the board, it just makes a rumbling noise, similar to the sound of wind against the mic. No other sound comes through.
First try another cable. If still bad, try another channel on the mixer. Obviously , you know this microphone requires phantom power.
If all fails, then the capsule o the microphone is shot. Either from being dropped, or excessive spit/moisture getting on the capsule.
Hope this helps.
Apr 13, 2010 | Neumann KMS105MT Professional Microphone
Cobra CB
is any wires in the mic catching in the plug as this is a common fault with a lot of radios . eg. pulled mic wires.
Apr 09, 2009 | Cobra 18 WX ST 40-Channels Base CB Radio
Correct wiring for a ASTATIC TEARDROP MIKE to a RANGER RCI 2950DX
here is the info you asked for the following is the correct wiring.
Mic Wiring Info
Stock Mic Wiring
1. Ground Shield
2. Audio Yellow
3. Transmit Red
4. Receive Black
5. CH. Up White
6. CH. Down Blue
Turner 4-Wire MIC. Wiring
1. Ground Shield
2. Audio White
3. Transmit Black
4. Receive N/C
5. CH. UP N/C
6. CH. Down N/C
Turner 6-Wire MIC. Wiring
1. Ground Shield & Red
2. Audio White
3. Transmit Blue
4. Receive N/C
5. CH. UP N/C
6. CH. Down N/C
Astatic 4-Wire MIC. Wiring
1. Ground Shield
2. Audio White
3. Transmit Red
4. Receive N/C
5. CH. UP N/C
6. CH. Down N/C
Astatic 6-Wire MIC. Wiring
1. Ground Shield & Blue
2. Audio White
3. Transmit Red
4. Receive N/C
5. CH. UP N/C
6. CH. Down N/C
Mar 11, 2009 | Connex 3300 240-Channels Base CB Radio
Lots of white noise and crackles, and intermittent problems.
check and make sure on the back of the power supply that it is set up for your local voltage(120/240)
Sep 06, 2008 | AKG SolidTube Professional Microphone
No sound when recording channel 3
Is this when you are recording via CH 3 from a separate source? If so, try CH 4 or alternately, L1, L2 inputs.
Nov 13, 2007 | Panasonic PV-V4523S VHS VCR
64 people viewed this question
 Grubhead
Grubhead
