Goes through every cycle but never drains the water
There is a chance that there is something stuck in the drain pump area.
you can use a wet dry shop vac and attach it to the end of the drain hose to remove all the water.
then remove the front panel and check the hose that comes down from the bottom of the tub to the drain pump,if you do not find any thing make sure to stick your hand up in the hole to the tub.
then remove the hoses from the drain pump
there is a slight chance the the lid switch could also be bad
