Question about LG DLG5988 Stainless Steel Gas Dryer
My DLG5988 IS MAKING A SQUEAKING NOISE AND THUMPING NOISE. I do have mechanical knowledge, but referring to "remove set screw" is pretty ambiguous without a schematic. I've removed a number of screws from my dryer unit, and still can't seem to get any of the panels to budge and be able to open it up and see what's going on inside. The owner's manual is worthless for this type of troubleshooting. Please advise. Thanks bennychickenlegs
  • LG Master
  • 43,501 Answers
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
wry2qwh
Posted on Sep 30, 2010
The seat belt mechanism is making a squealing noise - I want to get into the mechanism how do I get into the mechanism?
Remove the door frame bottom plate (it pops out). The mechanism is behind the column bezel, just pop out the bottom and so far up to get access to it. If just squeaking, lube it.
Apr 17, 2015 | 2004 GMC Sierra 1500 Crew Cab
Thumping noise and squeaking noise!!!!
rachel you have done quite a bit to fix this dryer. Have checked the the manual for any solution? Check with Kenmor. Seems to me some fine tuning is needed rather than parts.
Feb 18, 2014 | Kenmore 63942 Dryer
GE dryer Mod # DWXR463EG1WW is squealing. Does anyone know what is wrong with it and how I can fix it?
Sounds like a rear bearing . remove the 2 screws from the top when you open the door . this way you can take the top off . When you take the top off remove the screws on the inner left and right on the front panel. disconnect the belt from the pulley and motor and pull the drum out . then you will see the rear bearing . cheap fix but can be a pain. good luck
Feb 16, 2013 | Dryers
LG Dryer is making a loud thumping and squeaking sound while drying clothes.
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Aug 13, 2011 | LG DLE2512W Electric Dryer
My Asko dryer is thumping loudly. I am finding bits of rubber when the lower panel is removed.
You need to have your drum rollers replaced, they are making the noise because they are falling apart.
Also it could be or include the drum belt breaking down and falling apart...which means its about to break.
Normally pretty cheap parts can be found on the net...look around.
Its a pretty easy fix.
Jan 15, 2011 | Asko Dryers
Dryer started making a squeaking noise, then a thumping, then stopped altogether.
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Oct 21, 2010 | LG DLE5977 Electric Dryer
Maytag neptune dryer making banging noise on each rotation on the left side facing the front. its almost like a thumping noise what do i need to do please?
The drum baffle screw has unscrewed itself and the head is thumping against the inside top panel. Pull door, lift lid, rotate drum to find screw sticking out and tighten.
Aug 03, 2010 | Maytag MDE5500AYW Electric Dryer
Frigidaire LEQ215EE1 dryer making thumping noise
Posssibly have a bad drum roller if mechanically inclined you can do this yourself but you need to take the drum out to do this
Nov 15, 2009 | Dryers
LG DLG5988 Stainless Steel Gas Dryer Logo
245 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
