Question about Canon PowerShot A570 IS Digital Camera
Memory card error/card locked
I just got a sandisk 4.0gb memory card. everytime i put it into my powershot sd600, i got the memory card error and card locked message. i also cannot format (it is blacked out). i also do not have a card reader. my other memory card (kingston 256 mb), which i've had for years still works. please offer advice and suggestions!
I had the same problem. I am currently looking at trying to use a memory card reader to see if that will allow me to access the card.
  • sharons880 Dec 16, 2008
    I have exactly the same problem - my camera still says it is locked no matter what card I put in. It is as though the new 4GB card did some sort of damage and now previously used 1GB cards won't work. I have tried moving the little plastic thing on the side but no luck.
  • 123 Answers
It sounds like your card is locked. You need to unlock it. On one of the sides you should see a piece that can move back and forth. Move it from the position it is now to the other side. This should unlock your card. When locked the files are unaccessible to anyone. This also means that files on the SD card cannot be deleted while the switch is in lock position. When the switch is in up-position, then all files located on the card are accessible to anyone, and that files may be deleted from the card.
Good Luck.
Posted on Apr 07, 2008
2 Suggested Answers
SOURCE:
  • 49 Answers
SOURCE: Memory card error/card locked
I don't know for sure, but since it is "grayed out," it MAY be that your camera can';t utilize a card that big (in gig's that is.)
Just a guess.
Posted on Mar 14, 2008
Memory card locked
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
May 10, 2014 | Canon PowerShot SX 200 IS Digital Camera
I bought a new SD card for my powershot SD600. I have tried two different cards and they both say they can be formatted. What is the problem?
Bet it's a brand new SDHC card.
There are several possible causes for "memory card locked", "memory card error", or "no memory card". Some include trying to use of a 4GB SDHC card with an older camera made before SDHC format came out. Others include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Nov 15, 2010 | Canon PowerShot SD600 Digital Camera
I have a cannon power shot SD600. I bought a memory card, and the camera says memory card error. I can't even fomat the card because the function won't high light.
Did you get an SDHC card? The SDHC protocol was developed after the SD600 came out, and the SD600 is not compatible with it. Use SD cards with a maximum of 2GB storage capacity.
May 24, 2010 | Canon PowerShot SD600 Digital Camera
Canon PowerShot SD 630 Digital Elph "Memory Card Error"
I'm sorry to tell that PowerShot SD 630 does not support SDHC cards over 2 gig.
If you want the camera to take a card over 2 gig then you are stuck standard SD cards.
The other camera does support the card because it's a higher model.
Regards.
Sep 03, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
I have a canon sd600
Sorry this is not a solution exactly but the sd600 will only accept cards up to 2gb.
Dec 23, 2008 | Canon PowerShot SD600 Digital Camera
Sd card error on canon powershot s3
I get a memory card error everytime I insert a memory card. They are not locked and I have tried 4 different memory cards and nothing works. How can this problem be fixed?
Jul 28, 2008 | Canon PowerShot S3 IS Digital Camera
"memory card error" on Canon PowerShot SD600 digital camera
we hadnt had any case like this before. i will try to research on your problem as this is the first time too that i have encountered such problem.
Mar 21, 2008 | Canon PowerShot SD600 Digital Camera
"Card Locked" error is false!
Remove card from SD600 camera. Locate sliding switch on side of SD card and move from lock to other (unlocked) position. That ought to do it. Compact flash card is another issue.
Mar 19, 2008 | Canon PowerShot SD600 Digital Camera
Just a guess.
Mar 13, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Canon PowerShot A570 IS Digital Camera Logo
249 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
