Question about RTO PasLode 900420 Impulse Framing Nailer
Paslode f350s leaking air through exaust after new o rings. Is something major wrong?
  • 2,176 Answers
Check the seal on top of the cylinder for debris or really loose fit.
Posted on May 31, 2010
How do I fix an air leak on a paslode model mu 212 f?
about 90% of the time my experience has shown that leaking air from the exhaust is a poorly seated trigger o ring, or headvalve spring not pressing tight against the cylinder.
Mar 30, 2016 | Air Tools & Compressors
Why is it shooting 2 nails @ a time?
Your driver could be broken or worn down and may need to be replaced.
Mar 15, 2015 | Paslode F350s "powermaster Plus" 30...
Why is my gun bending nails?
Adjust the Work Contacting Element. See page 4 in the manual...
http://www.paslode.com/owners-manuals.html
Adjust the depth of drive.
Make sure correct fasteners are being used.
Use fasteners that meet Paslode specifications only.
Increase air flow to tool -- use larger air lines
(3/8 ID minimum).
Increase Air Pressure. DO NOT EXCEED 120 PSI.
Jul 23, 2014 | Paslode F350S PowerMaster Plus 30-Degree...
How to unjam paslode f350s nailgun
use the driver of the tool or a nail punch and hammer and try to knock out the nails
Sep 13, 2012 | Air Tools & Compressors
Why does my paslode f350S shoot one nail, but not shoot the next nail/
Had that problem on one of mine. If it is a multi degree nailer double check your degree setting. It will always shoot the first but will jam on the second.
Feb 15, 2012 | Air Tools & Compressors
Paslode f350s.just replaced all o rings,now when you pull the trigger air leaks out through the trigger,but only when depressed..will not fire nail.please help ..thanks bob
Simple. You have a leak you didn't have before. Either find it, or take it to someone who knows what they're doing. O-rings have a thickness, as well as a diameter. If you used generic rings, that's probably the problem. Use the repair kit by Paslode.
Paslode.com can tell you where your nearest dealer/repairer is.
HH
Dec 05, 2010 | RTO PasLode 900420 Impulse Framing Nailer
How to load nails in the paslode f350s framer purchased a used nailer now trying to figure out how to load the nails
Hi, I found you a free owners manual for your model. Click on the link below and save or print.
http://www.paslode.com/uploadedFiles/pneumatic_ops_manual.pd f
Hope this Helps, RSMITH972278 P.S. PLEASE RATE MY ASSISTANCE
Dec 29, 2009 | RTO PasLode 900420 Impulse Framing Nailer
I dropped my Paslode F350S framing nailer on concrete and it has a pin hole air leak in the outer casting. Where can I get a replacement outer shell? Also can a pin hole air leak be repaired? The nailer is...
You will have to take it to your nearest paslode repair agent(check for your nearest repairer on the paslode web site). It sound like you have damaged cylinder or comb. chamber. the orange casing is just that a casing to hold the internals together. The gas framing gun is just like your car motor. Fuel(gas cell),spark(spark plug), motor(piston moving up and down a cylider) and filter/air( fan to move air around evenly and filter for tool to breath)
Dec 22, 2009 | RTO PasLode 900420 Impulse Framing Nailer
My paslode IM350 fires about once every 20
by service im assuming you mean replacing the o-ring and seals/gaskets. If not do that. But if you have it may be more of an internal problem with the air valve leaking around the piston.
Aug 03, 2009 | RTO PasLode 900420 Impulse Framing Nailer
RTO PasLode 900420 Impulse Framing Nailer  Logo
746 people viewed this question
Top RTO Air Tools & Compressors Experts
yoopertech
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a RTO Air Tool and Compressor Expert? Answer questions, earn points and help others
