Question about Brother MFC 240C All-In-One InkJet Printer
Black ink does not print
Our brother printer cannot print documents in color black despite replacing it with a new and original ink for brother printer
    Scholar:
  • 94 Answers
If your printer have a separate printerhead with the cartridge just try to replace the printerhead of that printer it is because the printerhead have a problem on that.
Posted on May 28, 2010
Brother mfc printer will not print black ink
Sounds as if the black portion of the printhead has dried or become blocked. I would advise running cleaning cycles from your printer software or the printer itself (should be tucked away in maintenance/ink management).
If this fails to help then unfortunately it is likely to be a mechanical problem with the printer itself. In which case I would recommend getting in touch with Brother themselves for repair/replacement.
Nov 07, 2012 | Brother Black Mfc J 615 W Compatible...
IMPRESSION IMPOSSIBLE .4F
change your print head, and the printer will work perfectly.
when changing print head don't use chineese ink, use brother original ink, to save your head,
Hot Sell Printhead For Brother Mfc J825 Print Head Buy New And Original... Printhead Mfc j220 Mfc j615w Mfc j410 Dcp j125 Printer Head Buy Print Head...
Oct 05, 2012 | Brother MFC-J220 All-in-One Color Inkjet...
I have replaced all my ink cartridges, colour printing fine, black won't print. Have replaced black cartridge again, incase the last one was faulty and it still isn't working. Yes i am using brother...
If one or more of the ink colors are missing from pages printed by your machine (i.e. received faxes, copies and/or documents printed from the PC etc), nozzles in the print head may be clogged, or the ink cartridge in question may not be installed correctly. Verifying that the ink cartridges are installed correctly and/or cleaning the print head may solve the problem.
Instructions here: http://welcome.solutions.brother.com/BSC/public/as/au/en/faq/faq/000000/000700/000035/faq000735_004.html?reg=as&c=au&lang=en&prod=mfc260c_eu_as&Cat=112
If this was helpful, please leave good feedback. Thank you.
Mar 06, 2011 | Brother MFC-260C All-In-One InkJet Printer
My black ink printing all of a sudden stopped..ink in cart.all other colors work fine
All brother machine have a one year in parts and labor this machine have a print head problem.
Oct 05, 2009 | Brother MFC 210C All-In-One InkJet Printer
Only colours are printing no black, all inks just replaced newly replaced black ink does not print despite several cleaning
Sounds like the black color lines (the "cables" between print head and cartridges) either have clogged ink in them, or air bubbles. Try the cleaning process found by pressing Ink Management and then Menu/Set twice. After the test print sheet is printed, answer the question(s) in the display and print up to five test prints by answering the questions.
It should solve the problem, but if it doesn't, you should perform a heavier duty purge found in the service mode.
May 27, 2009 | Brother DCP 115C All-In-One InkJet Printer
Brother Multifunction center, receiving documents, but not printing, being told that color inks are low, do not use color ink never had, original from purchase, I only print in black and white, what can I...
If it show low or near empty it still print.
If it show empty it not print.
You can use black tape cover at ink catrige on position of sensor.
Many people do like that it work.
If not work send it to service center. it hardward problem.
Dec 09, 2008 | Brother Multi-Function Center MFC-240C...
Can't print
Ok, if your brother has four cartridges then I'll assume you have black ink available. There should be a printer setting to print in black only, especially if your trying to print a colored document. If your brother only has three cartridges then cyan is necessary to form black; you will have to buy a replacement cartridge.
Nov 27, 2008 | Brother MFC 210C All-In-One InkJet Printer
Print faded after replacing black cartridge Brother 240C
The print heads don't appreciate being out of ink so the Brother printer has sensors to prevent that but the tape defeated that prevention. Maybe more cleanings or maybe a cartridge with printhead cleaning solution will help. Otherwise, I fear a new printer.
Dec 13, 2007 | Brother Multi-Function Center MFC-240C...
Can't print documents from Word.
Did you do a test print by pressing ink testprint etc.? Do you have all colors incl. BK? If yes, check the printersetting WITHIN Word. Is the mfc the printer to be recognized by Word or is it another one? If you miss the bk upon the test sheet try to clean the ink cart by help of pressing ink arrow-down-button (cleaning) and (blue) start mono. If there is no or not enough ink check the cart. In case you use third party ones, use an original brother cart and do the cleaning twice. Third party carts do make a lot of trouble due to malconstruction!
Oct 10, 2007 | Brother MFC-5440CN All-In-One InkJet...
Brother problem
Did you use third party ink? If the ink is pigmented the filter in front of the printnozzels is clogged and cant be cleaned any more. What you can try is to buy a brand new original brother ink cart and do the cleaning 3 times. After that do a testsheet printing. In case its OK, your lucky and it was a problem of the cart. If you cant see any blocks (with the original ink used!!!) the printhead is crashed and has to be replaced (BTW: Its cheaper to buy a new mfc)! Do use only dye ink for brother printers!!!
Sep 10, 2007 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC 240C All-In-One InkJet Printer Logo
144 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
