Question about Craftsman 19 in Premium Battery Powered 3in1 Deck Lawn Mower
Am having a hard time trying to start my lawn mower
    President:
  • 3,433 Answers
Remove the spark plug, Make sure it is clean, then before putting it back in, wet the tip with clean freshfuel. Chk and clean the air filter. Make sure any shutoff on any remote controls on the handle is in the run position. Good Luck
Posted on May 28, 2010
Lawnmower Makes Squealing Sound when Self-Propell is Used
if you take it apart there will be no warranty . take it to where purchased and get it repaired
Jul 21, 2015 | Troy Bilt 5.5hp Self Propelled Mower
Briggs and Stratton 24hp lawn mower timing Mark problems how do I fix it?
The timing is fixed on the ignition side and the valves have dots on the gears
B&S motors have a history of stretching valve stems which means that when hot the motor is hard to start or refuses to start
If this is your problem then remove the valves and reset the valve clearance by about .002"
normally it only has to be done once as the stems will have stretched as far as they will
Mar 23, 2015 | Garden
Compression lockup
Remove spark plug. Pull rope several times to blow out cylinder. Spray WD 40 in spark plug hole. Pull rope several times. ensure compression is present. Replace spark plug with new one. Spray starting fluid in cylinder before replacing spark plug. Ensure plug wires snaps on tight. Check oil level, fill with 30w oil if required. All mowers have a low oil start cutoff. Clean or replace air filter.
Sep 10, 2012 | Toro Power Lawn Mower
Why is my Tecumseh 6.5 hp engine hard to start after taking blade off.?
When you tilt the mower too much oil will mix with gas. Try taking out the spark plug and cleaning it good in case some oil got on it. If this don't solve it, drain the gas and refill with fresh gas in case oil mixed with it when you tilted the mower.
Aug 04, 2012 | Tecumseh Lawn Boy Push Mowers Insight...
I have a 6.5 self propelled Lawnman by MTD . It will start but will not stay running.
is the handle hard to pull?or pull back at times?any way pull the flywheel off and check the key that aligns the crank and flywheel in time they shear when you hit rocks
May 08, 2012 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Toro choke doesn't work
try cleaning out the carburator.
May 23, 2017 | Toro Lawn Mower With Toro Power Tools
I have a brigs 6.75hp sometime it runs good and other times u cant get it started why
take carburator apart clean real well inlet line and all, it's not that hard to do!
Jun 06, 2010 | Briggs & Stratton Lawn-Boy Insight Series...
Lawnmower wont start
check your sparkplug clean or replace, also crank it several times without sparkplug in it to blow out the cylinder, did you have it on it's side for anything?
Jun 05, 2010 | Toro Lawnmower 20099 Mower Mowers Lawn
Mower motor hard to start
Make sure the choke is completely closed when trying to start. Many times this is the problem with hard starting.
Mar 31, 2009 | Garden
Craftsman 19 in Premium Battery Powered 3in1 Deck Lawn Mower Logo
108 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
