Question about Frigidaire ATF6000ES Front Load Washer
Washer wont finish a cycle it will go for about 5 min. click then start over what is causing it
  • 1,531 Answers
The unit should not start over but my suggestion is replace the door lock,first then if that does not solve it replace the control panel
Posted on May 28, 2010
Zanussi aquacycle 1200.After a wash has finished and i empty washing, reload again,it wont start and none of the lights come on.eventially it works ok again after a good 5-10 mins.
you have probably done no harm. try selecting spin and drain again to ensure the water has drained properly.
Machine starting on its own after 5 minutes or so is usually the door lock failing, again not caused by your actions.
Sep 05, 2016 | Zanussi Washing Machines
Lights keep flashing and door locks without finishing cycle
Kenmore HE2 Plus Front Load Washer Keeps unlocking ...
www.fixya.com > ... > HE2 > Kenmore HE2 Plus Front Load Washer
flashing prewash and add garment lights My HE2 Plus will fill with water, but when ...Kenmore HE3 2plus wont finish cycle Washer wont finish the last1 minute of cycle. ...We ran a load twice and it still did not unlock. du is the code for cannot ... Why does the door keep unlocking and locking in between the drum rotating?
Admiral, Whirlpool, Maytag - Washer Repair - Not ... - YouTube
? 5:51
https://www.youtube.com/watch?v=oBihToN6dxs
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your Admiral Top Load Washer that has these following symptoms: Not Completing all Cycles ...
Washing machines - Ariston
Jan 05, 2016 | Washing Machines
I'm not saying you don't have a problem. But just to be clear. You do understand that the last minutes on these machines can vary. The machine senses certain conditions in clothing, water discharge, etc. So sometimes the "1 min left" indication can stretch into many minutes. In theory, at least, it's possible your machine just needs to be left alone until it finishes whatever it's doing. However, one would think that any issues not resolved in 10 - 20 min are an indication of a problem. So i guess that's my next question, did you wait long enough? Keep in mind i am not a kenmore expert.
Jan 06, 2013 | Kenmore HE2 Plus Front Load Washer
When washer starts it usually makes a clicking noise know it is humming and nothing happens the door is locked and wont open
your main belt is broken or loose i would suspect the latter,the reason the door will not open is the machine has started a wash cycle and because the belt is not able to finish the cycle the door wont open so the progam is not finished,switch the machine of at the mains and the door will open after 10 mins.But the problem remains the belt.please rate this answer thanks.adrian,,,,,,,,,
Aug 23, 2010 | General Electric WCVH6800J Front Load...
My front load washer goes into pause two min after machine is started i have to press start for cycle to continue and sometimes it does it a second time press start again it will then finish cycle
you should check button start / pause the washing machine, if it is damaged you must replace it with a new one, the damage caused by the push button which is not connected properly.
Aug 11, 2010 | Frigidaire ATF6000ES Front Load Washer
Door stuck
try unplugging and plug back in to reset
Nov 17, 2009 | Hotpoint First Edition FEW12 Front Load...
GHW9100LW randomly stops during cycles, has a severe clicking noise
the water leaking back in may be due to a fill valve not fully shuting off allowing water to leak into washer after shut off...reclean pump ck as far as possible into pump itself something may be hung in impeller the shaking may be due to excess water in clothes causing off balance and shaking ..cleaning pump may solve problem..if possible pull pump completely out to clean ck pump impeller to be sure it has not come loose on motor shaft this would also cause slow or no pump out ..if impeller is loose replace pump..good luck
Nov 09, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite HE4t Washer - "Control Locked"
Press and hold 'dry' & 'spin', shd unlock OR
Try holding the "end of cycle" button down for 5 or 6 seconds. You must hv done it accidently, it is the child lock device. Pl. rate if helped.
Dec 29, 2007 | Kenmore Elite 45986 Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
70 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
