Question about Dell V505 All-In-One Printer
V505 Dell Printer Connected by USB
Dell V505 Hardware recognized by Computer. Even though USB is secure at both connections there is no communication link detected between computer and printer.
Any thoughts? Should I replace USB cable?
    Scholar:
  • 94 Answers
Try to check the USB in the device manager if did not disable. To goto device manager right click the My Computer on the screen and click properties. Dialogue box appears click on the Hardware and click Device Manager. Another dialogue box appear then just see at the bottom of the dialogue box if the Universal Serial Bus Controllers are did not have question mark (?) with yellow color. If don't have mark like that try to change your USB cable then insert it again to your printer. But if they have a mark like that you need to right click the Universal Serial Bus Controllers and click Update driver.
Posted on May 28, 2010
I am attempting to scan a document with my X4650 without success. The copy function works with no problems. I have used the scan function to my computer on numerous previous occassions without problems.
How is your printer connected to your computer, wireless or hardwired with a USB cable? If wireless, check the status of the WiFi light on the printer (green = connected to a network, orange = not connected to a network). Try to turn off/on your printer. Doing this usually fixes minor communication issues. This article in the Lexmark website might also help resolve your scan problem: No Communications Error When Trying to Print or Scan.
Apr 18, 2011 | Lexmark X4650 InkJet Printer
I got a used v505 printer i hooked it up and it will not communicate with the computer what am i doing wrong
Go online, google or Dell website, type in your Dell V505 drivers, download those driver and carefully install them to your computer while your printer is attached to the computer and ON. verify if they installed succesfully, test print from your computer to see if it works.
Dec 03, 2010 | Dell V505 All-In-One Printer
Computer says there is no communication with the printer
Couple of things to consider and try,,,have you tried another USB device in the computer, like a flash drive? If it can read the flash drive ok then the problem is not the USB port. Try using a different USB cable for the printer. Make sure your computer is up to date with the most current drivers. To me it sounds like a bad printer cable. Another thing to try is having the printer attached and when the error message comes up try wiggling the cable to see if communication is restored. If so then chances are that the printer cable is bad. Hope this helps.
Jul 22, 2010 | Dell Photo 964 All-In-One InkJet Printer
Printer not printing changed printer using same said wiring when i go print says no printer connected must select a printer even though it is a listed printer then it doesn't recognize the printer can't...
Please go to run and enter "devmgmt.msc" you will get device manager remove all of the USB driver from the device manager and click on Scan for hardware changes. It will install all of the USB drivers. After that connect the printer and install the software properly.
Jul 01, 2010 | Dell 922 All-In-One InkJet Printer
My ml 1610 printer says its not connected to my computer even though the cord is pluged into the usb port
Check the hardware and software settings first
1) Check the Hardware Connection -
a) Power connection to Printer
b) USB Connection from Printer to Computer
2) Checked the Drivers Software
a) XP/Vista = Open the device manager
Click Start - right click on My Computer
Click on Manage
Click on Device Manager
Click on (+) Ports COM & LPT and Check Printer is listed or not
or
Check for Printer Name (Samsung ML1610) is it listed under device manager
if YES - Check by printing the test Page
if NO - Install the Printer Drivers and then print the Test page
Jan 21, 2010 | Samsung ML 1610 Laser Printer
New Dell desktop can't recognize external hard drive
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especialy true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
Aug 28, 2009 | Dell Computers & Internet
Dell-All-in-One printer. Won't communicate with my
go to Dell websitr and downlowd the updared programs and driver for the All In one printer, the problem might not be your laptop, but your printer and the software having a connection issue. check with Dell.
Jul 21, 2009 | Office Equipment & Supplies
Port not recognized - printer and computer do not communicate
unplug printer ,shut down printer, shut down computer, then restart computer, and plug printer back in after computer is fully up and running turn printer back on
and that should solve the problem
Jul 20, 2009 | Lexmark X3650 Printer
Printer installation?
You will have to reload your printer. Plug the printer to your computer and reboot. The Plu and Play should recognize it. Then the Ad Hardware Wizard will pop up. Load the CD that came with the printer and the Wizard will allow you to load and configure the printer driver. Once the drivers are loaded you can print a test page. If it is a USB printer then load the drivers first, then plug your printer in and reboot.
Dec 24, 2008 | Canon MultiPASS C555 InkJet Printer
Dell V505 All-In-One Printer Logo
341 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
