Question about Freezers
We have a GE 20.3 cu. ft. upright frost free freezer that keeps forming a layer of ice on the bottom, which we assume is happening when it is defrosting. How do we unclog the drain?
  • 8,220 Answers
I let the ice box thaw out and use a shop vac to open the drain hole. You can find the end of the drain hose above the compressor drain pan.
Posted on May 28, 2010
Upright freezer not freezing food and ice forming on back wall
is the top of the freezer full where it can breathe remove something to help it breathe
Sep 10, 2012 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Ice keeps forming on the bottom of my freezer
Your kemore self defrost is not working. 1. clean the ice and look for the heater element and your lemi switch.
Sep 01, 2012 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Ice forms at the bottom very solidly Model: Maytag MQU1656BEW 15.7 cu. ft. Upright Freezer with auto defrust
check for a bad/ loose/dirty gasket on the bottom side ofn the door. check your drainage line for clogging on the defrost system for back up
Jul 20, 2011 | Maytag 20 cu. ft. Upright Freezer MQU2056B
Ice in bottom of frost free whirlpool freezer
Most likely the drain (located behind the lower panel rear wall) is obstructed. You will want to clear out the ice build up and use a turkey baster with hot water to clear the frozen drain tube.
Jun 12, 2010 | Whirlpool 20 cu. ft. / 566 liter Upright...
20.3 cu. ft. Upright Freezer GLFU2067F: We have an upright frigidaire 20 cu feet that is a...
Sounds like frost bulidup from door being left open warm air gets in making frost and ice. Need to turn off for 24hrs or so to let all the ice melt compleatey then turn back on keep door closed run for 24hrs check Temp. shoud be about 0 to -5 Deg. if good start using.
May 17, 2010 | Frigidaire 20.3 cu. ft. Upright Freezer...
Water on floor temperature rising
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Apr 15, 2010 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezer forming Ice on the bottom not draining water
pour some hot water in the drain if this does not work use compressed air
Aug 23, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Sears Coldspot 17 frostless freezer not defrosting
One reason for the fan running is that it is trying to distribute the air in the compartment. Look at the very rear of the freezer on the bottom and see if the little vents, which allow water to disperse, are not filled with frozen ice. If so, turn off the fridge (unplug it) and use a hair dryer to melt that ice until it is all gone. That will probably fill the condensation pan under the unit and you'll need to empty it.
Feb 01, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Ice build-up
Defected DEFROST HEATER can cause frost build up on the panel at the back of the freezer,and freezer stop cooling and ice frozen on unit so air could not flow to refrigerator side.Water will coming out caused of unbalanced freezing,and causing the flooding of water in the floor. You must change this defroster heater assembly so it will works normal again..
Hope this may help;
Regards,
VOTIT
Sep 22, 2008 | Frigidaire 20 cu. ft. / 566 liter Upright...
Frost free freezer smells like fish
IF THERE WAS A LAYER OF ICE ON THE BOTTOM OF THE FREEZER, THE DRAIN IS PROBABLY PLUGGED UP. IT WILL NEED TO BE CLEARED BEFORE PUTTING BACK INTO SERVICE OR IT WILL JUST DRAIN INTO THE FLOOR OF THE FREEZER AGAIN. AS FAR AS THE ODOR, TRY PUTTING CHARCOAL IN IT TO ABSORB THE ODORS. IT WILL HAVE TO BE LEFT IN THERE FOR QUITE A WHILE. WHEN THE FREEZER IS CHILLED, IT WILL LESSEN THE SEVERITY OF THE ODOR. IF THAT IS UNACCEPTABLE, THERE ARE COMMERCIAL ODOR NEUTALIZERS ON THE MARKET YOU CAN USE.
Mar 30, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezers Logo
190 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
