Question about Eclipse Car Audio & Video
How to remove the dash mounted AVN2203D DVD/GPS unit from a Japanese assembled 2003 Ford Escape. No manual is provided.
  • welcome933 May 29, 2010
    More specific detail of the special DIN tool used by Ford to remove audio/DVD sets is requested.if a DIN tol is not readily aavaialbel can I construct one ? Anyone have a design. Anyone have an English manual for an Eclipse AVN2203D unit?
  • 4,924 Answers
Http://www.autodvdgps.com/blog/?p=1048
here is a link for another car ..with a in-dash unit..and I linked it just to make an idea...
If it do not have any visible screws or other ..you will have to remove the dash itself cause the unit may have a system that it is joined by the back ...Most of them though are just snap clicked in ..and you will have to use a plastic tool like a flat screwdriver ..to insert at the side and see the points where it is snapped on ..and get it from a side to the other ...inch by inch ..after that will slide out ..
remember if it do not want to ...do not force ..cause it may have a safety system on the bach ..and it have to be removed the whole dash ..
Posted on May 28, 2010
  • Catalin Turcu
    Catalin Turcu May 29, 2010
    that tool it is just like a flat head one inch wide slightly bent for a lever effect ..and it is not necessary to be the original stuff..just something you have in handy will do ..The idea is to open the snap clicks points..they are on a 4 inch distance apart ..and this tool will make it easier to open them ..without damaging the frame..
    they are available for sell in all tool stores..even some markets I sow they had some kinda tools like that ..
  • Catalin Turcu
    or maybe you was referring on this u shaped tool for removing cd unit..
    http://cgi.ebay.com/FORD-VW-MAZDA-SAAB-S...
    President:
  • 1,561 Answers
Disconnect the battery to avoid an electrical short while working with the wiring.
Use a screwdriver to remove the retaining screws holding in your car DVD/GPS unit. Grab hold of the stereo and pull it toward you to remove it from the dashboard.
Get a pair of DIN tools to slip on either side of the DVD/GPS unit, if the DVD/GPS unit connects to the dash using spring clips and bolts. These thin tools slide in easily, release the clips, and allow the DVD/GPS unit to come out easily. You may need to remove dash panels when bolts hold in the DVD/GPS unit. Take out the bolts and screws that hold the DVD/GPS unit in, and then simply pull it out.
Look at the wires on the back of your car DVD/GPS unit. You should see 2 wires attached to the stereo. A wiring clip protect the DVD/GPS unit from vibrations and holds the wiring harness steady.
Pry the wires up from the DVD/GPS unit and loosen them using a pulling/pushing motion. After working the wires back and forth, you should be able to pull the wires straight out.
That is the procedure on how to remove DVD/GPS unit from your dash board.
Take care.
Posted on May 29, 2010
  • Sulaimon Jimoh Olayemi May 29, 2010
    Follow the link below to see the diagrams of a DIN tool, you can construct one with the provision of this diagram, this link should guide you on how it will look and fits to remove the dvd sterio.
    http://images.google.com/images?hl=de&am...
    Take care.
    Thanks for that help.
    Don't seem to have retaining screws but will try to "construct' a pair of DIN tools to release the 4 spring clips that appear to hold the unit in it's frame.
    Ideally I would like to source an operational instruction manual for the unit (AVN2203D) that is in English. Any leads ??
Heater core replacement on a 2003 ford sport trac
the complete climate control assembly unit is required to be removed in order to remove the heater core. The climate control assembly is attached by studs & nuts which are accessible at the firewall in the engine compartment. The R134 refrigerant will need to be evacuated and the a/c lines at the expansion valve removed in order to remove the climate unit. Hope this helps. :)
Jan 21, 2014 | 2003 Ford Explorer Sport Trac
Eclipse avn2203d
I recommend you download from the manufacturer supplier from GPS. see your owner manual and go to the website. or searh in Internet with : Altavista, yahoo, lycos, bing, etc.
God bless you
Jul 30, 2013 | Car Audio & Video
Headlight went out in 2003 ford escape i have
you have to remove the whole headlight assembly, then pop off the front cover pull the old bulb out and put the new one in. reverse the process to re-install. there is a small plastic tab on the topfront of the headlight assembly, that is what you need to release to get the clear cover off and get inside.
Sep 02, 2009 | 2003 Ford Escape
How do you replace a power steering fluid pump on a 2003 ford escape? It looks like its internal and I may have to pull the motor? please help!
it is directly under the upper engine mount on the passenger side. simply block up the engine from underneath and remove the upper engine mount (5 - 18mm bolts)
Jul 13, 2009 | 2003 Ford Escape
The dash light will not come on in my 2003 Ford Escape
CHECK FOR FUSES IN OWNER MANUAL,SHOULD BE 2 BULBS SO THEY COULDNT WENT OUT SAME TIME.
May 08, 2009 | 2003 Ford Escape
On an 05 escape there appear to be only 2 screws holding the brake light cover. I've taken them off but the cover seems really secure along the outer edge and the body panel. I'm if I give it a good yank...
here is 2003. I don't have 2005. SHould be similar. Please rate as fixed if this helps.
SECTION 417-01: Exterior Lighting 2003 Escape Workshop Manual
REMOVAL AND INSTALLATION Rear Lamp Assembly Removal and Installation
  1. Remove the rear lamp assembly.
    1. Remove the bolts.
    1. Pull straight back to remove the rear lamp assembly.
  2. Disconnect the electrical connectors.
Apr 28, 2009 | 2005 Ford Escape
Need to replace head lamps on Ford Escape 2001,
there are 4 bolts that hold lamp in. the first 2 are obious. the others are behind the front bumper..the bumper must be removed to expose them...here is a cpoy of the manual to change..good luck
Headlamp Assembly Removal and Installation
  1. NOTE: Make sure that the headlamp switch and the ignition switch are in the OFF position.
    Remove the front bumper cover. For additional information, refer to Section 501-19.
  1. NOTE: Pull headlamp assembly forward to access electrical connectors.
    Remove the headlamp assembly.
    1. Remove the three bolts.
    1. Loosen the nut.
    • Disconnect the electrical connectors.
  1. To install, reverse the removal procedure.
    • If necessary, adjust the headlamps. For additional information, refer to Headlamp Adjustment in this section.
Apr 22, 2009 | 2003 Ford Escape
Need to replace headlight assembly on 2005 Ford Escape
ithere are 4 bolts that hold it in...the top 2 are obvious..the others are behind the bumper. the bumper must be removed to acces them...here are the manuals instructions..
Item Part Number Description 1 — Headlamp assembly bolts (3 required) 2 — Headlamp assembly nut 3 13008 Headlamp assembly 4 14290 Electrical connectors
NOTE: Make sure the headlamp switch and the ignition switch are in the OFF position.
  1. Remove the front bumper cover. For additional information, refer to Section 501-19.
  1. Remove the 3 headlamp assembly bolts.
    • To install, tighten to 5 Nm (44 lb-in).
  1. Remove the headlamp assembly nut and the headlamp assembly.
Jan 01, 2009 | 2005 Ford Escape
Front brake disc and pad replacement
has long has you check that fluid and bleed the lines to avoid air pockets . make sure you apply that sqeek prevent on the back of the shoes r u will be bothered by the sqeek later.
Jun 04, 2008 | 2003 Ford Escape
Car Audio & Video Logo
263 people viewed this question
Top Eclipse Car Audio & Video Experts
xxxxxx xxx
Are you an Eclipse Car Audio and Video Expert? Answer questions, earn points and help others
