Question about Pool & Spa
Something going on in either the drive belt or transmission belt area; The mower still drives but there is a hard knocking/thumping and you can feel it when you food is touching the brake pedal. Its a MTD model 13AM675G205. Its called Ranch King it has a 14.5hp Briggs & Stratton and has speeds 1 thru 7 and the tranny is 3 position FWD, N, REV; Like something has broke or came loose? IT DOES IT WHEN THE TRANNY IS IN NEUTRAL BUT THE SPEED IS ON ANY SETTING EXCEPT PARK. SO MAYBE ITS THE VARIABLE SPEED BELT, BRACKET; OR SOMETHING IN THAT ASSEMBLY. I AM AN INTERMEDIATE MECHANIC AND I MY CONFIDENCE LEVEL HAS INCREASED OVER RECENT YEARS; BUT I WOULD LIKE TO SEE IF SOMEONE MIGHT ZERO IN ON THIS WITH THE SYMPTOMS I'VE DESCRIBED; I DON'T THINK A BELT IS BROKE; BUT MAYBE A SPRING OR BRACKET HAS CAME LOOSE OR BUSTED; ITS CREATING A HARD THUMPING/KNOCKING AND IT EVEN JARS THE WHOLE BELT AND PULLEY ASSEMBLY WHEN IT DOES IT.
  • 333 Answers
It sounds to me like it may be a chunk missing out of your belt. Or warped pulley.
I dont think that it would be a broken spring because it would make the belt slip. Does it do it the same no matter how fast you are going?
But no matter what it is, if you start taking it apart. It should be easy to find. If its not the belts you can jack the rear wheels up take the belts off and work the pulleys and or wheels til you find it.
Posted on May 28, 2010
Transmission make loud sound when put it in revers
PLEASE HELP! SOS! car starts but doesnt move! - Club3G Forum ...
www.club3g.com > ... > Performance & Tech Forums > Problem Reports
Nov 16, 2010 - 61 posts - ‎14 authors
now yes, i will take the transmission is fubar into consideration but theres an .....however... idk about my cv joint, my car ONLY would make a loud ping noise when i move from a stop or brake ..... almost always when i put it into reverse. such as an engine mount sound, ... Vehicle: 2004 Eclipse Spyder GT. Loud knocking sound after oil change..
Sep 20, 2010
Horrible noise upon start when cold
Dec 24, 2009
Sporty knocking.. Oh noez!!one!!1!
Mar 22, 2006
More results from www.club3g.com
Loud thump when I shift into drive or reverse - CarGurus
www.cargurus.com > Questions > Chevrolet > Cavalier
CarGurusDec 19, 2012 - And while driving loud thump when car motor shifts th... ... Bad throttle position sensor can trip both lights and make the transmission shift at high rpms and shift hard even under light acceleration. .... the transmission will shift hard when firstput into reverse or drive ... 2004 Chevrolet Cavalier LS For Sale.Missing: mitsubishi ‎eclipse
Mitsubishi Transmissions & Drivetrains Repair Questions ...
Dec 06, 2015 | 2004 Mitsubishi Eclipse
How do I diagnose a noise from the tranny of an atv? I can feel it. knocking noise most apparent in high gear
Check the drive belt. Had this once on a Ranger and a piece of the vari-speed drive belt had come away from rest of belt and was thumping against the cover (LH side of engine) If that's ok check all the axle universal joints.
Nov 02, 2014 | Polaris ATV
Why did Craftsman LT2000 stopped moving? Engine starts and blade engages fine.
The transmission drive belt is a separate one from the blade belt. The clutch pedal when released puts tension on the transmission drive belt so it tightens up and drives the gearbox pulley by way of a large spring. Make sure the spring is ok. The belts don't last forever and probably needs replacing looking at the age of the machine. That is a fun job as it is right up under the machine and runs from the engine pulley right back to the top of the transmission. You have to drop the deck right off and I usually find a tree with a large branch and haul the front up with a rope or winch so the mower is vertical. Makes it easier to work on. Drain petrol first though. Hope this helps otherwise get a mower shop to do it for you if you feel it's to much of a task. Good luck.
May 19, 2014 | Craftsman Garden
Removed the deck on my Poulan pro to replace the sheared pins on the broken spindle. Now the mower wont go into gear?
You might have knocked the drive belt off while removing the deck/belt? what kind of transmission do you have 6 speed manual or an automatic?
May 16, 2014 | Mtd Garden
Transmission wont engauge
You have probably knocked off or stretched the drive belt, the drive pulleys or or the linkages off the transmission lever.
Nov 17, 2013 | Snapper Garden
Loud knocking sound
They did not hear the noise or did they not drive the truck ?
It could be something in the brake system too.
Jul 24, 2012 | Chevrolet Suburban Cars & Trucks
My husqvarna mower has quit moving. The engine runs smoothly but when I shift out of neutral, nothing happens. It stopped working suddenly. I have moved the small lever in the back that allows you to...
either the drive belt from the engine to the top of the transmission has broken or gone slack due to a tensioner issue, or the transmission has failed. with the engine NOT running you can put your hand up under the deck and feel the topmost belt, if it is there and snug, then you have a transmission problem and that requires a replacement.
May 25, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
My riding mower stopped forward and reverse movement every once in a while..then it stopped completely. the engine is running fine and the throttle parts move when the pedal is pressed
Check the main drive belt. Without knowing your specific model and brand, its hard to be more detailed than that. Almost all riders have a main belt. When you look under your mower, there are usually two belts that come off of the drive shaft of the engine. One drives the mower deck and one drives the transmission for your mower. The way your mower "stopped forward and reverse movement every once in a while" tells me your belt developed a bad spot, then completely let go. Also, many mower companies host a website for their products. You can find your model's owners manuals, parts lists, and diagrams, to help you fix the mower yourself, which I highly recommend, if you are able. Shops in my area charge around $150.00 to $200.00 dollars to change a main belt.
Aug 22, 2009 | Garden
Husqvarna YTH2348 drive belt slipping
Is there the proper amount of tension on the belt?Look in your owner's manual to find out how to adjust the tension.
Aug 02, 2009 | Garden
Pool & Spa Logo
114 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
