Question about LG DLE2514 Electric Dryer
Dryer works fine . other than a thumping noise. and a large stress crack in the drum near the front. getting worse.
  • LG Master
  • 43,501 Answers
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
yuuri
Posted on Sep 29, 2010
Dryer makes lots of noise when drying..squeaky ans sometimes a "thump"
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Dec 07, 2010 | Kenmore 64882 Electric Dryer
Dryer makes a clunking noise while drying. Is it possible that the drum is "Out of balance"?
Most likely if it is a thump thump noise a drum roller has a flat spot and is causing the noise.
The dryer will operate ok but it will be loud.
A service call may be needed to replace all 4 drum rollers.
Jan 06, 2010 | LG DLE2532W Electric Dryer
LG DLE2514w electric dryer has loud thud every turn
Most model dryers are supported at thge rear of the drum with a bearing configuration, but usually the front of the drum is supported by some lining pads or guides. These help hold the rotation of the drum concentric. It sounds like your drum is not spinning concentric. My guess would be that some new guides might need to be installed.
Hope this helps...
Sep 02, 2009 | LG DLE2514 Electric Dryer
Frigidaire Dryer making loud thumping noise in back.
Some things to check.
Worn rear drum rollers, idler pulley, or drum front slide kit.
Click here for illustrations.
Hope this helps.
Aug 12, 2009 | Frigidaire GLEQ2152ES Electric Dryer
I have a thumping noise as the dryer runs, but it seems to work fine.
Look closely at the seam of the dryer drum, at the very front and the very back. I suspect that the seam has developed a crack, and makes a thumping noise each time the crack passes over the drum support rollers. You will have to replace the drum to eliminate the problem
Jun 28, 2009 | LG DLE5977 Electric Dryer
LGR7648KQ1 model, dosen't seemd to have in lint in
The thumping noise is a stress crack from poor construction when thr drum was made. I have the exact same problem and found the crack when I removed the top cover by removing the rear upper brace support screws and bracket, then sliding the top dryer panel towards the rear about 3.5" and then lifting it off for complete drum inspection. Rotate the drum by hand and you will see the crack...Mine is at the front, next to the drum seam.... We should all get together and file a class action suit...I'm sure this is a manufacturer fault related problem with this model..
The crack is probably allowing air to bypass the normal air flow through the filter too... Richard
Jun 27, 2009 | Whirlpool Dryers
Dryer thumps when running, clothes get stuck...
It always helps if you list the brand and model number in your post. I would look at the seam on the drum to see if the weld has cracked. (right at the front and / or rear of the seam.)
Jun 10, 2009 | Dryers
LG DLE3777W dryer thumps when running . It sounds like there are tennis shoes in the drum.
Probable cause is the bearing on the wheel that turns the drum is worn out. They are easy to replace and should cost less than $25. for the part.
Remove the front of the dryer and turn the drum by hand, you should be able to tell which side is worn.
Be sure and unplug first.
Mar 16, 2009 | LG DLE3777 Electric Dryer
Lg Gas dryer Dlg0332w drum making noise
The drum on my DLG0332W was also making noise at the back of the dryer...kind of a thump thump thump as the drum rotated. My dryer is only 4 years old. I got brave, downloaded the service manual and opened up the dryer. I found that the drum's welded seam was starting to separate where the roller wheels were coming into contact with the drum at the back of the dryer. Looks like a new drum is in order.
Mar 01, 2009 | LG DLE2532W Electric Dryer
Lumpy drum noise
Did you remove the shipping bolts from the back of the machine
Mar 26, 2008 | Maytag MDE9700AYW Neptune 174 Electric...
LG DLE2514 Electric Dryer Logo
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a LG Dryer Expert? Answer questions, earn points and help others
