Question about Car Audio & Video
What dimension should a vented sub box be for a single MTX RT 840 sub (Road Thunder 8'')? What dimensions should the port be?
  • 94 Answers
Only spec i could find is .4 cubit ft
Posted on Jun 07, 2010
8 INCH MTX ROAD THUNDER SUBWOOFER WON'T WORK NO SOUND NO NOTHING
has it ever worked, if so did you ever use it in the cold because in the cold it is possible for the wiring inside the speaker to crack and break
Oct 29, 2012 | Velodyne CT-80 Subwoofer
Hi i have a 15"w3-d4 jl audio sub,can anyone tell me what size antype box i should use ie sealed or ported and the box dimensions
I've had a look at the JLaudio website and they recommend 2 box designs, a ported and a sealed.
The sealed box needs a volume of:
2.125 ft3 or 60.2 litres.
To get this you would need to build the box to these dimensions:
22" x 16" x 14.75" or 559mm x 406mm x 375mm
The ported box needs a volume of:
3.50 ft3 or 99.1 litres.
24" x 19" x 18" or 610mm x 483mm x 457mm.
The port needs to be:
3.0" x 10.9" or 76mm x 277mm.
The enclosure recommendations listed above are external dimensions which assume the use of 3/4" (19mm) thick material. If you are using 5/8" (16mm) thick material, subtract 1/4" (6.5mm) from each dimension. Do not use any material with a thickness of less than 5/8" (16mm) as this may compromise the rigidity of the enclosure.
• All enclosure volumes listed above are net internal volumes! Driver displacement, port displacement and brace displacement must be added to obtain the final gross internal volume. All enclosure dimensions above have already taken this into acount.
• When using two subwoofers in a common enclosure simply double the required volume and, in the case of a ported enclosure, use two times the recommended port(s). Likewise, when using three subwoofers in a common enclosure simply triple the required volume and, in the case of a ported enclosure, use three times the recommended port(s).
• We recommend the use of this speaker in a bi-amplified system using high-quality satellite speakers and a high-quality amplifier. We do not recommend the use of this subwoofer with a passive crossover (coil), as this type of device will adversely affect performance.
As you can see it all depends on the space you have available, whilst the vented box will give you a more efficient bass responce especially with the low range frequencies.
If you to go and look at the information about your sub woofer and find out all the information about building or buying the correct enclosure then this is the link to the pdf file I found:
The enclosure info is on page 3:
JL AUDIO 15W3 Tech Specs and box info.
Warm regards
Mike
Oct 12, 2010 | Jl Audio 15W3-D4 Car Subwoofer
I have a mtx thunder 7801 and a sledge hammer box
Sounds like the subs are blown with the voicecoils fused together which means the amp is/was seeing a dead short ( zero Ohms reisitence) not good for any amp. Disconnect the speaker terminals from the amp and see if it turns on. The funny smell might have been the subs blowing up, i'll keep my fingers crossed for you.
Feb 28, 2010 | MTX Car Audio & Video
1501d,, What subs should i use/
I would stick with Kicker or MTX. The best place in my mind to get them is soncelectronix.com
Just try to mach the specs as close as possible. Make sure to look at the recommendations of the subs for the size of the box and the port volume.
Oct 11, 2009 | MTX Thunder 1501D Car Audio Amplifier
Rotten foam rubbers
You can have "The Speaker Factory" re cone them. Call for an est.first Generally gonna be less expensive to replace.
Jun 25, 2009 | MTX Road Thunder RT-1240 Car Subwoofer
Box dimensions for 15 in cerwin vega
do you want the box ported or unported (holes or no holes) if you don't got a lot of room than you dont want a ported box. keep in mind the box has to have the correct amount of cubic air space or you could seize your sub... if you're building it make sure you use OSB board (oriented strand board) or MDF board(medium density fiber) your sub needs .7cubic feet of air space in an unported box
Feb 14, 2009 | Cerwin Vega IT-15.0 Car Subwoofer
The best bass in this case
HERE is the owners manual for your sub.
If looking for LOUD, ported enclosure is the way to go.
If looking for accuracy, build sealed.
You dont have enough depth for an isobaric setup.
using the maximum dimensions given, 8x13x41, the volume of the biggest enclosure you could make (assuming 3/4" MDF material) is 1.7cu ft.
To tune this 1.7cuft box around 50Hz, you need (1) 4" round port 5" long.
MTX recommends an enclosure of 2cuFt ea. You will only be able to use 1 subwoofer in this application.
Even a sealed enclosure is recommended 1.25cuFt.
You can shove 2 in the vented enclosure, but you may not be happy with the outcome.
Thanks for using FixYa - A Fixya Rating is appreciated!!
Jan 27, 2009 | Car Audio & Video
Box dimensions
I've Got The Same Subs, I Got A Formula On The Net, Its Dimension Is Aprox 9 D X 24 H x15 W.
Although I Have Them In A Home Made Ported Box I've Made, Its Dimensions Are 8 D X 23 H X 17 W And Its Sound Pretty Damn Good. I Have A 2 Inch Round Port X 6 Inch Long. The Formula Says I Should Have A 3 Inch Long Tube.
Feb 23, 2008 | Volfenhag ZX-4712 Car Subwoofer
Car Audio & Video Logo
79 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
