Question about Dell PowerEdge 1800 Server
At Startup I get the message: 'Service Control Manager - At least one service or driver failed during system startup. Use event viewer to examine the event log for details.' Everything boots up fine, but the 'external lan' has a red 'X' and I cannot access the internet or receive e-mail. However I do get junkmail
  • 355 Answers
I would uninstall the external lan driver and the go to dell website (on another PC if you have to )and get the latest update for that lan card. a good easy starting point.
Posted on Jun 07, 2010
Have error with 4600 loading descriptor 1 ...done on startup. Can't figure out why
If you want to know what this is the error code is related to
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured Right click on the error message select properties you will see all details about the error or click start type in event viewer press ENTER you might be able work your way through the problem
Jan 03, 2013 | Dell Dimension 4600 PC Desktop
In dg41wv server 2003 is not loading
problems in Windows Server 2003
To start the computer by using Last Known Good Configuration, follow these steps:
Click Start, and then click Shut Down.
Click Restart, and then click OK.
When you see the message Please select the operating system to start, press the F8 key.
Use the arrow keys to select Last Known Good Configuration, and then press Enter.
Collapse this imageExpand this image
Note NUM LOCK must be off before the arrow keys on the numeric keypad will function.
If you are running other operating systems on the computer, click Microsoft Windows Server 2003 on the list, and then press Enter.
Notes
By selecting Last Known Good Configuration, you can recover from problems such as a newly added driver that may be incorrect for your hardware.
This feature does not solve problems caused by corrupted or missing drivers or files.
When you select Last Known Good Configuration, only the information in the following registry key is restored:
HKLM\System\CurrentControlSet
Any changes that you have made in other registry keys remain.
If you can start your computer by using the Last Known Good Configuration feature, the last change that you made to the computer (for example, the installation of a driver) may be the cause of the incorrect startup behavior.
if this fails to fix the problem try to repair in safe mode
How to start the computer in safe mode
When you start the computer in safe mode, Windows loads only the drivers and computer services that you need.
You can use safe mode when you have to identify and resolve problems that are caused by faulty drivers, programs, or services that start automatically.
If the computer starts successfully in safe mode but it does not start in normal mode, the computer may have a conflict with the hardware settings or the resources. There may be incompatibilities with programs, services, or drivers, or there may be registry damage. In safe mode, you can disable or remove a program, service, or device driver that may prevent the computer from starting correctly.
To troubleshoot startup problems in safe mode, follow these steps:
When you see the message Please select the operating system to start, press F8.
On the Windows Advanced Option Menu, use the arrow keys to select Safe Mode, and then press Enter.
Note Num Lock must be off before the arrow keys on the numeric keypad will function.
Do one of the following:
If the computer does not start in safe mode, try starting the computer by using the Recovery Console. If you still cannot start the computer, look for possible hardware problems, such as defective devices, installation problems, cabling problems, or connector problems. Remove any hardware that was added recently, and then restart the computer to see if the problem is resolved.
If the computer starts in safe mode, go to the next section to continue to troubleshoot the startup issue.
Use Event Viewer to identify the cause of the startup problem
View the event logs in Event Viewer for information that can help you identify and diagnose the cause of the startup problem.
To view events that are recorded in the event logs, follow these steps
Click Start, point to Administrative Tools, and then click Event Viewer.
Start the Event Viewer snap-in in Microsoft Management Console (MMC).
In the console tree, expand Event Viewer, and then click the log that you want to view. For example, click System log or Application log.
In the details pane, double-click the event that you want to view.
To copy the details of the event, click Copy, open a new document in the program in which you want to paste the event (for example, Microsoft Word), and then click Paste on the Edit menu.
To view the description of the previous event or the next event, press the UP ARROW key or the DOWN ARROW key.
Use this tool to help identify possible problem devices and device conflicts.
To do this, follow these steps.
click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occurred
hope this helps
Sep 01, 2012 | INTEL - MOTHERBOARDS Dg41wv Uatx Intel Gma...
My A305-S6857 freeze every time when I tried to login. I cannot access to my desktop.
Try doing a startup repair by pressing F8 repeatedly on startup. On the options menu, choose 'repair my computer'. If this isn't successful you can try running your antivirus software in safe mode to check for any infections. Press F8 as before and choose safe mode. If this works, you can also check your event viewer to see if there are any system errors recorded: control panel>system and security>administrative tools>event viewer. Expand the critical and error menus under 'summary of administrative events' You can double click on an event for further detail and the event ID which may help you troubleshoot the problem further.
Apr 03, 2012 | Toshiba Satellite A305-S6857 Laptop
I have an HP 3210 printer and Windows XP. Whenever I start my PC I get a message from Document Viewer asking me to install it from a removable disk. I can't find the disk.
Diagnostic startupDiagnostic startup enables Windows to determine the basic device drivers and software to load when you start Windows. When you use this method, the system temporarily disables Microsoft services such as Networking, Plug and Play, Event Logging, and Error Reporting. Also, you permanently delete all restore points for the System Restore utility.
Note Do not use this method if you want to save your restore points for System Restore or if you must use a Microsoft service to test a problem.
To perform a diagnostic startup, follow these steps:
  1. Click Start, click Run, type msconfig, and then click OK.
  2. On the General tab, click Diagnostic Startup, and then click OK.
  3. Restart your computer.
If the problem does not occur, use Selective startup mode to try to find the problem by turning individual services and startup programs on or off. Selective startupSelective startup enables you to select the files and the settings that you want the computer to load when you restart the computer. Select from the following options:
  • Process System.ini File
  • Process Win.ini file
  • Load System Services
  • Load Startup Items
By default, no options are selected. The following actions apply to these options:
  • When you select the check box, the configuration file is processed when you restart the computer.
  • When you clear the check box, the configuration file is not processed when you restart the computer.
  • When the check box is selected, and you cannot select the check box because it appears dimmed, some items are still loading from that configuration file when you restart the computer.
  • When the check box is not selected, and you cannot select the check box because it appears dimmed, the configuration file is not present on the computer.
  • You cannot change the Use Original BOOT.INI option button.
Note When you clear the Load System Services check box, you disable Microsoft services such as Networking, Plug and Play, Event Logging, and Error Reporting. You also permanently delete all restore points for the System Restore utility. Do not clear this check box if you want to keep your restore points for System Restore, or if you have to use a Microsoft service to test a problem.
To perform a selective startup, follow these steps:
  2. On the General tab, click Selective Startup.
  3. Select or clear the available settings.
  4. Click OK.
  5. Restart your computer.
  6. Repeat steps 1 through 5 until you find the problem.
Nov 04, 2010 | HP Photosmart 3210 All-In-One InkJet...
How we can remove active directory in windows 2003 safe mode ?
hello,
you just try to remove as force.
go to run, after this type " dcpromo /forceremoval ".
it will do this for you, if any issue on active directory or ad database.
you can do this command in normal or safe mode.
thanks,
Apr 25, 2010 | Microsoft Windows Server 2003 Enterprise...
Failed to connect services
For the Service in Vista:
Boot into Safe Mode.
Control Panel> Administrative Tools> Services> right click on System Event Notification Service> set startup mode to Automatic. Do NOT attempt to start the Service.
Make sure the Event Log Service is also on Automatic.
Reboot into Normal Mode. The Service should be started.
For the Event Viewer in Vista:
http://www.windowsnetworking.com/art...ows-Vista.html
Please observe the same guidelines for reporting: ignore Warnings, only one copy of recurring identical error.
Nov 04, 2009 | Compaq Presario 700 470024-192 Notebook
Window startup error
Looks like a spyware or an invalid application running with errors in the back ground.
You can access Event Viewer by selecting Start, Control Panel,
Administrative Tools, and Event Viewer. When researching the meaning
of the error, information regarding Event ID, Source and Description
are important.
or try running a spyware scan to get that out of the machine.
Thanks
Fame !
May 05, 2009 | Ahead Software Nero 6.0 (60045) for PC
Asus 5pe-hdmi mb = Q6300 Dual Core - 450W PSU
try checking out in safe mode.does it reboots in that also.
Mar 23, 2009 | ASUS P5PE-VM Motherboard
The Realtek EAPPkt Protocol Service failed to start
Try this..1.Try to uninstall the USB adapter and re install it again. To do this go to Add/Remove Programs under Control Panel and find the usb adapter your install in this case its Alfa Wireless USB Adapter and uninstall it and restart your computer after uninstallation. 2. Remove the USB adapter while restarting and insert it again until windows already loaded and all windows startup program have all been started.
3. System will look for the system driver of USB adapter and it will prompt you for the driver location in this window do not choose the recomended instead click browse and locate the driver cd and look for driver folder and select the applicable driver for your operating system such as WinXP if your using XP.
4. If there is no driver folder in cd, go to my computer, explore cd and run setup or install this will install the pending driver installation.
Nov 19, 2008 | Computers & Internet
SCREEN GOES WHITE AFTER A LITTLE WHILE...
Service Control Manager >> this defines a currently running service or a service that is attempting to run but cannot get stared.. simply hold CTRL + ALT and PRESS DEL the taskmager will popup and then click prosesses,, all these are services..
GUID-555908D1-A6D7-4695-8E1E-26931D2012F4
general user identification of the service
EventID Qualifiers="49152">7026</EventID
the event or situation it is trapping or handling,
Data Name="param1">cdrom - parameter 1 = cd rom
So basically they are saying its your cd driver, or your cd rom driver...
To fix this you need to scan your registery for errors using a registery repait tool such as tune up utilities..
if that dont work you will need to format and reinstall
Jan 05, 2008 | Microsoft Windows Vista Ultimate Edition
Dell PowerEdge 1800 Server Logo
145 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
