Question about Brother MFC-8460N All-In-One Printer
My MFC 8460N is showing "Document Jam, Clear scanner jam, then press STOP key." So, I checked the scanner feed and opened the scanner lid to check for any paper jams but didn't find anything. Ran some sheets through the feeder and it just keeps giving me the same error message above. Turned off the machine last night and just turned it on. Same message. This is a refurb from a previous warranty request. Is there any other solutions before I contact warranty service?
  • 10,515 Answers
If the machine is under warranty, we would follow what is explained by Brother for the same Error Message.
Take a look at :-
http://welcome.solutions.brother.com/BSC/public/eu/gb/en/faq/faq/000000/000600/000094/faq000694_006.html?reg=eu&c=gb&lang=en&prod=mfc8460n_all
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on May 28, 2010
An error is displayed that clear scanner jam.
Check the Paper Sensor on the ADF. If it is stuck, a Document Jam Error will occur because the scanner will attempt to feed documents when there are none. The sensor I'm speaking of is a black plastic lever that sits in a slot to the right of the feed roller. It should stick up through the slot (3/4 inch) and spring back if depressed and released.
Nov 24, 2010 | Brother MFC-8460N All-In-One Printer
It says there is a document jam and to clear scanner but there is not paper in the machine. What do I do?
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Nov 09, 2010 | Brother MFC-8460N All-In-One Printer
Overheats when printing pictures on transfer paper and now it will not print anything.
hi
i have problem with my brother prinetr MFC-8460N
IT SHOWS DOCUMENT JAM
ALSO MESSAGE ON SCREN
CLEAR THE SCANNER JAM THEN PRESS THE STOP KEY
STATUS SHOWS RED LIGHT
WE ARE NOT USING SCANNER WE ONLY USE FAX AND COPY
RIGHT NOW BLUE LIGHT IS ON FAX AND WHEN I PRESS COPY BUTTON IS NOT ALLOWING ME
PLEASE ADVISE
Nov 10, 2009 | IBM Infoprint Color 1357 Led Printer
Mfc 8460n paper jam
Check to see if this happens when you use the drop down manual feed tray. If your printer works fine using the manual feed tray the problem is with your paper tray. Check to make sure it is set to letter size. I've found that sometimes the 'teeth' holding the paper stop on the paper tray wear out and when the printer goes to pick up paper, it pushes the paper stop out of position causing the printer to think it's using a different, much longer size paper thus preventing it from feeding all the way through. You'll probably need a new paper tray if this is the case.
Jan 06, 2009 | Brother MFC-8460N All-In-One Printer
Brother MFC 8460
Hi
There must still be a piece of paper in the machine check the fuser section at the rear of the machine maybe be piece there or check at the paper cassette area remove cassette and check that the paper hasn't got jammed as it feeds through.
Thanks
Dec 29, 2008 | Brother MFC-8460N All-In-One Printer
Document jam brother mfc 8460n
you cannot clear this unless there is still a presence of paper inside the machine.
or you can open and close your machine once you are cleared of any paper jammed, be sure not to leave and removed all residual paper in the paper path, the tiny sensor would recognize any sort of this and thus make your machine unoperable.
Jul 25, 2008 | Brother MFC-8460N All-In-One Printer
Brother 2820 Says clear scanner jam and press stop
Make sure there is nothing caught where the documents go it. List up the scanner cover and look inside. It may need a separator pad or clean the feed rollers with some alcohol. Lawrence
Mar 23, 2008 | Brother IntelliFax-2820 Laser Fax
Document, Jam???
Hey I figured it out. On the top where you insert paper into the automatic document feeder you will notice a small switch. When paper is set in the tray the switch is pressed down. I noticed on mine that the switch had become stuck down. I just used a small push-pin and popped it up. Error message went away.
Feb 01, 2008 | Brother MFC-8460N All-In-One Printer
Brother MFC-8460N All-In-One Printer Logo
149 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
