Question about Software Architects ReadDVD 10.3 (SAI0JRDVD000200W) for Mac
How to use Ratdvd
I am trying to up load a dvd to my hard drive with RatDVD....how i i do this ?
    Genius:
  • 1,354 Answers
Hi
do you have your DVD is read drive then only it will work if not then only
u can run read DVD's
Posted on May 28, 2010
Installed new hard drive p105 s6064 now cd drive wont work dont have recovery discs
Dell recovery will not work in a Toshiba Laptop. Just make sure the boot order is set to CD/DVD driver first that will automatically start the CD/DVD driver when disc is loaded.
Apr 22, 2012 | Toshiba Satellite P105-S6104 Notebook
I have an acer 5315-2326 and I reformated the hard drive and tried to load windows 7 pro. It cant find the hard drive. I can load ubuntu but when I try to load windows 7 it says no hard drive found.How do...
I have seen hard drives where people had screwed around the partitions so bad that their computer would recognize it. I would recommend since Ubuntu can see it. Boot into a Ubuntu Live CD and delete any partition info so that it's a completely empty disc. Then try to use the Windows 7 DVD to install Windows. Comment back with your results.
Oct 25, 2011 | Acer Aspire 5315 Notebook
I have a Emachine T5212 and im trying to reformat my hard drive but my internal dvd drive is not recognized.I brought an external dvd drive,but everytime i try to erase my hard drive it tries to load from...
First you need to have media ready to install once format is compelte.
You can not format a drive you are currently using an operating system unless you run the operating system setup disc in which case you would be booting and running from cd once you start reloading you main drive.
So if you are loading windows .
Review steps below if when you boot you do not have option to select boot device
Boot you laptop / pc and get into the BIOS
<normally f2 or f8 , f12 depending on system.>
Change the BOOT order to cdrom as primary \ you may see the device as USB CD/DVD rom with the actual name of brand there.
Save and exit
Have operating system in cd/dvd rom attached to device
Once it starts to load you will see BRIEFLY in the upper left corner PRESS ANY KEY TO LOAD FROM CD ROM or something similar... stop reading this and press a key ........
From there it should prompt you for setting up a new os, I prefer linux myself but in windows or linux in the setup process you have the option of just loading the operating systems or DELETING THE PARTITIONS and FORMATTING the drive, therefore wiping i .
NOTE: THIS IS NOT WIPING YOUR DATA, if you are trying to hide something, wipe from your drive past **** you never wanna share with anyone again..... repost under how do i wipe my hard drive clean .. its a completely different story .. not hard but different.
Jul 24, 2011 | Computers & Internet
I am tring to format my hard drive but when I try to load windows but it will not go to my dvd rom when I turn it on it says invalid disk
you need to set your bios to boot from CD/DVD first.
turn on your computer and hold either the f2 or del key to get to the bios.
then look at the settings for a option to change the boot drive order
make CD/DVD rom first then hard drive second.
Mar 31, 2011 | Samsung (SP1203N) 120 GB Hard Drive
I TRIED TO RE-INSTALL THE OS WHEN THE DVD/CDRW DRIVE STOPPED WORKING IT STOPPED AFTER IT FORMATTED THE HARD DRIVE. NOW MY QUESTION IS HOW CAN I USE AN EXTERNAL HARD DRIVE TO INSTALL THE OS. THEN PROCEED...
Hello
OK, at the link below you will be able to get step by step instruction on how to load windows from a USB device.
Click HERE.
As for the CD/DVD rom, you will just be able to plug it in, no additional drivers will have to be loaded.
Kind regards
Andrea
Aug 31, 2010 | Sony VIAO P4 PCV-RS712 3.0GHz 512MB 200GB...
We're trying to hook our Western Digital My Passport External Hard drive to our dvd player. The dvd player has a port for it, but is unable to read the external hard drive. Do we need to unlock the hard...
the USB port in the dvd player is to update it by the manufacturer. Unless the USB port is in the front then try going into the dvd players menu and have it search for devices, also make the content easy to find for dvd player, like have a VIDEO folder and put the media in there.
Jun 20, 2010 | Western Digital WD Passport 250GB Portable...
Hi, my Philips DVDR3455H/75 DVD/Hard disk doesnt
THE DVDR3455H HAS A COMMON PROBLEM AFTER A FEW YEARS THE HARD DRIVE GO BAD, IT WONT BOOT UP
99% OF THE PROBLEM WITH THE PHILIPS DVDR3455 IS THE HARD DRIVE.
IT WILL KEEPING REEBOOT OR IT WILL HANG ON THE PHILIPS LOGO.
IT IS NOT A FIRMWARE PROBLEM IT AHARD DRIVE PROBLEM.
ONE THING YOU SHOULD KNOW, IF THE HARD DRIVE IS BAD YOU WILL NOT BE ABLE TO UPGRADE THE FIRMWARE IT WILL NOT READ THE CD OR DVD DISK.
AT THIS POINT IT NOT LOOKING FOR A FIRMWARW DISK BUT IT LOOKING FOR THE BOOT UP SOFTWARE.
OR THE LOAD CD WHAT PHILIPS CALL IT.
SOLUTION REPLACE THE HARD DRIVE WITH THE LOAD SOFTWARE INSTALL ON IT.
THE HARD DRIVE IS SOLD ON EBAY JUST LOOK FOR DVDR3455H YOU WILL FIN NEW DRIVE READY TO INSTALL THAT WILL FIX YOUR PROBLEM.
Nov 03, 2009 | Philips DVDR3455H/37B
LG GSA H55L DVD READ PROBLEM
It is possible there is a bottle neck in your system stopping it from allowing the dvd to play.
The DVD drive is only one part of it. There is the cable to the motherboard, CPU load, memory load, Video card being used etc.
If the drive is connected to another DVD/CD drive on the same cable, try unplugging it first and see if it improves. Also if it is running on the same cable as a hard drive, your main hard drive in particular, then try to get it onto it's own cable.
Check the software running it is not in software mode using it's particular config section within the program as well. If your video card supports hardware mode for video playback, then that will reduce system power being used by the CPU and the memory systems.
Apr 20, 2008 | LG (GDR8164B) Internal DVD Drive
Can't hardly play a pirited dics
try: deep burner, ratdvd, dvdclone etc: from http://filehippo.com
Sep 30, 2007 | Televison & Video
Hard Drive not responding
sounds like a bad hard drive or a software problem and if im not mistaking this kinda thing has to be done "in-house"(at the factory) Try this info Hope it helps!! Good Luck Main support number(800) 252-5722 Email support proinfo@jvc.com
Apr 08, 2006 | JVC DRMH20 DVD Recorder
Computers & Internet Logo
90 people viewed this question
Top Software Architects Computers & Internet Experts
David Payne
David Payne
Are you a Software Architects Computer and Internet Expert? Answer questions, earn points and help others
