Question about Sport & Outdoor - Others
No spark on tecumseh 4 hp lawnmower engine - Sport & Outdoor - Others
  • Karla Pitts May 28, 2010
    have no spark on our tecumseh lawnmower engine
    Genius:
  • 1,040 Answers
Dear Acelady,
Check all the grounding point for corrosion.
The flywheel needs to be remove with a flywheel puller. There are (should be) 3 holes in the center of the flywheel. Tap the holes with a 1/4 inch 20 national course tap. You can use the Tecumseh puller, recommended, or use another puller that fits the flywheel hole pattern.
When you re-install the flywheel, make sure you squeeze the engine shut-off lever or you will damage the flywheel brake.
As for the coil, disconnect the small wire(s) connected to the coil...it should be a push on type spade connector. Remove the spark plug and re-install the starter. Check for spark. If you have spark then the coil is fine and you either have a bad wire or a stretched engine shut-off cable. I rarely find bad coils; it is either the cable or wire. As for a sheared key, you will normally have spark.
1- Check the Flywheel Key. If the Key is Damaged it Will Cause this Problem. The Flywheel Key Times the Engine. 2- Check the Coil Clearance from the Flywheel. It should be .020in. 3- Check the Spark Plug Gap. Should be ,035in. 4- Check the Valve Lash on the Exhaust Valve. Should be .017in Clearance Between the Valve Stem and the Valve tappet. 5- Check for a Burnt Valve(the valve must be removed from the engine block to perform this check). Hope this Helps.
Posted on May 28, 2010
    we have checked all of the suggestions you gave still no spark any more suggestions
    Brigadier General:
  • 3,917 Answers
There is a shutdown wire, this wire is grounded somewhere along the route. Look at the coil for this wire; it shorts the coil to ground so no spark can get out to the plug.
Let us know if you want to know something else accept the suggestion.
Thanks for contacting fixya.com
    we tried this and still no spark
I have a Murray 20 model 20213A with a Tecumseh engine. The lawnmower will start but it dies a few minutes later. What could cause this and where can I get a manual for this model lawnmower?
Use high test fuel without ethanol, and
Murray 22" Lawn Mower - Carburetor Cleaning, Nasty ...
? 7:33
www.youtube.com/watch?v=_dzcDZUh1MY
May 10, 2013 - Uploaded by mountainbikekayak But here is the link for the start up of this Murray had to replace the plug as well also ... as well: Murray 22" Lawn Mower 6.5 HP OHV -- First Start after Carburetor Cleaning - Part III - May 9, 2013 ... When I start it, it runs for 3-4 seconds and dies. ... Youcan also find you engine Model # online and view the ...
Sep 09, 2015 | Tecumseh Garden
6.5 toro self propel.....new plug and new gas,,,turns over but then shuts down...replaced both neoprene hoses
Carburetor Cleaning TUNE UP of Toro 6 5HP Lawnmower with Tecumseh Engine
The above link will provide a video on how to clean the carb on the 6.5 hp mower. Before you go to that length, try putting some carb cleaner in the fuel tank and see if that corrects the problem. Also, as the video shows, make sure the spark plug is getting a good spark. If the spark is weak , the fly wheel may be rusted, ot the magneto is bad.
May 09, 2014 | Garden
What is sparkplug gap on 8 horse tecumseh snow blower
Clif - I have two items in my garage with Tecumseh engines on them in that HP range and they both specify .030 spark plug gap in the instruction manual.
Dec 03, 2013 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
8HP Tecumseh with no spark
Check the gap between the coil and the flywheel. You can fold a dollar bill over a few times (3 or 4 layers thick) , place it against the flywheel , **** the coil up to it , and then tighten down the coil. This will give you a good clearance between the coil and flywheel and promote good spark.
Essentially I am suggesting you use the folded dollar bill to set the coil to flywheel distance/gap.
If it still doesn't work, I am at a loss. Is this a multi cylinder engine ? If so , does it have points or electronic ignition ?
Aug 08, 2012 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Centura 3.8 HP Tecumseh lawnmower not working w/o starting fluid
main jet blocked needs carby service its worth it
May 12, 2010 | THQ The Lawnmower Man
4HP Tecumseh flat-head head-bolt torque?
check the numbers on the motor and you can contact Tecumseh or check their website for info, they are usually very good with their help
Jun 29, 2009 | Sears Craftsman 7-1/4 in. Circular Saw...
Oil leak tecumseh engine OVRM120-22053F
oil seal is worn out from durbis wrapped around crankshaft need to replace oil seal by removing blade and hub
clean cranksaft with fine sand paper
a sharp awl punch in the outter edge corner of seal on a 45 degee angle then slide seal off
heres the manual.pdf page 75
Mar 23, 2009 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Mtd riding lawnmower won't run
my mtd lawn mower wont start . when I turn the key there is a buzzing soung where the battery conectors are near the shifter but the starter is hot and getting juice
Sep 28, 2008 | Garden
Sport & Outdoor - Others Logo
405 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
