Question about Whirlpool LSR5132PQ Top Load Washer
My washer The washer is leaking from the front and I don't know what to do.
  • 1,531 Answers
Check the drain hose and make sure there is no holes in them also make sure to check the drain pump make sure it is not cracked.
lean the machine back and you should be able to see the hose and the drain pump
Posted on May 28, 2010
My whirlpool duet sport washer is leaking in the front underneath, not from the door. Does not do it when it drains. What do I do?
Hello Casey,
Its possible that the washer could be leaking from the door seal yet ya don't see it coming from the door. The way to check if its the door seal remove the lower panel and see if the concrete counterweight that's on the front of the drum...if ya see water dripping from that counterweight,its from the door seal.
If the door seal is not leaking ya would need to look at the pump and hoses on the tub while it was in wash mode to see whats leaking.
GENE
Oct 11, 2011 | Whirlpool GHW9400 Duet Washer
The bleach dispenser keeps filling up with water (I am not using it) and I don't know how to empty it - and why is it filling up?
You have a leaking water valve that dispenses water into the bleach cup. You will need to replace the water valve to stop this problem.
Good luck
Jul 08, 2011 | LG WM2487H Front Load Washer
Washing machine is leaking
Electrolux
EW1000i Front Load Washer leaking This video will show you how to find the leak on your washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
May 03, 2011 | Electrolux EW1000i Front Load Washer
My washing machine is leaking
Miele W2240 Front Load Washer leaking This video will show you how to find the leak on your washing machine
Apr 20, 2011 | Miele W2240 Front Load Washer
Ge front loader leaks when filling
Leaks are probably going to come from one of 4 places:
  1. Door gasket: water should run down the face of the washer from the lowest point of the door.
  2. Water connectors: left rear of machine
  3. Soap drawer: water running down front of machine from the upper left-hand side
  4. Discharge pump and hoses: Right side.
Rear right would probably indicate a discharge hose leak. Front right would most likely be the discharge pump and/or connectors to it. Here's a diagram:
If you don't see any of the easily visible leaks (door, soap dispenser, connectors), try to
pop off the front access panel by removing the 3 bottom screws. Once removed try to determine where the leak is originating from...then we can troubleshoot more. If you find this advice helpful, please don't forget to rate me -- trying to get my Guru level so I can offer premium support
Jun 23, 2010 | General Electric WCVH6800J Front Load...
I have water leaking from the dispensing tray, only on the pre wash filling..any suggestions I have a hotpoint washer dryer wd64
Check the level of the machine, may be leaning slightly forward allowing water to leak on that one fill cycle. Lift the front a little by using the adjustable feet and see if it stops.
Feb 16, 2010 | Hotpoint Aquarius WD640 Front Load...
January 31, 2010 Kenmore top loading series 80 leaking from bottom toward front. It started during a wash cycle. I put two wet towels back into the empty washer and put on spin, leaking reoccurred. ...
is the pump leaking?or you could have bad tub seals,follow the center trany shaft up to the tub and see if it leaks there,is it noisy when spinning,you gotta just get in there with a light and look around to see where the water is coming from,if you sent pictures they didn't show up,remove the front cover,take out the two screws that hold the console down,remove the two clips with a screw driver and unplug the lid switch wires and pull the cover back and remove it
Jan 31, 2010 | Washing Machines
Leaking washing machine
Hotpoint Aquarius WF210 Front Load Washer Leaking This video will show you how to find that leak on any front loading washing machine
Apr 01, 2008 | Hotpoint Aquarius WF210 Front Load Washer
Bosch Nexxt WFMC3200UC
Bosch Nexxt WFMC3200UC Water pouring out from beneath washer. This video will show you how to find that leak on any front loading washing machine
Mar 15, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Whirlpool LSR5132PQ Top Load Washer Logo
27 people viewed this question
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
