Question about Insignia Audio Players & Recorders
Need a 12 pin din cable for is-nxt10232 - Insignia Audio Players & Recorders
5 Suggested Answers
SOURCE: Sanyo 8 pin din cable
from Sanyo LA,Calif
Posted on May 11, 2008
  • 1039 Answers
SOURCE: Need input connector (13 pin din?) pinout.
Call Bose. Do google search. They sell accessories on line. They are vry helpful.
Posted on Apr 25, 2009
  • 5370 Answers
SOURCE: some of the pins on
You can but this cable.This spare cables are available on eBay.-------- Click this link below for male to female Din 9-pin cable:--- http://cgi.ebay.in/Mini-Din-9-Pin-Male-Female-Cable-12-feet-long-/360328538624 -------------- If you require male to male din 9-pin cable , click this link :--- http://cgi.ebay.in/Mini-Din-9-Pin-Male-Male-Cable-9-feet-long-/360328538777#ht_987wt_932 -------------- You can also get this cables at radioshack, walmart, bestbuy online sites.--------- ------------ This will help.Thanks.Helpmech.
Posted on Aug 04, 2011
florin2901
  • 8 Answers
SOURCE: The 4 pin din connector on a Liteon AC adapter, PA-1181-02 firs neither a standard din nor a mini din connector. It's almost as if the pins are for a standard din and the shell is for a mini din.
Maybe is too late, but i wrote here what I found about LITEON PA1181-08 adapter.
First flip the adapter and remove those 4 round rubber where you will find 4 screw's. Or take a look here => http://www.pchub.com/uph/laptop/46-33144-7053/LITE-ON-PA-1181-08-AC-Adapter-Laptop.html for pinout of the unusual 4 DIN connector.
Hope you will find this usefull.
florin2901@yahoo.com
Posted on May 30, 2012
Anyone know where to get an 8 pin din cable for my Yamaha YST-MS55D multimedia speakers?
I just bought one here in Holland in the handyman store. Where do you live?
Oct 07, 2014 | Yamaha YST-MS55D Computer Speakers
I CANT FIND A SP PWM505 CABLE
  • Here is a list of cables for your unit from Crutchfield's.
  • If your looking for the s pin DIN cable from the sub you can get that anywhere. The 8 pin DIN is a standard cord the same across the board. Here are a couple to choose from.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Oct 11, 2011 | JVC TH-M505 System
No sound
To answer this one, we'll need a lot more information. The following
1. Verify your cable. There's no way to post a picture so we'll try this in text. Looking at the 5-pin DIN (called P1) with the pins to the top, number them 1 through 5 from left to right (regardless of how they may be numbered on a connector as it is unmarked on the cable). Looking at the 8-pin mini DIN (called P2) with the key at the top, number the top row 1 through 3 (left to right in all cases), the middle row 4 through 6 (pin 6 will be the one separated by a gap from the other two), number the bottom row 7 and 8.
Now, make sure that continuity exists. This is how my cable was wired as follows: P1-1 to P2-7, P1-2 to P2-8, P1-3 and P1-4 to P2-6, P1-5 to P2-1. If you do not show that each wire is good, then you either have a damaged cable or audio is not being output by the Bose control unit or your system uses a different cable wiring, which means that you will need to verify that your cable connects each 5 pin DIN to some on the 8 pin mini DIN
2. Make sure that a headphone is not inserted in the headphone jack on the side. If it is, then sound in not connected to the rear ports. It may sound silly, but someone may have connected headphones and nobody realized that they're still connected.
3. Do you have an oscilloscope? If so, then you'll need to insert wires into the 8-pin mini DIN connector for the zone you're using. Using the pinouts from step one for the cable connector will create a mirror at the Bose jack as follows, left to right, top to bottom 3, 2, 1 - 6, (gap) 5, 4 - 8, 7.
Audio comes out at pins 7 and 8. So connect your scope at those points and ground the probe by clipping it to one the RCA shields. Turn the unit on and make sure that you have a source producing signal, such as a disc or a radio station and see if you see signal. The output at these pins appears rather low, so you set your scope sensitive enough.
My Bose produced audio, but also clicking at an increasing frequency and amplitude as the unit heated up, that results in a lot of noise. I verified the wiring and output with this method.
Feb 18, 2011 | Bose Lifestyle 20 System
Is the system cable wired as a serial connector
u can get one from cablesondemand.com 8 pin mini din male/male
Oct 19, 2009 | JVC TH-M303 System
Din cables
You need to know how many pins you need (count the holes in whatever you are plugging the cables into). After that, just buy a cable in any tech store, or on Amazon (Amazon's cables are here: http://www.amazon.com/s/ref=nb_ss?url=search-alias%3Daps&field-keywords=din+cable&x=0&y=0).
Sep 19, 2009 | Durabrand Two Screen Car DVD Player
Scheme for the VGA Cable of Acer AL1511eb
You will have to buy a 13 Pin Din Male Connector cord. Use the break-down below to help with reconfiguring.
Pin 1 RED Red video Pin 2 GREEN Green video Pin 3 BLUE Blue video Pin 4 N/C Not connected Pin 5 GND Ground (HSync) Pin 6 RED_RTN Red return Pin 7 GREEN_RTN Green return Pin 8 BLUE_RTN Blue return Pin 9 +5 V +5 V DC Pin 10 GND Ground (VSync, DDC) Pin 11 N/C Not connected Pin 12 SDA I²C data Pin 13 HSync Horizontal sync Pin 14 VSync Vertical sync Pin 15 SCL I²C clock
Nov 24, 2008 | Computers & Internet
107 people viewed this question
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Alan Matzke
Curt Larson
Level 1 Expert
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
