Whirlpool Duet GHW9150P Front Load Washer Logo
Posted on May 28, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Control panel locked - Whirlpool Duet GHW9150P Front Load Washer
Anonymous
Level 3:
President:
  • Master 1,382 Answers
  • Posted on May 28, 2010
Anonymous
Master
Level 3:
President:
Answers
1382
Questions
0
Helped
552348
Points
5097
Press and hold the End of Cycle Signal button for three seconds. This will turn off the Control Lock feature.
Thank you !!
Whirlpool duet dreyer control lock On --can't program dreyer
try unplugging for a couple of minutes and it should reset to factory settings.
CONTROL LOCK GE GAS DRYER
  1. Press and hold for 3 seconds the "Control Lock/Unlock" button on the control panel to lock the control panel.
  2. Listen for a double beep and observe the "Control Lock" status light is lit when the control lock is in effect.
  3. Press and hold for 3 seconds the "Control Lock/Unlock" button on the control panel to unlock the control panel. The "Control Lock" status light is goes out when the control panel is unlocked.
Jan 31, 2015 • GE Dryers
The control touch panel is locked in door locked mode wont clear to use other control functions
I appreciate your post, philip hunter!
From my understanding the control panel on your Electrolux range is locked. On the control panel you should see a button near a lock symbol, typically it is labeled control lock, and if you hold that button down for three to five second it should release the control panel. If that does not help release the panel I would suggest performing a reset and you can do that by disconnecting the power from your range for ten minutes. Hopefully this helps. -Matt
1helpful
Whirlpool duet dryer
Oct 22, 2013 • Dryers
2helpful
The controls locked is displayed. what causes this and how do i get the controls unlocked.
I have accidentally locked my microwave oven (profile performance convection oven). I was cleaning the front. Can you tell me what to do?
Got you covered. Here you go:
Microwave - Explanation of the Child Lock Out Feature
Many microwave control panels can be locked to prevent accidental use or access by children.
There are two different ways to lock the control panel:
1. Press and hold the CLEAR/OFF pad for 3 seconds. The display will show "LOCK" and then revert to the time of day.
A small "L" will appear in the corner of the display as a reminder that the control panel is locked. If anyone tries to use the microwave, the display will show "LOCK".
2. On some models, press and hold the 5 and 7 pads simultaneously for 3 seconds.
To unlock the control: Repeat the procedure which was used to lock the control. (Press and hold the CLEAR/OFF pad for about 3 seconds or hold the 5 and 7 pad simultaneously for 3 seconds.)
That info is from GE
Hope that does the trick.
Regards, Farmerbear at FixYa.com
2helpful
2answers
Control panel reads control locked
You problem have locked the control. There is a button on the front panel that says control lock. If you push adn hold this button for 3 secs the control locks or unlocks.
My Kenmore Elite HE 4t has a bulb illuminated on the front panel. The bulb is the "Control Locked" bulb and the washer does not work! Please help. I have tried unplugging it for awhile.
The reset or cancel button does not control the locking feature. Unplugging the appliance also will not reset it. The following link explains how to correct a control panel lock issue on a Kenmore Elite:
http://www.fixya.com/support/r2469429-kenmore_elite_amp_whirlpool_duet
The control panel lock is actually a designed safety feature that allows you to lock the control panel to keep small children from manipulating the controls. It can be inadvertently set by leaning against the control panel buttons, or following a power outage.
If you have questions, please let me know. I hope this helps you.
1helpful
Fpa lock on how do i get this offf
hello Lock/Unlock Parental Controls
Selecting this option lets you lock and unlock parental controls settings
using a password.
If you do not lock parental controls, none of the settings for V-Chip,
Channel Block, or Front Panel Block will take effect.
If you forget your password, press the MENU button, then select Parental
Control
(the password entry screen appears). Simultaneously press and
hold CH+ and VOL+ on the front panel for 8 seconds. Parental Controls
unlock and the Parental Control menu appears. You can enter a new
password by locking the Parental Controls again.
Front Panel Block
Selecting this option lets you block (disable) or unblock (enable) the TV’s
front panel. The remote still tunes to any channel. When using this as a
Parental Control method, remove access to any remote that is capable of
operating the television while you have the front panel blocked.
Don’t forget to lock parental controls after you change the status. If you
don’t, the front panel block will not take effect .if this don't work get back to me i've got manual good luck
shaun
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
