Question about DeLonghi Esclusivo Magnifica ESAM3300 Espresso Machine
Leaking water Whenever we make a coffee it seems to be comong out slower than usual amd a large amount of water is coming from underneath the coffee pot. Have you heard of this before? hope you can help!
  • 25 Answers
Check for two loose screws holding the backplane that holds the infuser unit. With the machine OFF, open the door and press the two red buttons to pop out the infuser. You will then see two 3 mm hex head screws attaching the backplane. Check that they haven\'t come loose; if so, you\'ll need a hex socket to tighten them. Then re-insert your thoroughly cleaned infuser and see if that has stopped your water leak.
Posted on Jun 29, 2010
During a cleaning cycle my krupa ea8080 bean to cup machine started leaking water from underneath the machine. After trying to make a coffee once it had finished, some coffee is coming out correctly, but...
I have the same problem and have now just located where the water is coming from, it is seal within the boiler/plunger and I am now on a mission to find a service kit. It took many hours to get to this problem and unless you are feeling brave I would consider sending it off to krups!!
I will let you know my progression
Mar 26, 2011 | Krups Small Appliances Espresso Machine
My xp7240 has also started leaking water from beneath the machine
the distribuitor as down!
its dificult to substitute. maybe find an expert its a good option for this case.
Jul 02, 2009 | Krups Small Appliances Espresso Machine
Water not getting through
If you look under that white nozzle you will notice a small hole that leads to the drain tray, clean out hole and the area or small enclosure around the white nozzle (clogged with coffee grounds), and make sure that if you pour a little water in that enclosure it goes to the drain tray. That will solve the water under machine problem.
For the amount of water from the coffee nozzle, check brew unit, you will have to remove the shower screen and clean, make sure that the unit is not clogged in one of the tubes.
May 19, 2009 | Solis Master 5000 Espresso Machine
Water leaking from underneath water tank.
I rang Saeco service centre about my leaking water tank and they posted me a new tank - no questions or need to return the faulty item. I believe there may be a bad batch of tanks which leak because of faulty valves.
Mar 24, 2009 | Saeco Primea Cappuccino Touch Plus Coffee...
Question about cuisinart's DCC-1200 1-4 cup mode
The 1-4 cup setting actually loops the water through the heating element twice. It's a good wrokaround for people who like extremely hot coffee, but not for iced coffee fans like me.
-Tha Mp3 Doctor
Dec 21, 2008 | Cuisinart DCC-1200 Coffee Maker
Water leaking into machine
it's possible, like mine with the same problem, that one or more of the plastic feet under the water tank has broken, then making the tank move and upsetting the valve underneath. My one always leaks clean water, never dirty and I have a broken foot.
Sep 29, 2007 | Saeco Primea Cappuccino Touch Plus Coffee...
DeLonghi Esclusivo Magnifica ESAM3300 Espresso Machine Logo
878 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Michael Vincent Cruz
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
