Question about HP LaserJet 4250dtn Printer
Can't print on Network LaserJet Printer
Updated HP LaserJet 4250dtn Printer driver and now the printer won't print. Printer is connected to a company network by ethernet cable. Printer is accessed by a Workstation Dell Optiplex 740 with 2Gb of RAM running Windows XP (Service Pack 3)
  • 903 Answers
If it worked before you updated the driver, go into the Device Manager and roll back the driver to the previous version. Sometimes new drivers haven't been fully tested, or they may contain bugs or may just be incompatible with an application that you happen to be running. If the old driver version works, stick with that.
Posted on May 28, 2010
How to use HP Laserjet 2300 dn offline. This printer is a network printer
Thank you for contacting FixYa with your inquiry.
This printer can work very well via a standard printer cable directly connected to your computers LPT Terminal. Most of Microsoft's current Operating Systems already have the LaserJet J2300 drivers built in and will automatically install when connected.
To confirm your connection to go to your computers printer setup and ensure the driver is configured to print from LPT1 port and click on print a test page. (Start/Settings/Printers/LJ2300 - Right Click on properties then click on the tab for ports. The general tab should have a button to print test page)
The network card that comes with your printer (Jet Direct Card) will not be used with this method nor will the Ethernet cable be required.
Hope this helps helps. Please keep us updated and remember to rate this answer.
TF
Dec 14, 2010 | HP LaserJet 2300dn Printer
I have changed my pc, reconnected my hp laserjet 4250, installed drivers but now although the option for print both sides is clicked it doesn't print it. Any ideas??? Cause i have to print a 500 pages book...
There isn't too much to go on in your description. Taking a guess that you are running Windows....and if you are printing from Word...and that your printer has a duplexer sticking out the back...click on the Print icon/select the printer/select properties/select finishing/check "print both sides". Select OK, select print.
Oct 15, 2010 | HP LaserJet 4250dtn Printer
Watermark problem
Sounds like a print driver problem. If the driver sits on a server and used by others do they have the same problem. If so, delete driver on server and reinstall. If the print driver is loaded individually on each pc - you will need your driver deleted and reinstalled (preferably from a different source). Hope this helps.
Jul 08, 2009 | HP LaserJet 4250dtn Printer
Printing mechanism failed
The swing plate assembly needs to be replaced by an HP technician
Mar 04, 2009 | HP LaserJet 4250dtn Printer
Network printer will not print
Hi Savo,
Is printer being recognized by network? What does device manager indicate? If there is a Yellow exclamation point, you need an updated driver. Try uninstalling software, removing access cable to printer and reinstalling software then re-connecting printer cable.
Jan 17, 2009 | HP LaserJet 4200tn Printer
HP LJ printer printing slowly
try to change the driver on the network definition
Nov 21, 2008 | HP LaserJet P2015 Printer
Looking for a manual
You can download your manual from
www.generalmanual.com/Printers/HP-LaserJet-4250dtn-Printer.htm
Hope my info solves your problem,
Thanx for using fixya.
Sep 30, 2008 | HP LaserJet 4250dtn Printer
HP LJ4250dtn 49.5F11 Service Error
49.xxxx error occurs when the printer does not understand the Print Job Language. Following could be the reason:
  • Faulty Network Cable/Port
  • Corrupt Driver
  • Firmware of the printer and the Jetdirect Interface.
  • Corrupt file.
  • Corrupt Print job.
  • Less memory or corrupt memory DIMM
Hence to start with, please let me know when do you get the error. Is it when you powercycle the printer.
Please perform the following:
  • Upgrade the firmware of the printer and the jetdirect card.
  • Change the driver and install the UPD drivers.
Let me know the next update...
- Nikhil
Aug 07, 2008 | HP LaserJet 4250dtn Printer
Error 60 02 on a HP LJ 4250DTN
60.2
printer error
The tray 2 lifter-motor is not functioning. 1 Turn the printer off and then on.
2 If the error persists, turn the printer off.
3 Verify that the tray 2 lifter wire-harness
is full seated in its connector on the
dc controller PCA (location J93).
4 Replace the tray 2 lifter-driver
assembly. See Tray 2 lifter-drive
assembly.
5 Replace the dc controller PCA. See
Jan 10, 2008 | HP LaserJet 4250dtn Printer
HP LaserJet 4250dtn Printer Logo
183 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
