Question about Kenmore Washing Machines
I have ''syphoning '' how do I extend my drain hose.
I have ''syphoning'' since my drain hose is less than the minimum height how do I extend it.
  • Anonymous Mar 15, 2014
    Machine is not draining properly.
  • 166 Answers
You can try looping and securing the hose up in the back of the machine higher than the height of the highest water level in the tub. you should have enough hose to do this.
Posted on May 28, 2010
Water discharging from drain hose by itself while running washing machine, drain switch not functioning
It sounds like you have a simple syphon running. The end of the drain hose MUST be higher than half way up the height of the drum. If the hose is lower than this then physics is not on your side and water will simply fall out of the hose because the end is lower than the height of the water in the drum!
Sep 01, 2015 | Haier Washing Machines
Want fill up
Good Afternoon Friend,
I see that you are having trouble with water staying in your Frigidaire washer, model# FWS1339A, during the fill cycle. I suggest checking to make sure your drain hose standpipe is the correct height. The standpipe must be between 33 and 96 inches. If it is less than 33 inches, then the water might be syphoning out of your appliance. If this is the case, then I suggest installing a syphon break kit. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 16, 2014 | Frigidaire FWS1339A Top Load Washer
When pressing the start button, C on appears in the window
Could be drain hose too low minimum height should be over 30 inches or will syphon /could also be leakage under machine operating float switch/operating pump to get rid of water avoiding flood.
Oct 31, 2013 | Beko Washing Machines
Overflow is way past hot line and need to drain
You should be able to take the small hose loose at the radiator filler neck and drain the overflow. Or use a syphon pump to pull coolant out of the tank.
The syphon hose would be the less messy way to go.
Feb 06, 2013 | 2002 Chevrolet Monte Carlo
I have a Kenmore 500 top load washer that doesn't hold water. As it is filling for the wash cycle all the water runs down the drain
The drain hose outlet must be higher than the 'full' water level in the tub or the water will syphon out until the tub water equals the hose height. If the drain system you are using for the washer is floor level, then you need to install a vertical pipe (1-1/2" minimum) to place the hose end into at the top and it should eject the water through a 90 degree elbow onto the floor at the bottom. There are more elegant solutions, but this will stop the tub from self-draining. Good luck!
Aug 05, 2010 | Kenmore 22422 Top Load Washer
My water is draining out of my machine as it is filling, Why?
This is a condition known as syphoning. Your drain hose on the washer needs to go up before it connectes to the house drain. It needs to rise as high as the washing machine top then hook over the drain pipe. If the drain hose is pushed too far into the drain pipe this can also cause syphoning.
Here are some tips to help describe this better.
Is the drain hose extending more than 8" (20.3 cm) into the drainpipe?
The drain hose may be too far down inside the drainpipe (standpipe) or laundry tub. Drained water can siphon back into the washer if the drain hose extends too far. Make sure that the drain hose does not extend more than 8" (20.3 cm) into the drainpipe or laundry tub. Using the U-shape drain hose form (as described in the Installation Instructions), will provide the correct length of drain hose in the drainpipe or laundry tub.
Drain hose form
Is the drain hose taped onto the drainpipe? Is top of the drainpipe covered in tape?
Do not seal the drain hose into the drainpipe with tape. The drain hose should be loose, yet secure. There must be a gap between the drain hose and the drainpipe to allow air to flow. The air gap will break the suction. This will keep water from being continuously sucked out of the machine (siphoning) as it fills.
Is the drainpipe (standpipe) less than the minimum height of 39" (99 cm)?
Make sure that the top of the drain is at least 39" (99 cm) high (as measured from the floor.) If the drain is below 39" (99 cm), the water will start to flow out of the machine due to gravity. The flow of water can create suction (siphon) and the water will continue to drain out of the washer.
Apr 19, 2010 | GE Washing Machines
Recently my washing machine has been giving off a putrid eggy smell when on any program. I clean inside the drum, the drawer ect often. i have checked both inside and outside drains and cleaned them. i was...
it may well be stuff from your sink drain trap syphoning back into your washing machine
sounds like you need an anti syphon valve to be connected in line with your washing machine waste water outlet
Check that hose discharge from washing Machine loops up above the minimum height as specified by the machine manufacturer and at least to the underside of the work top for an inset sink before connecting into the sink trap.
http://www.wickes.co.uk/invt/420182
Nov 18, 2009 | Washing Machines
Water continues to drain on the spin cycle while filling
there is no actual drain valve, but rather physics to keep water in tub.
The drain system MUST be located HIGHER than the deck fo the machine, with console height being preferred.
Drain during spin cycle is normal, as rinse is intended to also drain away at that time..
Doc
Sep 18, 2009 | Washing Machines
Water wont go into drum, it goes straight out the drain and the some lights start flashing
suspect you have the drain down at floor level. drain hose should go upwards to about the height of the worktop before going down to drain. if you are draining into a standpipe, put drain hose only a few inches into the standpipe, not right down to the bottom or a syphon will form
Jul 18, 2008 | Washing Machines
Washing Machines Logo
Sal DeAngelo
fordexpert
Ed Mac
