Question about Dynamite 32 Marine Inboard Engine
Working on a 305 in a 1981 criss craft boat, oner
Working on a 305 in a 1981 criss craft boat, owner of the boat didnt open the valves in the hull to let the lake water in and up to the impeller pump located on the front left side of the engin. (if your standing behind it) replaced the pump and started the engin to make sure it was pumping befor replacing hoses and it wasnt. any suggestions on what might be the problem? also turned housing around thinking i might have put back in wrong but no results there eather. had it right the first time.
Where are the drain plugs situated on a T Cat boat
has to be out on the rear hull area
below water line or deck platform
upgrade hull with
aftermarket stainless steel or brass systems
wise to have a bilge pump
and carry bailing buckets
9f16875a-8021-465a-81f2-8f6b06be53e4.jpgindex-cvxygyvu0vydc25j522ljeey-4-2_0.jpgst-cvxygyvu0vydc25j522ljeey-4-3.jpg
Mar 31, 2017 | Boating
Is there no reverse, goes forward but won't go in reverse
Outboard won't go into reverse ?? - General Discussion Forum ' In ...
www.in-depthoutdoors.com > ... > General Discussion Forum
Aug 9, 2006 - 8 posts - ‎7 authors
There's 2 cables that go into my outboard. ... It would have forward just fine but it would not shift into reverse. Assuming it's a wheel boat does the throttle handle go intoreverse but reverse doesnt work or does it not even ... Here are instructions to recover your old idofishing.com or idohunting.com account:.
Boat won't go in reverse - Lake-Link.com
www.lake-link.com/forums/boats-motors/.../Boat-wont-go-in-reverse
Sep 23, 2013 - 4 posts - ‎3 authors
Fishing Boards - Boats & Motors: Boat won't go in reverse. ... Forward seems to be working OK, but reverse just won't engage. ... I'm not sure if this is something at the throttle control end or something wrong at the motor. Any thoughts ... Looks like there'sa piece missing that's supposed to hold that in place.
Help! Will go in Reverse but not Forward gear! - The Hull Truth ...
www.thehulltruth.com/boating.../526873-help-will-go-reverse-but-not-f...
Jul 30, 2013 - 8 posts - ‎5 authors
Whether you're researching a new boat, or are a seasoned Captain, ... and it was notengaging fully into forward gear, but into reverse just fine. ... I'm a little dumbfounded as to why it will lock the prop when it's not running, but won't go into forward gear when it is ... While your there, change out the bellows. Mercury 125 won't go into reverse - The Hull Truth ...
Mar 17, 2014
Mercury 25 Horse Won't Shift into Reverse
Apr 5, 2009
90hp Yamha won't go in reverse & more - The Hull ...
Oct 4, 2007
Boat wont go forward or reverse - The Hull Truth ...
Jun 6, 2006
More results from www.thehulltruth.com
Dec 16, 2015 | Boating
Looking to buy used waverunners.one is 98 yamaha gp 800 93hrs. limited,the other is95 seadoo gts580cc 177hrs.what should the compression test reading be and what else should i check? mav7273@aol.com
For a motor to run the compression needs to be over 110 PSI. The normal compression will be between 130 PSI and 175 PSI . What is important is that both or all three cylinders be with in 5 to 10 PSI of each other. If one cylinder has much lower compression than another it is an indication that motor work is necessary to fix the imbalance. With older boats it is always a good idea to pull the motors and replace the crankshaft end seals. Also it is not a boat if it does not float. Inspect the hull for damage, cracks , holes, bashes/bruises, these will need to be repaired. Figure out how to look into the intake grate and inspect the impeller and mated surface for nicks damage. Seadoo's have a replaceable plastic ring around the impeller ($80) that is easily torn up by rocks and debris. If the gap between the impeller and the ring is wide you will lose significant thrust. Only your own sweat equity will make a boat needing a lot of work a good deal. Happy Riding.
Apr 04, 2011 | Yamaha 12V Air Pump
I have a new unit to fit. Can the transducer be mounted inside the hull? It currently gives me strange readings whether inside or out but we are on dry land - if that makes a difference
there are two kinds or transducers out there on the market --- some that can be mounted inside the hull and others that need to be mounted on the outside of the hull, the instruction manual should indicate which transducer you have. AND YES the transducer will only work when you are on the water --- the readings on land are no good and it will not work. install it on the boat and then test the unit on the water. BUT if you do want to test the unit before you install it to the boat you can always take the boat out to a lake ( or wherever ' on the water ' ) and mount the transducer to a long dowel or stick and hang it over the edge of the boat and this will work fine for testing.
' fish on and have fun '
c...
Dec 31, 2010 | Eagle Cuda 242 Fishfinder
I have around 1988 mariner 40hp new water pump still doesnt pump much water with hose hooked to it . u can put in the lake it works fine . whats the prolbem
The volume of water is less on the hose and water pressure in the lake is higher. You are also getting a different operating angle on the boat, because the transom is the low end of the boat.
The cuffs are just for testing and many of the new ones will indicate that you do not run the engine above idle with cuffs on.
Mar 12, 2010 | Boating
CHANGE STUDS ON BOAT
http://www.sailnet.com/forums/gear-maintenance/49777-dropping-keel.html
I found this site for you, I have never been involved in pulling a keel or removing lead, so you are on your own, check this out.
Feb 22, 2010 | Boating
How do iI chose a fishing boat?
There are three styles of regular fishing boats; deep v, regular v or modified v. The v determines how well the boat cuts through the depth of the water. The deep v is better suited for large lakes because they can handle heavy waves better. Regular "v" is more appropriate for smaller lakes and a man made body of water. As the water is not as deep and the waves are not as heavy, this type of boat is able to handle the situation. The modified v is the most popular version. It is capable of handling speed best. Most fishing boats on the market today are made of fiberglass or aluminum. What is best for your fishing situation? Do you want to fish in large lakes or small lakes? The options are endless. There are several classes of fishing boats for different situations. All purpose fishing boats are great for your basic fishing needs. This type of boat has space for some bench seats, fishing gear and a simple steering station. They are made of either fiberglass or aluminum and are between 15 and 20 feet long. Another type of fishing boat is a bass boat, which comes fully equipped with space for rods and fishing gear. The boat is fully built with electronics and livewells. This boat also is made out of fiberglass and aluminum. The advantage to this type of boat is it is made especially to catch bass, fast. The third type of fishing boat is the center-console. It allows a fisherman to angle from any place on the deck. The control center is located in the center. Depending on the size of the boat they can be used offshore as well as near. Flats boats are mostly made up of fiberglass. The advantage of these boats is they allow easier angling access to saltwater flat fish. Another advantage it has is a poling platform that allows for fish spotting. Finally, a casting deck allows the angler to keep control. This makes this ype of boat convenient for fishing. The final category of fishing boats is the fun boat because it combines the motor of a yacht and the functionality of large a cockpit to work trophy fish and bring them on board. If ou are a fishing fanatic then it is important to have all the things that you need to make your fishing trip a success. Fishing boats are definitely the finishing touch to a nice fishing trip.
Dec 01, 2008 | Sea and Sea Sea Eagle Inflatable Fishing...
Dynamite 32 Marine Inboard Engine Logo
Top Dynamite Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Dynamite Toy Expert? Answer questions, earn points and help others
