Question about Lexmark X73 All-In-One InkJet Printer
Lexmark X73 not pulling paper through properly, overprinting lines, part printing documents and printing some lines in colour shadowing the black print. I have used different grades of paper but still the same.
  • 241 Answers
Your printer's rollers sound like they are worn along the paper path. I suggest you taking your printer in to have a maintenance cleaning or have the rollers replaced. This will resolve your issues.
Posted on May 28, 2010
  • irby hartley Nov 11, 2010
    Maybe, but will the cost be more than buying a new one??? Alternately, can one dissaemble the unit and replace the roller(s) oneself??
    Why is this unit plagued with simple mechanical paper feed problems while the rest of the unit semingly performs well????
  • Sheri McMichael Nov 11, 2010
    Rollers get worn down from general usage. They could also just need a cleaning. You can contact Lexmark for replacement parts or go to a printer parts dealer online and see if you can get replacement rollers (which don't cost much a few dollars).
Printed copy will not feed out line by line and finally will not feed the printed page. How to get it to work properly?
There could be something blocking the paper path that's not allowing the paper to not go all the way through the feeder. Try to open the printer and access the cartridge area. Remove the cartridges. Check for any foreign objects blocking the paper path. Rebrick your printer by removing the power adapter (black box found on the back of your printer where the power cord is plugged in) and then re-plug after 30 seconds. When your printer turns back on, re-insert your cartridges. Then try print your document again to verify that the problem is fixed.
Nov 10, 2011 | Lexmark X73 All-In-One InkJet Printer
My Lexmark X73 made a snapping noise and stopped
My printer did the same thing, after tearing into it, I found one of the plastic gears had broke in two.
Aug 08, 2009 | Lexmark X73 All-In-One InkJet Printer
Printer works, copier and scanner do not
you might try enabling bi-directional printer support in printer properties, if its paralell cable then it is in bios, epp or ecp.
Jul 27, 2009 | Lexmark X73 All-In-One InkJet Printer
Mono color
These models use a "3 colour" printing process. In other words, these printers do not contain black ink when the BC-05 colour cartridge is installed. To produce black print, a 3 colour printer mixes an equal amount of the three primary colours. This process is known as "composite" black.
As the ink in the cartridge runs out, one of the three primary colours will run out first, depending on the material that has been printed. After one of the three colours has depleted, this colour will be missing from the mixture required to print black, and the print will change colour. This is the indication that the cartridge needs to be replaced. Usually the remaining colours in the cartridge will run out soon afterwards.
Rate the solution as appropriate !
Feb 07, 2009 | Lexmark X7170 All-In-One InkJet Printer
OKI C5100 alignment issues, I think
FROM YOUR USEWR MANUAL>>>>>>>
In colour menu
AJUST REGISTRATION, press EXECUTE
Performs automatic colour registration
adjustment. Normally this is done on power
on and when the top cover is opened and
then closed. This process accurately aligns
the cyan, magenta and yellow images to the
black image.
Use oki drums and toners, clean led heads
Dec 19, 2008 | OKI C5100n Laser Printer
Lexmark x5470 printer printing blue horizontal lines on coloured documents
hi
try to perform maintenance of your printer
on the setting
and open your printer clean up the nozzle
use alcohol and cotton buds and then placed it back properly!!
Nov 10, 2008 | Lexmark X5470 All-In-One InkJet Printer
Lexmark X73 print/paper problem
Same problem here. Went thru a few tests with Lexmark but didnt help. They next said it would be best to get new one since repair cost would be higher. Thru front door I do see a spring that moves freely. That must be broke. After their help they sent email for 20% off.
Sep 12, 2007 | Lexmark X73 All-In-One InkJet Printer
Unable to print properly keeps printing on one line
Sounds like there is something jammed in the paper feeder, or maby its the paper feeder itself. Check to see if the path the paper follows through the feeder is completely clear. Sometimes paper is left in the feeder from previous paper jams.
Aug 07, 2007 | Lexmark X73 All-In-One InkJet Printer
Printing mostly blue with lines across page
I have the same problem that you are haveing, I changed the ink ,both black and color, and it hasen't helped any, I wanted to get a new copy and printer machine but I don't want to get one and have the same problem. I have runined a lot of print paper trying something else new. I am open to all suggestons. thanks Ken.
Dec 03, 2006 | Lexmark X73 All-In-One InkJet Printer
Lexmark X73 All-In-One InkJet Printer Logo
406 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
