Question about Janome Memorycraft 6500P Computerized Sewing Machine
Thread take up lever seems to have a metal clip showing that I didn't see before and the machine bounces the bobbin when it sews. HELP doesn't sew very well either.
    New Friend:
  • 194 Answers
The take up lever does have a little metal clip/spring that keeps the thread from getting out of it once it is threaded. It should just lay flat against the lever. If the bobbin is bouncing, it will be the wrong bobbin is being used or the bobbin case is damaged and vibrating. Take the thread off the machine and the bobbin out, if it sounds noisy with no bobbin then I suspect you need a new bobbin case.
Posted on Jun 03, 2010
Sewing Machine is unthreading itself.
I don't know the answer to your question but I have a thought - someone recently asked why her sewing machine motor was running backwards.
I wonder has your machine motor suddenly started running backwards and if so would that cause your problem?
Jun 22, 2016 | Sewing Machines
Showing E6
You receive the error message E6 when the motor locked up because thread is tangled or the machine is seizing up.
Remove the tangled thread, it it still happens that means your machine is seizing and requires service.
Apr 30, 2014 | Brother CS-8060 Computerized Sewing...
Machine jams after 4 or 5 stitches. Bobbin thread locks up.
try these suggestions
change the needle
make sure the thread doesn't come off the thread take up lever--this
can jam the machine
make sure the bobbin is turned the right way in the bobbin case--this
can cause problems if the bobbin is turned the wrong way
make sure the bobbin is not warped or damaged
make sure there are no burrs in the bobbin area or on the needle
plate
Oct 16, 2012 | Singer 8280 Mechanical Sewing Machine
Problems threading bobbin
Although you have a Husqvarna sewing machine, the graphics and instructions at Singer are the same as for other brands.
http://www.singerco.com/resources/operation_basics.html
Choose the type bobbin your machine has - one is vertical with a metal case and the other type is a horizontal drop-in type.
The site also shows how to raise the bobbin thread.
When threading any sewing machine, be sure to do so with the presser foot up. Not doing so can have a negative impact on how the tension control works and the quality of the stitch.
Mar 01, 2010 | Husqvarna Sewing Machines
Bobbin tension problem with kenmore model 385.16231300
If You have a drop in bobbin you will have to remove the hook and adjust the tension, however try adjusting the top tension before you remove the hook.
Jul 17, 2009 | Kenmore Drop-In Bobbin 505S-21BH...
Bobbin Thread Doesn't Join the Upper Thread
Have you lowered the presser foot lever? It is the lever behind the needle that makes the foot go down. Do you put the bobbin in the machine from the top of the machine or from the front? In either case, you need to make sure the bobbin thread has clicked into the tension slot in the bobbin case. The bobbin case is the part of the machine that the bobbin sits in. It will have some kind of narrow cut out with a thin metal shaped piece half covering the opening. The thread has to go down into the cut out piece and click down beside the metal piece. You will hear a faint "click" when it is in place. Very hard to describe, but easy to show someone! Write back if this is not helpful to you. Also tell us your machine model.
May 04, 2009 | Sewing Machines
Threading lower bobbin
There are some different bobbin cases for different machines but the one you have is a pretty common one with a finger sticking out on top. If you examine the bobbin case you will see a slot on the side of it and there is another piece of metal screwed onto it. This is the tension they are describing.
To thread it properly, turn the bobbincase upside down and insert the bobbin in the case so you can see it. Place your thumb on top of the bobbin and pull the thread through the slot on the side of the case and under the piece of metal(the lower tension) which I described to you earlier.. When you have done that, remove your thumb from the bobbin and pull on the thread. It should have some tension on it.
Next,placing a thumb or finger on the bobbin to keep it from falling out, turn the bobbin case over.
Keeping the finger sticking up lift the lever on the
front of the case and insert the bobbin and bobbin case onto the spindle inside the hook assembly(The part that is in the bottom of the machine that turns when the hand wheel is turned.) Don't worry about the thread that is sticking out.
Holding the upper thread under the presser foot ,turn the handwheel towards you until the top thread pulls the lower thread to the top. Pull the thread to the left of the machine, insert your fabric, lower the presser foot and begin sewing
One more thing , The finger sticking up on the bobbin case will go into a slot on the ring holding the hook inside the machine.
Hope this solves your problem.
Be sure you thread the upper part properly. It should go through the tension, then the take up lever and then the needle. Tension should be set at around 5
sewman7
Jan 17, 2009 | Brother LS-2125 Mechanical Sewing Machine
Kenmore Model 385.16231300
I discovered the same problem. What I figured out (after having the machine "repaired" several times) is that it seems as if the bobbin type may be the suspect. I started looking closely and it seems as if I have 2 different types of bobbins. So, I tried both types. Since I don't know the bobbin number(s), you will have to put up with my description .... the bobbin that is flat, top & bottom, seems to bunch up. The bobbin "bounces" when I sew. The bobbins that are rounded on the top and bottom don't seem to "bounce" and it doesn't bunch up the lower thread. Now, I have read my manual front to back and it does not say what bobbin type or number to use. So, if anyone knows, it would be a great help. I am assuming the correct bobbin is the "class 66" bobbin. Does anyone know for sure?
Dec 11, 2007 | Kenmore 756A-30BH Mechanical Sewing...
Janome Memorycraft 6500P Computerized Sewing Machine Logo
144 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
