Question about Hansol H950 19" LCD Monitor
Hi :)
I have a problem, i purchased the Hansol H950 19" LCD Monitor and it doesnt work. the screen go's black and if i press the source button it flashes on and off and sometimes i can see my desktop. It does this on other computers i plug it into aswell.. how can i fix this?
If you can help me that would be amazing :) I really appreciate this
Sincerley,
Alex
Thank you
  • 8,617 Answers
Some of those monitors have had a problem where the large HDMI cable attaches to the back of the monitor. Try inserting the HDMI cable then instead of tightening the screw supports power up the monitor and wiggle it slightly if the monitor works then the problem is in the connector and may need to be resolderd on the inside. have you tried using another HDMI cable to rule out that the cable itself isnt defective?
Posted on Apr 07, 2008
Hi, My Hansol H550 used to come on when my PC tower was booting up, but now I have to press the green on/off button. BUt unfortunately, after pressing the on off button the screen only comes on for a split...
Sounds like there is no input to the monitor. Check the video cable(the one with the screws). Even if it looks plugged in, unplug it and replug it at both ends.
Feb 27, 2011 | Hansol H550 15" LCD Monitor
Brightness
open the monitor you will look big black part called EHT you will see the movable shaft on it rotate it by screw driver in active supply monitor see on screen suficient brightness and stop you will be satisfied
Nov 21, 2008 | Hansol 500 A Monitor
H950
The backlight power supply in the H950 series suffers from a manufacturing defect. Hansol might replace the unit even if it's not covered by warranty anymore. Contact them.
Otherwise (and if you have electronics skills), replace the electrolytic caps in the monitor's power supply. Take proper high voltage precautions!
  • Disconnect mains
  • Wait at least one day for caps to discharge a bit
  • Remove monitor stand (four screws)
  • Put the monitor face-down on the table, plugs facing to you
  • Remove back cover (snap-in, difficult to open without minor damage) - be cautious: front buttons are connected using a rather short cable, do NOT try to remove front cover
  • Remove EMV casing screws (four screws) and ground wire
  • Disconnect CCFL tubes (four connectors), noting connector orientation
  • Disconnect front buttons pcb
  • Lift EMV casing side facing to you
  • Disconnect power supply board (left) from signal board
  • Unscrew/remove power supply board - caution: C12 is likely to store mains voltage even after days!
  • Replace caps (C34 and C66 are likely failure candidates for IPHS19-S rev1.2 boards; you might also replace C31, C32, and C35 while you are at it) - higher voltage and temperature rating are okay, capacity has to match
  • Assemble everything again
Nov 10, 2008 | Hansol H950 19" LCD Monitor
Hansol H950
  • Disconnect mains
Jun 26, 2008 | Hansol H950 19" LCD Monitor
Spare parts
The best bet is to try ebay.
What do you mean by control panel? the part that does all the power or stuff?
May 31, 2008 | Spa Parts Plus PANEL, TOPSIDE, DUPLEX...
Hansol H950 19
Most likely the power supply, or the back-plane lamps, or the back-plane supply, or a defect on one of the processor boards is loading the supply too much, or any combinations of these are defective. You will have to have a source to try the boards to fix the monitor. I would suggest to find the authorized service rep for your monitor. They will have to service it for you. If the monitor is out of warranty, the fix will not be cheap!
Jerry G.
Apr 07, 2008 | Hansol H950 19" LCD Monitor
Hansol Mazellan 500A is it not compatible with 128MB Video Card?
your monitor does not support the screen resolution that your windows install is set to. hook your pc back up to your computer guys monitor, and reduce the screen resolution, then hook it back up to your monitor.
Jan 08, 2008 | Hansol 500 A Monitor
Hansol H950 19" LCD Monitor Logo
245 people viewed this question
Top Hansol Computers & Internet Experts
Matthew Spark
Matthew Spark
Cleverer2
k24674
Are you a Hansol Computer and Internet Expert? Answer questions, earn points and help others
