Question about Toshiba 50H71 50" Rear Projection Television
Toshiba 50H71 TV, blown fuse 852, replaced STK392-110
Hi I have a Toshiba 50H71 TV, had a blown fuse 852, and replaced convergence ICs STK392-110 with STK392-110 T. Now TV will power on for a second or two you can her HV then will not power on again unless you unplug from outlet. I have soldering and TV fixing experience, also check soldering spots and jumpers 010, 050 as many suggested on this post.
  • 3 more comments
  • miran35 May 28, 2010
    Hi
    it is not arcing problem.
    power supply turn off after one of it's conditions is not met
  • miran35 May 29, 2010
    Hi
    I have service manual, yes it is Over load problem or one of the modules do not work properly, so is there a way to find out which module is causing shutting down
    Miran
    Hi
    There is not enough time to measure voltage because TV turns off in 1 sec
    Hey
    Please read may first post, "I have soldering and TV fixing experience" there so I have millimeter, oscilloscope(I hope you know what it is), My question is again how do I find which module is shutting down power supply, Can I remove one of the fuses ex F889 for audio amp Vcc or F470 120V and TV will still power on?
    Miran
    OK let's live jokes aside and get serious, You replayed 8 times and there wasn't any real answer ping pointing yet.
    Please do not user abbreviations like DMM or w.r.t because I do not know what they mean (English is my second language) Yes I did check stand by regulator Q840 for 5v. and red stand by LED is blinking at the front.
  • 4,889 Answers
What do you mean by can hear HV? Does it sound like some kind of high pitched buzzing noise? Did you check for arcing near the flyback?
Posted on May 28, 2010
  • 5 more comments
    Hi
    I mean HV starts for a sec or two then turn off looks like on or more conditions are not meet.
    Is there a way to see which condition is missing?
    Miran
  • eagle338
    eagle338 May 28, 2010
    Did you check for arcing near the flyback like I said in my previous post?
  • eagle338
    eagle338 May 29, 2010
    Ok.. DO you hear any clicking noise before it turns off. Over load on one or more circuits cause the relays to kick in and turn off the set to prevent damage. I have a service manual for this model so let me know when you are here and we will finish this today.
  • eagle338
    Since you have the service manual, yo should start by checking the specified test points marked in the manual especially near the voltage regulators. Try it and let me know.
  • eagle338
    That is why we are using a digital multimeter. Most digital multimeters have a voltage of their own. If your multimeter has that feature touch the probes on the anode and cathode of the voltage regulator and set the digital multimeter in ohm meter mode. Measure the resistance across it. Also check the voltage across it then report back along with the IC number and the voltage recorded. The only question is do you have such a meter?
  • eagle338
    I know what an oscilloscope is. Its for getting the wave forms. Now if you have an oscilloscope you should also know that there is something known as residual voltages. Your primary targets are the 3 pin voltage regulator ICs. Measure voltage w.r.t ground. I know the set is off but your DMM should do the trick. Trust me on this. I wave worked on 10's of Toshiba sets and I have helped people fix their sets. Thats how I got the Toshiba badge that you are seeing. For any reason if you cannot follow my instructions, please let me know and I will break it down for you and I will tell w.r.t to the service manual that you have.
  • eagle338
    eagle338 May 30, 2010
    That my friend is because you have ignored my advice. Sorry about the abbrevations though. As for the schematic looks like you don't have a comprehensive schematic. I see 3 lines 9V, 5V and 3.3V if the regulators are normal then you would have all 3 at proper ranges. Did you test them and see if any of them are overloaded? P.S if your service manual does not have a detailed schematic please let me know and I will give it to you. I am only trying to help you.
Can not adjust red convergence up or down it will adjust left or right
replace the convergence ICs and resistors. You can get the repair kit for your model at the following link. The kit contains the parts and instructions.
http://servicemanuals.vstore.ca/product_info.php/pName/toshiba-50h71--50h81-convergence-repair-kit/cName/convergence-repair-kits
Jul 10, 2009 | Toshiba 50H81 50" Rear Projection...
Convergence amp
You usually have to replace the two ICs at the same time along with resistors to get the longest life from the Convergence amps. You can get the repair kit for your model at the following link which contains both ICs and all 6 resistors plus instructions with pictures that explain how to do the repair yourself. Heres a link to the correct kit for your model Toshiba.
May 18, 2009 | Televison & Video
Getting 2 images on top of each other on Toshiba 50H71
How To Enter Service Menu is what you need to know and replace both of your STKs these ic chips control convergence.If they are STK392-110s use STK392-180s better ics.
Dec 18, 2008 | Toshiba 50H71 50" Rear Projection...
42H83 Convergence
Yes the convergence ICs need to be replaced, however so dont the six 1.8 ohm 1watt resistors as Toshiba recomends replacing those six resistors when the ICs are changed. You can get the 50H71 / 50H82 Convergence repair kit as the 42H83 is identical to the 50H71 series, so the kit will work for your model. Heres the link where you can get the kit.
Aug 10, 2008 | Toshiba 42H83 42" Rear Projection...
ICS Convergence
Did you also check to make sure both pico fuse are good ?
Jun 09, 2008 | Toshiba 50H71 50" Rear Projection...
Toshiba 50H71 projection tv
the convergence ICs have shorted and thats whats shutting down the set. Its an easy repair you have to replace both the Convergence ICs they are STK392-110 ICs you can get replacements at the following link and they provide free instalation instructions with pictures and also free tech support. Heres the link.
May 31, 2008 | Televison & Video
Toshiba 50H71
you need to replace both the convergence ICs they are STK392-110 you can get new replacement ICs at the following link and they will provide free instalation instructions with pictures so you can do the repair yourself. Heres the link.
May 29, 2008 | Toshiba 50H71 50" Rear Projection...
Toshiba 50h71 red light after fixing the convergence chips
Did you check to be certain none of the resistors were burned or open that power the ICs ? This is fairly common for one or two of the convergenvce resistors to be open when the ICs go out. Also double check the iC pins to insure that none of the pins are bridged with solder. If you need more assistance please let me know.
May 19, 2008 | Toshiba 50H71 50" Rear Projection...
You need to replace both of the convergence ICs they are number STK392-110 you can get new replacement ICs at the following link and they provide free instalation instructions so you can do the repair yourself which tkes about 30 minutes to do and saves you about 400 dollars. heres the link.
May 18, 2008 | Toshiba 50H71 50" Rear Projection...
Toshiba 50H71 50 in. Rear... Problem
set most likely has bad convergence ics J.D.W.
Mar 26, 2008 | Toshiba 50H71 50" Rear Projection...
Toshiba 50H71 50" Rear Projection Television Logo
103 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
