Question about Panasonic PV-DV402 Mini DV Digital Camcorder
Palmcorder PV-DV402 doesn't work with tape inserted
My panasonic PV-DV402 no longer works when a tape is inserted. Instead the power light blinks slowly, none of the buttons (ie. MENU) respond, and the camera shuts off after a minute or so. It has worked fine for years. I have removed and recharged the battery etc. and can think of nothing else to try.
If a tape is NOT inserted, then the camera appears to work fine - though of course it's not very useful
  • Panasonic Master
  • 5,412 Answers
Have you tried with different tapes ? Could be that this one is binding inside, and the camcorder cannot move it. Will it fast forward and rewind ?
Posted on Jul 22, 2017
  • 19 Answers
SOURCE: "Tape Not Inserted" on Panasonic PV-DV203 palmcorder
hai, If you are service engineer you can do this problem, Please, check the cassette IN sensing Switch. The place of the Switch is right side of the mechanism, Clean S/w with IPA solution & check. It will be ok or other wise you have replace s/w or mechanism.
Posted on Nov 10, 2006
SOURCE: palmcorder pv-L452D
Typical CCD sensor problem ...replace CCD block. This is normally due to a faulty component being installed so even if your camera is out of warranty try to have it done free of charge.
Posted on Sep 07, 2007
SOURCE: Panasonic Palmcorder PV-GS15 Software
What u need at the minimum is an addon card for downloading(refer to the manual for the exact No. it is something like IEEE1395 or so) Then connect the cam to this thro' the cable.
If u use windows xp u have a movie maker. u can use that s/w. Else try to get pinnacle studio or studio 8 to dump and edit etc.
all the best.
Posted on Dec 28, 2007
The Machine
  • 788 Answers
SOURCE: Panasonic PV-DV402 with Windows Vista
That is the sad truth about Vista, manufacturers are either slow at providing support for older equipement or ignoring them altogether. Panasonic has not upgraded the software for that camera since 2003. You best solution would be to create a second partition on your computer and install Windows XP in a dual boot configuration, but that would cause problems as your should do it the other way around (install XP then Vista). Or you could buy a cheap XP computer (a used one or value one). Or you could upgrade to a newer camera.
Although you may luck out downloading software for a newer camera from panasonic, maybe this driver might work: ftp://ftp.panasonic.com/pub/Panasonic/Drivers/capture/ComMass.zip
Does the camera have firewire? Did you try connecting it that was?
Posted on Jan 29, 2008
Double Red Flashing Light
I just posted another solution on the main link. Basically hook up the unit to the ac adapter, reset the menu to get rid of the blinking red light, and then put a new tape in on camera mode. The unit was able to record again and also work in camera mode.
Jun 09, 2009 | Panasonic Palmcorder PV-DV53 Mini DV...
hi there
you can try and check panasonics home site for compatibility issues regard there products to windows vista.
hope this would resolved your problem.
Jan 29, 2008 | Panasonic PV-DV402 Mini DV Digital...
PANASONIC PALMCORDER IQ (PV-IQ204
Try removing the battery. While holding the eject button, re-insert the battery.
Dec 06, 2008 | Panasonic Palmcorder PV-GS15 Mini DV...
Panasonic Palmcorder PV-43 turns off with a tape inside
you definetly have a tape mech fault and this is going to have to go for repairs to panasonic.
Apr 25, 2008 | Panasonic Palmcorder PV-GS12 Mini DV...
Blinking power light
call panasonic if there are that many posts maybe it is a recall issue and they should know about it.
Oct 03, 2017 | Panasonic Palmcorder PV-DV52 Mini DV...
Won't work with tape installed
I had this same problem. At my wedding, and didn't get to record it because of it. When I got home I put a new tape in and worked fine. It was just a bad tape.
Oct 27, 2007 | Panasonic Palmcorder PV-DV102 Mini DV...
Panasonic dv53
. Take out the tape - AND TURN THE CAMERA POWER ON
2. press the menu button (near the viewfinder)
3. Use he wheel on top next to the viewfinderto scroll through the choices
4. Choose "display setup" by pushing the wheel in
5. Choose "C. Rest" by pushing the wheel in
6. Turn camera off
7. Next time you turn camera on y ou should be able to view tapes and record.
IT DID NOT WORK THE FISRT TIME SO I PUT MY FINGER IN TO TRY TO GENTLY PUSH BUTTON WHEN I TOOK THE TAPE OFF AND THEN TRIED SOLUTION ABOVE AGAIN, AND THIS TIME, IT WORKED. BUT PLEASE DONT INSERT YOUR FINGERS IN AS I DID TRY THE SOLUTION 2 OR THREE TIME IT SHOULD BE OK, HOPE THIS WORKS FOR YOU
Apr 22, 2007 | Panasonic Palmcorder PV-DV53 Mini DV...
Chewing up mini-dv tapes
These type of problems usually result from damage to the tape transport mechanism, Unfortunately they are impossible to fully diagnose without a physical examination of the mechanism.
There is not a magic tweak for this i'm afraid.
Wish i could be more help
Jan 11, 2007 | Panasonic Palmcorder PV-DV102 Mini DV...
Nov 08, 2006 | Panasonic Palmcorder PV-DV203 Mini DV...
Panasonic PV-DV402 Mini DV Digital Camcorder Logo
95 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
