Question about KitchenAid KAWS750L Top Load Washer
I have a Kitchenaid washer model # KAWS750L, leaking at bottom
I have a Kitchenaid washer model # KAWS750L, and it is leaking from the bottom . What can I do?
    Novelist:
  • 77 Answers
The most common leak in a KitchenAid washer is from the water pump. The easiest way to see is slightly tilt it up with a small load. If there are many clothes and water in the tub it will be to heavy. Get a light, and tilt the washer up a few inches. Prop it up with something even. Now, lay on the floor and as the washer is running watch for the water leak. The pump is at the front of the washer, directly in the middle. so it's only about 1-2 inches behind the front of the cabinet. I would be very surprised if it was anything but the pump.
The pump you will need is one of two. I've looked up your model number. After the KAWS750L there is either a Q or a T followed by a number. That letter and number make the difference. This pump can be bought for as low as $40 up to $70. It depends on the pump, and where you buy it from :)
Posted on May 29, 2010
Kitchenaid top loading washer makes noise when filling
Did you check the hot and cold shut off valves if they have calcium build up it might make a noise. Try replacing them.
Jun 20, 2012 | KitchenAid KAWS750L Top Load Washer
How do remove the top of machine to get at the mixing valve located at top of machine, valve is leaking
First unplug washer, then unscrew screw#8 in graphic(1 on each side of bottom panel).
SEE PICTURE
Then remove 2 clamps#6 in picture
make sure you disconnect any wires like the lid switch and pull cabinet forward towards you and put aside. and you are done. reverse to install.
Feb 09, 2011 | KitchenAid KAWS750L Top Load Washer
Model KAWE770BALO coupler between motor and transmission needs to be replaced. Should I do this from the back or bottom?
NEITHER. The back panel is not supposed to come off on this washer and working from the bottom requires you to tilt the washer backwards which can cause the gearcase (transmission) oil to leak through the top breather hole. You need to remove the exterior washer case in order to gain full access to the motor coupling. The procedure is much simpler, then it sounds. the following link explains:
http://www.fixya.com/support/r3574231-replacing_a_motor_coupling
Your washer is manufactured by Whirlpool, so these instrucitons do apply. The part number for a replacement coupling is inlcuded in the link I provided. Replacements can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. The first three sites also have exploded view parts illustrations to assist you with locating and properly identify any parts you may need.
If you have any questions, post back and let me know. I hope this helps you.
Sep 07, 2010 | KitchenAid KAWS750L Top Load Washer
How do I remove the console on my Kitchenaid Top load washer
remove the 2 Phillips head screws that are in the left and right end caps of the console, in the front corners. remove nothing from the rear of the cabinet!! after removing those 2 Phillips head screws slide the bottom of the console forward about 1/2 inch the lift up and it will pivot right up and over on the hinges that are attached in the upper corners of the console..
good luck and have fun.
Aug 26, 2010 | KitchenAid KAWS750L Top Load Washer
What size is my washer kitchenaid kaws750gq0
good day,
hope this link below will solve your problem.
kitchen
Dec 12, 2009 | KitchenAid KAWS750L Top Load Washer
Kitchenaid topload washer about 3 yrs old, started leaking from bottom, front. Checked hoses at faucet and washer, all tight no leaks there. Seem to be coming from under the front lower lip of washer.
it's the pump. release the control panel and flip back on hinges. pop the retainer clips and unplug the lid switch harness on top. pull entire white part of cabinet back and up..pump is front center.
Jun 14, 2009 | KitchenAid KAWS750L Top Load Washer
KitchenAid Model KAWE564W
try using wet-dry vac on hot water inlet (they sometimes **** in garbage out of line), also check filter screen on hot side as it may be clogged.
Apr 18, 2008 | KitchenAid KAWS750L Top Load Washer
KitchenAid KAWS750L Top Load Washer Logo
568 people viewed this question
Top KitchenAid Washing Machines Experts
kj henriksen
kj henriksen
gbob59
Mike
Are you a KitchenAid Washing Machine Expert? Answer questions, earn points and help others
