Question about Garden
I have an 1995 Troy-Bilt GTX20 lawn tractor with a
I have a 1995 Troy-Bilt GTX20 lawn tractor with a 60'' mower. I believe the hydrolic control unit for the left turn steering has a leak inside the unit itself. Does anyone know if the unit can be rebuilt. The left turn steering works but looses turning force then wonders to the right. It looks like a drunk person has mowed the lawn. The right steering is ok and the motor, transaxel and all hydraulics operate great. I believe that it may just need an O-ring or gasket for the left steering but I don't want to take the unit apart if it can't be repaired. I have searched the internet for a new unit but it has been discontinued. I have also tried to find a used unit and still didn't have any success.Thanks for any help that anyone can give me.
  • NNYParts May 30, 2010
    Do you have any part numbers for the control?
4 Suggested Answers
lester482529
  • 226 Answers
SOURCE: I need a transaxel for a troy bilt lawn tractor
go to partstree.com put your make and model # in they should have what you need .hope this helps
Posted on Jul 29, 2009
mickey813
  • 472 Answers
SOURCE: Troy bilt lawn tractor that will not go in forward-just grinds
sounds like the trnns has some thing lose in it you will need to get to the shop
Posted on Oct 15, 2009
  • 196 Answers
SOURCE: Troy Bilt model 60TG I hit a small piece of wood and the tractor
If you haven't already, check to see if there is a hunk of wood wedged between the blade(s) and mower deck. I've seen that happen. I pried the hunk of wood out with a crowbar and life was good again. The second time, someone ran over a campfire log they didn't see under leaves last fall and bent the blade spindle. It basically froze the spindle in place even though there wasn't anything wedged in there. I removed the belt from the top of the mower deck and then it started just fine..... although the blades and shaft were toast and had to be replaced. If you can disengage the mower deck without removing the belt(s), try it if you haven't already. See if it starts that way. If not, the issue may be more serious such as a broken connecting rod in the engine. Try the simple stuff above first to troubleshoot the cause.
Posted on Apr 30, 2010
Troy bilt troubleshooting
what are you trying to troubleshoot? heres the troybilt link to get you started
http://www.troybilt.com/equipment/troybilt/lawn-mowers/lawn-mowers?facet=cas_f9_ntk_cs%253A%2522Zero%2bTurn%2bTractor%2522&sortBy=3?cm_mmc=Google-_-Mowers-_-Zero%20Turn-_-Sponsored&gclid=CjwKEAjwi6OeBRCCrZqp-qaQhhISJACrfbtAq_Hepy9R8IgJYw_E9HkmY0pum-PDxyoqjOrFfOWq-hoCAknw_wcB
Jul 17, 2014 | Troy Bilt 25HP VTwin Hydrostatic 50" Zero...
How to change the oil in the 7.75 self-propelled troy-bilt lawn mower.
I believe on that model it has to be pumped out. From the Fill hole.
Aug 20, 2010 | Troy-Bilt Garden
Troy-bilt bronco riding lawn mower choke problem
Check your air cleaner...then check fuel line from pump. Pull fuel line off carb make sure fuel is present. :)
Sep 07, 2009 | Garden
I have a Troy bilt 17hp 42 inch cut ride on lawn
yes they have a charging system, not like a car but a charging system one the less. as i said before either under or around the flywheel. some newer mowers also have an electronic regulator.
Jul 31, 2009 | Garden
Troy built lawn tractor won't start.changed plugs.
i have a troy bilt riding mower,i start the mower it only runs for 15 to 25 min's ,so i changed the coil to see if it would run long. but after a few minunts it stop again so i don't know if maybe it's my carb. what could it be.... help
Jul 03, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Troy Bilt Horse Lawn Tractor Transmission problems
you need to screw the transmision adjustment in so that it is push all the way in to gear.
Apr 21, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Garden Logo
176 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
