AWA DVD recorder Mod DR640. Have had power supply replaced and now on screen showing permantly channel, HDD and no disc. A red beam is coming from the rear and in the display a red/orange dot is there. AWA have not been able to assist and the technician that replaced the power supply has suggested that I use the factory default. Any suggestions?
  • 3 Answers
SOURCE: DVD Burning doesn't work..no Disc in Setup..
Been checking out my m/c and found that there are many -r & -rw discs the m/c does not recognise which gives rise to this problem. However the m/c does recognise VERBATIM discs and I have been able to record and dub to them with no problems.
Posted on Mar 11, 2008
SOURCE: Problem Recording HDD to DVD-R
I had a few problems with my philips 3450 - I downloaded the latest software upgrade at www.philips.com/support , and my issues were resolved. Worth a shot...
Only other thing I can think of is you may have a faulty batch of DVD-Rs?
Best of luck!
Posted on Mar 15, 2008
SOURCE: dubbing hdd to dvd
I had the same problem I thought it was me!! Dooh but sent it back and JVC very kindly replaced the DVD unit, I believe free of Charge and after is was out of warranty by a few months.
Well done JVC on this one.
Posted on Sep 07, 2008
SOURCE: Panasonic dvd/vhs player/recorder will not
I have the same problem and I can offer a solution only to get your disk back but not the error code thing. unplug the unit and all video/audio cords. Remove the 3 screws in the back and 2 along each side. Remove top. Remove3 screws holding DVD player in place. Remove and turn over DVD Player. See the motor in the bottom near the ejection door, under the sheet metal with the lopsided "Keyhole" in it. Just to the rear of that there is a piece of plastic (mine is white) with a tab and some tracks in it. in a moment you will apply pressure to the tab will slide it to the right. (if the ejection door is nearest to you and the pcboard attached to the bottom of the DVD player is furthest from you.) But before you do this you may want to turn the DVD player correct side up. This will alloy gravity to hold the disk in the tray when the tray is ejected. Now you can slide the tab to the right (or left if the DVD player is correct side up) Use some force on the tab. you are attempting to ramp up the speed on the ejection motor and still have some momentum built up after you reach the end of travel for the tab. If you have done every thing I have instructed then the ejection door should have opened and the tray should be partially exposed. Simply gently pull on the tray and then remove your disk. Now if you flip the DVD player back over, plug in the power cord, and hit the little "Reset" button, after a few moments the DVD will retract the tray. At this point unplug the power and reassembly the machine in reverse order as disassembly. Or simply throw the unit out because according to other posts on this and other sights, if you are getting the F60 or U99 error codes then it would appear that you have a bad Video board which is no longer available.... anyway I may have saved you $139.00 (At Panasonic) to extract your $20.00 video.
Posted on Feb 28, 2009
  • 4 Answers
SOURCE: LG RH188S DVD/HDD recorder. 'Please wait'
Try reformatting the harddisk, worked for me!
Posted on Jun 30, 2009
Why does the channel up or down sometimes not work?
It sounds to me like you have a fault in the tuner circuit. I suggest you take it on for service.
Oct 23, 2014 | Magnavox MDR537H/F7 DVD Recorder 1TB Hard...
My recorder show HOLD how to clear hold
Hello
Reset the unit to its factory settings by the following methods.
Press and hold CH Up and CH Down button on the main unit for about 5 seconds.
(Current channel line-up and television program list are cleared.)
Select "Yes" in "Restore Default Settings" in the SETUP menu.
This returns all values in the SETUP menus, except for the clock, channel settings, ratings
level, and on-screen language, to the default settings.
While the disc tray is open, press [DVD] then press and hold REC button and Play/ [PLAY/* 1.3] BUTTON on the main unit at the same time for 5 or more seconds
Press and hold POWER button on the main unit for 10 seconds. (The settings remain.)
OK.
Mar 24, 2011 | Panasonic DMR-EH60 DVD Recorder/HDD...
I have a Toshiba DVD Video Player Model SD 260. I
Hello, The problem could be dirt on the surface of the lens, you can clean this by removing the cover of the dvd player . Gently use a dry cotton bud to clean the lens because the lens is fragile. Insert the disc plate into the dvd player and press play, if it does not play try the second method. Ensure the cover of the player is open, connect the power plug to the mains socket and observe the lens if it beam a red light, Also check the ribbon cable use to connect the lens to the printed circuit board, then gently clean the lens with a dry cotton bud , insert the disc plate and press play to see if it play. If it does not play the disc, then this require a change of the lens
May 20, 2010 | Televison & Video
Awa dvd recorder dr711 can this be connected to a set top box
If it's like the DR620 it will only receive analogue from the TV aerial. I connect the AV out connections on my set box to the inlet AV on the recorder and watch and record through the recorder's "rear AV input" selection.
Jun 16, 2009 | Durabrand DVD-1002 DVD Player
Unable to record e.g MOVIE from TV to DVD disc
Just record the shows to the hdd and when your there then burn the shows into the dvd from the hdd.the dvd is pretty small it wont hold many shows.
Apr 27, 2009 | Televison & Video
How do you connect AWA plasma TV to AWA surround sound
Hi Map33_bm
It appears that your TV set is 2 channel stereo, so as there is no surround signal coded into the TV audio channels, thesurround sound does not process it.
I've posted a PDF in 'manuals' which you can check out.
Did this info help at all?
Regards, Clive.
Oct 28, 2017 | Televison & Video
Sansui SAN1880 80g dvd recorder no colour
Hi, I have a Sansui Model San1880, after I have manually program the TV channels, I don't get no sound at all only on the TV channels its got good pictures but no sound, would you please tell me what to do.
Thanks
Rod
Mar 01, 2008 | Sansui VRDVD5000 DVD Recorder/VCR
Can i record from tv to dvd
yes
make sure the cables are connected correctly, the manual will show that.
If the mwr20v6 has a tuner you must have the channel on the dvd set to the program, if it has no tuner, you must have your tv set to the correct channel.
Feb 13, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Best of luck!
Jan 16, 2008 | Philips DVDR3450H DVD Recorder/HDD...
Televison & Video Logo
152 people viewed this question
Top Televison & Video Experts
Electro Med Services...
