Question about Whirlpool Dishwashers
Hello, my dishwasher is not getting the dishes clean. They are getting wet, but not clean, and the soap is not getting rinsed out of the dispenser.
    President:
  • 949 Answers
It sounds like we are having trouble pumping the water around. I can walk you through things to check on that will help. In order to assist you best, I need to know the model number from the tag that is just inside the door.
Thanks
Posted on May 28, 2010
My soap dipenser is always FULL of water ater every use. What could be wrong
Is anything else in the dishwasher wet or has it all dried properly? Is all the soap gone when you check? If both of these are true, then it may not be an issue -- your soap dispenser gets rinsed to get the soap out and onto your dishes.
Sep 01, 2015 | Dishwashers
Model GSD2100R00BB - the soap dispenser opens and the arm extends but the dishes do not get clean, just wet and does not leave soap residue on the dishes.
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Aug 28, 2011 | GE Dishwashers
Dishwasher isn't dispensing soap or rinsing well.
prime the sink before starting the dw yo make sure hot water is getting there
Jun 01, 2010 | Asko 1385 Dishwasher
Soap dispenser problem?
Check the water supply. Start cycle then open the door after it fills and check water level and spray action. If everything is soaking wet, there is probablyl a pizza pan blocking the soap tray.
Jan 05, 2010 | Frigidaire 24 in. PLD2850 Built-in...
Dishwasher soap dispenser does not release(sometimes partially)and as a result dishes are not cleaning
the solenoide which pops open the soap lid may be faulty.
Better to poar your dishwashing powder or tablet in the bottom of the dishwasher tray until you get the machine repaired. You may want to do a prewash rinse first, then stop the machine and add your soap.
Make sure not to use too much soap. Just the normal amount as you would use in the soap dispenser.
Ash
Oct 27, 2009 | Dishwashers
The some dispenser and the rinse aid dispenser seem to be "stuck", soap door doesnt open and dishes appear streaky from no rinse aid. this happened after I cleaned the deposits from under the screen in the...
There is a solenoid which pops open the soap lid after the initial rinse.
If the solenoid or soap lid latch is faulty, you will need to replace it. In the interim just poar your soap in the bottom of the dishwasher tray before cycle starts.
Only use a little amount as per normal. Dishwashing tablets are best as it is a measured amount and has the rinse aid built in.
Good luck.
Ash
Oct 21, 2009 | Bosch Dishwashers
Dishwasher is not getting dishes clean. Water is
follow this link:
http://www.fixya.com/support/t2390397-dishwasher_acts_up
that guy gave me some good advice!
Jun 09, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Dirty dishes
If you have a water softener, you should use about half the recommended amount of soap. Never use a wet or paste detergent. As mentioned before, this unit should be under warranty.
Gene, in AZ
May 24, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher does not rinse clean
run the dishwasher empty: use 1/2 the amount of soap you usually use in the soap dispenser close it then put white vinegar in the open dispenser and, run the dishwasher
Apr 22, 2009 | Dishwashers
Dishwashers Logo
231 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
