Question about Yamaha RX-V1700 Receiver
Yamaha Amp RX-V1700B Receiver - no power to head unit
Yamaha Amp RX-V1700B 7.1 Channel Receiver - no power to head unit. Removed all cabling except power cord, will not switch on. Tried a different power cord and different outlets, did not help. Removed cover and checked fuse - fuse is ok. What can I check next - or is it straight in to the repair shop?
    Brigadier General:
  • 8,546 Answers
Go to the shop.
Posted on May 28, 2010
Testimonial: "Thanks - I came to the same conclusion myself - hopefully something simple and not too expensive."
Sound center
Replace center channel speaker with known good one. If no longer scratchy then the voice coil of removed unit is rubbing against the magnet pole and the speaker needs to be replaced. If the replacement speaker also sounds bad, then the amp for the center channel needs repair.
Nov 23, 2013 | Yamaha RX-V490 Receiver
Receiver shutdown
change your power regulator it is leaky and there are some diodes around the regulator change them also check the caps and some of the resistors some also can be faulty.good luck.
Jun 07, 2007 | Yamaha RX-V1500 Receiver
HOW DO I USE A EXTERNAL AMP LIKE A YAMAHA M-85 FOR MY CENTER CHANNEL ON MY RX-Z11 AV AMP
You should have preamp output jacks on the back of the receiver. Hook that up to your external amp input.
Jul 24, 2013 | Yamaha RX-Z11 11.2 Channels Receiver
Can I use an Ipod Dock with a Yamaha RX V490 receiver?
No, but you could still access the audio directly from the iPod...
Anything that has a headphone output can be adapted to feed an RCA cable pair for standard stereo to an amp or receiver. Get a cable like the one described here:
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10218&cs_id=1021804&p_id=665&seq=1&format=2
and connect it into any available analog input EXCEPT "Phono". Turn the MP3 player volume up.
http://www.retrevo.com/support/Yamaha-RX-V490-Receivers-manual/id/319ci975/t/2/
Dec 01, 2010 | Yamaha RX-V490 Receiver
Can you tell me please: where do you insert cables from a cable box to a Yamaha RX-V2500 receiver I appreciate any help you can give. OK. The cables that were attached to my cable box were removed when the...
the coaxial cable from outside is connected to in (box), coaxial cable from out to digital in (RX) digital out to TV... (try scrolling through source to cable/ or component if this is HD) (all other devices can be connect to RX also like dvd using Red Yellow White cable or S-video w/red & white)
Mar 12, 2010 | Yamaha RX-V2500 Receiver
NO INSTUCTION MANUAL. CAN NOT GET IT TO WORK AS A 2 CHANNEL AMP.
Click Yamaha Support and download required user manual of receiver to figure out to set it on 2 channel output.
Need further help, please intimate receiver model number.
Mar 18, 2009 | Yamaha RX-V870 Receiver
Yamaha RX-V757 No Left Channel Output - Video Sources Only
First - make sure it is not a defective cable by reversing the leads/colors on the inputs if problem then goes to the right channel then you know it is a bad cable/RCA, etc., connector. I would try that first.
Thanks,
dthomas
Feb 07, 2009 | Yamaha RX-V757 Receiver
Yamaha RX Z9 and two-channel system integration
The A-B speaker switch is intended to direct amplifier output to a pair of speakers in a different location when set to B.
Feb 26, 2017 | Televison & Video
Help setting up Yamaha RX-V461
Typically, only stereo inputs exist on any comsumer-grade receiver, and the actual decoding to 3, 4, 5, 6, and even 7.1 is done internal in the receiver. When a "placement" signal is detected by the receiver, the sound is routed to the correct speaker.Please refer to a user manual
..accordianman
May 01, 2008 | Denon AVR-4802 Receiver
Yamaha RX-V995 no power no audio [dead]
sounds like a short in the cpu of the unit
Mar 02, 2008 | Yamaha RX-V995 Receiver
Yamaha RX-V1700 Receiver Logo
607 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
