Question about Frigidaire FAC124 wall/Window Air Conditioner
Model FAC124P1A1 window unit, I connected the unit after being off for about 5 months and it tripped,it shot a spark from the outlet. The breaker and the outlet work but the unit wont turn on anymore. What happend? Will it cost a lot to repair?
3 Suggested Answers
SOURCE: FAC124P1A1 window unit
Frigidaire told me in an e-mail that there is a single motor, "with two shafts and water droplets hit the fan blades and are then sprayed on the condenser coils to cool them". This is by design, I guess.
Posted on Jul 18, 2008
  • 387 Answers
SOURCE: When compressor kicks in the
This appears to be a direct short internally to the compressor . you neede a ohm meter to test it .. not certain how old the unit is but if its a window unit and over 6 years old I would buy a new one. But it does no0t sound good. In the future when a unit trips the breaker and you reset it and it trips right away its best not to trip it again as it contaminate the inside of thye system and is very difficult to clean and expensive as well . those are my thoughts. It could be the outside fan but the way you decribe it tripping right away my money is on the compressor
Posted on Jul 21, 2011
Dryer trips breaker after only a few mins of operation
Check to power at outlet for 220 volts
Check the breaker for the correct amperage cut off.
If the unit had an obstruction in the air flow, it would not trip the breaker.
Try running the unit with just cool air and see if it trips the breaker.
Odds are, you have a defective breaker.
Also, if the home is newly built, check the panel for loose connections at the breaker.
Or you could try a different power outlet, like the hot water heater.
If the unit continues to trip breakers on other outlets, you may have a short in unit.
Apr 29, 2014 | LG DLE2140W Dryer
I have a kenmore Elite dryer it was working fine than blew the circuit breaker, I unpluged it reset the breaker pluged it back it and it sparked and blew the breaker again. I disconnect the motor in the...
If the dryer is tripping the circuit breaker, it's possible that the circuit breaker itself is malfunctioning. or a wire is loose to breaker.
There could be a loose connection in the outlet. A loose connection in the outlet could consist of wiring that is not functioning and is unable to properly manage current. The current needed by the dryer is being mishandled by the loosely connected outlet and drawing more power from the electrical system, tripping the circuit breaker. check outlet to find out !
Mar 29, 2012 | Dryers
When the welder is first turned on I can weld with gas for about 5 seconds. Then the breaker trips. ( i have the proper wiring and breaker). The more times I reset the breaker the shorter the weld time...
Hi:
Just make sure that if you are using an extension cable between your machine and the power outlet, this cable is at least a 12 gauge size, if you are using a 14 or 16 it's too small to handle the amps.
Other point is to check that your breaker is 20 or 30 Amp capacity.
Hope this help.
Sep 08, 2011 | Clarke Power Products Clarke 130EN...
I HAVE A FEDDERS AIR CONDITIONER MODEL AED24E7F-C THIS UNIT TRIPS THE RESET BUTTON ONCE IN A GREAT WHILE IT RUNS FOR HOURS OR DAYS ON END AND THEN TRIPS. IT TAKE AWHILE AFTER THAT BEFORE I CAN RESET...
The reset button is part of the cord. The cord has built in arc detection. This is a complex circuit that monitors the unit and senses potentially dangerous sparks or arcing inside the internal components of the A/C (motors, switches, etc.) It sounds like the problem is getting worse - as they usually do. Sparking and arcing happen when dirt, corrosion, etc. accumulates and can result in pitted contacts. All of these conditions only make the sparks and arcs worse. Page 1 of the manual (left column) says this:
If the Arc Detection Device has tripped, the
reset button will pop up.
Follow these steps to reset the Arc Detection
Device:
1. Unplug unit from electrical outlet
2. Press the reset button
3. Plug the unit back into electrical outlet
4. Check to see if power has returned to the unit
Testing
You should test the Arc Detection Device
equipped power cord monthly, after every major
electrical storm, or if power to your Room Air
Conditioner has been interrupted.
Follow these steps to test the Arc Detection
Device:
4. Press test button. Unit should trip and reset
button will pop up.
5. Press reset button again for use
If above test fails, stop using the air
conditioner and contact customer service by
calling the following toll-free number:
1-800-332-6658 or email:
customerservice@fedders.com
I hope this helps & good luck!
Aug 30, 2011 | Heating & Cooling
Unit will start and run for 5 seconds, then will blow a circut breaker on 20A. circut. This is a model AD75USTO Serial # QU2660438 AKA Whirlpool gold energy star
Hopefully, it's not a problem inside the unit that's causing the circuit breaker to trip. Is there another electrical appliance plugged into the same outlet or on that circuit that is ON and draws 15 amps of power? If so, that's the problem. If that's not the case, turn the circuit breaker OFF and remove the outlet cover, so you can inspect the receptacle and it's wiring. A loose wiring connection or a broken or cracked receptacle could be the issue. If you don't find any damage reassemble the outlet and turn the circuit breaker back ON. Instead of plugging in the dehumidifier, plug in a lamp or something similar and turn it ON. Leave it on for more than 5 minutes to see if the circuit breaker trips again. If it does, you'll know the problem is either with the outlet receptacle or the circuit breaker. If doesn't, plug in the dehumidifier (Make sure the Master ON/OFF Switch on the unit is in the OFF position, before plugging it in. Then turn the Master ON/OFF Switch to ON and set your controls. If the circuit breaker trips again, the problem is in the dehumidifier. You will need to call Whirlpool Customer Care, as it's an internal electrical issue.
In case you have misplaced your Owners Manual, I have included a link to it, that you can download and print for future reference. http://www.kitchenaid.ca/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%201188927.pdf
I hope what information I have provided to you, will help you trouble shoot and solve the problem.
Apr 16, 2011 | Whirlpool 75-Pint Dehumidifier
My daughter's Kitchenaid Artisan 325 watt mixer had a malfunction last night. The unit itself is less than 3 years old. It had been running on high for approximately 5 minutes when sparks began to fly...
Sorry cant solve this but mine did the same. Mine is almost 4 years old now. Have you found out what the problem was with yours? Have you sent it back? Nicky.
Aug 02, 2010 | KitchenAid KSM150PS Artisan Series Stand...
Whynter 13000 sno no power
Could be a lot of things - but I'm wondering if when you are checking the 'fuse at the plug-in,' are you actually checking the outlet for voltage?
I would check the outlet for voltage; i.e. plug in a hair dryer or something to the outlet and see if it (hair dryer) comes on. If it doesn't then I would check your breakers and see if you have a breaker tripped. In homes - you can usually go to your breaker panel (usually in the garage or a store room, i.e. pantry, hot water closet, sometimes in hallways behind doors) and find the breaker panel.
On a small unit like yours it would probably be a 15 or 20 amp single throw (like a light switch) breaker. If it's 'tripped' it can be in a position that resembles half on and half off, or it can look completely 'off.'
Remember - if it's a 'tripped breaker' - just re-setting the breaker might not solve the problem. There is usually a reason for a breaker tripping - although they do on occasion 'trip' for no reason.
In any event - if it's a tripped breaker - i would reset it and then if it happened again, either within a few minutes/or an hour - or within a day or two - then I would suspect something wrong with the unit and I would need more information, or you might need a qualified technician to trouble shoot the unit.
Note: if the breaker is tripped and when you reset it - it immediately 'pops back off.' Leave it off and call a tech - because you have a direct short and it will have to be trouble shooted.
good luck!
May 02, 2010 | Whynter SNO 13000 BTU Portable Air...
Circuit breaker trips when turning unit on. only unit on circuit has triped on several circuits can find no shorts on wiring.
DOES IT BLOW THE BRAKER AS SOON AS IT TURNS ON OR DOES IT TAKE A FEW SECONDS. INSTANTLY WOULD MORE LIKELY BE A SHORT IF FEW SECONDS THE COMPRESSOR IS PROBABLY DRAWING MORE AMPS THAN THE BREAKER CAN HANDLE SO IT BLOWS. TRY TAPPING THE COMPRESSOR NEXT TIME YOU ATTEMPT A HOUSE CURRENT START UP. i HAVE A WINDOW AIR CONDITIONER THAT NEEDS TAPPED FOR STARTUP FOR THE SUMMER SEASON. GOOD LUCK
May 01, 2009 | Dometic RM2852 Refrigerator
Window unit trips circuit breaker
If your Plug is getting hot there is a voltage drop where the heat is generated. On these wall outlet recepticals there are two different methods of connecting the wires. First they strip the end of the wire and plug it into the back of the receptical . The second method is to strip the wire and attach it to a screw terminal . This is the best method for any outlet with a motor running from it.
For an example draw a straight line and then draw a circle that comes in contact with the line. Look and see how much contact area you have where the circle touches the line.
Jul 02, 2008 | GE AVX10AD Air Conditioner
Frigidaire FAC124 wall/Window Air Conditioner Logo
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
