Question about Apple iPhone Smartphone
Iphone does not ring on sleep mode
My iphone does not ring when I goes into sleep mode. I have to leave the lock setting on Never lock or I would not hear it ring and the call goes to voice mail. Also my bluetooth feature is not available. Can anyone help.
Thanks.
  • 5 more comments
  • jenbartlett Apr 08, 2008
    I have the same problem when my iphone locks and goes to sleep mode it does not ring and nothing happens on the screen. when i unlock the phone i have missed calls.  Cannot lock my phone otherwise i would not know i had a call coming in
  • Anonymous Apr 09, 2008
    the same problem. Iphone doesn´t works in sleep mode.
  • iker Apr 10, 2008
    My iphone does not ring, when it is in the sleep mode. During the first minute it awakes but after it it does not.
  • Anonymous Jun 09, 2008
    my phone have the same problem.
  • dommyem Dec 28, 2008
    i have the same problem but my bluetooth works ok. let me know if you find a fix, [email protected]
  • Anonymous Apr 08, 2009
    i have the same problem, sometimes my messages are delayed, how can i fix that?
  • shepherdadri
    shepherdadri Jun 17, 2012
    If you do not receive calls or msgs when your iphone is in sleep mode, i can fix this for you, i charge 30 USD for this, if you are in india then i charge rs 1000. the best part is that you do not need to send me your phone, i will fix it remotely. you can contact me on [email protected]
1. File manager in ipcsuite
/System/Library/SystemConfiguration/PowerManagement.bundle
2. Find the file:
com.apple.SystemPowerProfileDefaults.plist
Then rename it to:
com.apple.SystemPowerProfileDefaults.plist2
3. Reboot your phone
Posted on Aug 11, 2009
  • 1 more comment
  • Paul Sep 05, 2012
    it works for me. thx! however my battery is running out of juice much faster. does any one has similar issue? any clue how to fix this?
  • Babu Samnani
    Babu Samnani Jan 11, 2014
    its work 100000000000% thanx toooooooooooo
  • Babu Samnani
    Its work 100X100X100% thanxxxxxxxxxxxxxxxx.
If your phone is jailbroken, install insomnia app from cydia and it will fix the problem
    New Friend:
Make sure do not disturb is turned off, mine was on and when the phone was locked no calls would come thru at all.
Posted on Jan 15, 2013
Posted on Nov 28, 2008
You probably have a corrupt restore. It happened to me after I got a replacement phone.
I had to erase all contents to the phone (this took more than an hour: settings - general - reset - Erase all content and settings). While it was erasing, I removed the old backups from C:\Documents and Settings\<your_user_name>\Application Data\Apple Computer\MobileSync\Backup
After this I connected the phone to iTunes again, and the problem was gone.
However, all contact information and other notes etc was also gone. Make sure to synchronize condact data , calendars etc with the PC (e.g. outlook) before doing this.
Posted on Dec 03, 2008
Same problem was with my iphone was also, I have jailbreak my iphone using ziphone, after some time I found this problem in my phone, i have starded using without putting in sleep mode, although it drain out battery very fast almost within 8hrs it need recharge
one fine day i found that it is ringing in sleep mode also I just recollect what I did with my iphone,
Generally, I put my phone on sleep mode manully while re-charging, because during charging it rings even if it on sleep mode,
during that night I have recharged my phone from Power, not from laptop, secondly, when I unpluged Iphone it was pretty cold not hot as it was alway when I unpluged, I kept the phone in sleeping mode and it was receiving call even if remain in sleeping mode for than 2 hrs, during this not missed any call and battery lasted for more than 72 hour.
what I conclude
1. recharging from laptop is not efficiently charging that iphone
2. if iphone is hot it means charging is still going on , even if cell meter show full
3. putting phone into sleep mode manually (not dare to experiment with auto sleep mode
hope this will work for everyone, do let me so, that every iphone lover could have better use of there phone
Posted on Apr 21, 2009
    New Friend:
Solution 7install insomnia app from cydia and it will fix the problem
thank you very BIG!!! shooooo i was have the problem since 2 mount
Posted on Jun 03, 2010
    New Friend:
My iphone 3g does not ring when screen is lock
Posted on Oct 08, 2012
    New Friend:
Posted on Jun 17, 2012
I have the same problem. I tried the suggestion about reseting the networking, in airplane mode and out of airplane mode did not help me to solve the problem.
Posted on Apr 25, 2008
Found this on another site and it worked well for me -- solved the problem:
1.) Reset the phones network settings
2.) Reboot the phone
3.) Put the phone in airplane mode
4.) Reboot the phone
5.) Take the phone out of airplane mode
6.) reboot the phone.
To reboot the iphone hold down the sleep/wake button, and the home button at the same time for 6 seconds (until the apple logo appears).
Posted on Apr 09, 2008
    New Friend:
    Problem Solver:
  • 6 Answers
Solution 4 worked for me.
Posted on Feb 18, 2009
SOURCE:
My iphone 4 goes straight to voice mail on the first ring how can i change the setting
make sure you do not have the settings set to block mode, people often confuse block mode as being the setting that blocks other devices from piggy backing on their wifi. it actually blocks calls. check the top of the phone for the symbols or icons, if you see one that you dont' understand open settings. and make changes.
Aug 21, 2014 | Apple Iphone 4s I Phone 4 S Factory...
Iphone 5c will not ring in sleep mode
It could be a couple of issues, but I wanted to make sure of one first. Does this happen at specific times where you state "sleep mode", or anytime the screen is off? If you had a time set for Apples "Do Not Disturb" then you would need to change the time or disable it altogether. If this happens when a little moon icon is in the top near the clock then this is your issue. If this is not the case it could be the ringer switch, try moving it back and forth to ring and silent to test and also if you can replicate the issue while you are using it, plug in head phones to see if audio is working at all. Your issue could be something deeper within the phone if these items or not the case. It is always recommended to backup your iPhone and then do a full restore to see if it is a software issue. My work iPhone 4S has an issue while trying to ring and doesn't even play sounds when needed. In my case it is a hardware issue, but I am going to hold off for the iPhone 6. If it is a hardware issue then it could be covered by Apple's warranty if under one year. On any purchase I highly recommend Apple Care + to cover damage and up default warranty to two years. If you can supply any more details I would be glad to chime in on them.
Apr 03, 2014 | Apple iPhone Smartphone
How do you turn off sleep mode on iphone 3
What do you mean by that? You put the phone in sleep mode by pressing the power button on the top of the phone. To get it out of the sleep mode you can press the top button again or press the home key.
If you mean how can you stop the screen turning off after a a period of time, go to settings/general/auto-lock and change it to the desired setting.
Hope this helps
Sep 28, 2012 | Apple iPhone 3G
Iphone doesn't ring out on sleep mode
Download the Insomnia app through CYDIA. Phone must be jailbroken to install this.
Aug 06, 2009 | Apple iPhone Smartphone
Iphone does not ring when in sleep mode
This seemed to work for me;
I read this on another website, and it seemed to work for me.
Good Luck!!
Jul 27, 2009 | BoxWave Corporation Apple iPhone 2G...
Iphone not ringing in sleep mode
Take a back-up and restore it. That might work!!
Feb 07, 2009 | Apple Cell Phones
Phone won't ring in sleep mode
I had the same problem with my iPhone the only way I was able to fix it was to re-flashed the latest 2.2 firmware. Power phone off, power on by holding power and home at same time, hold power for ten seconds and then release still holding home key for another 30 seconds to put phone in DFU mode. Then plug into iTunes it will detect phone in recovery mode and allow you to re-image
Jan 08, 2009 | Apple iPhone 3G Black Smartphone
Iphone does not ring on sleep mode.
I fixed this issues on a friends iPhone.
Upgrade to version 1.1.4 - and you cannot restore your backup.
Apr 03, 2008 | Apple iPhone Smartphone
İPhone not ringing
you can actually move the button , on the top left hand side of your iphone, over the ringer volume, you will see a red or orange dot, this means the switch has you iphone in silent mode, I was stuck on this, until I found it is a actual switch, look at it closely, you can move it. So where you see the red dot, put your finger on it and move it the opposite way, and I do not mean press the button, I mean, flip the switch on it, then your phone will not be in silent mode anymore,,, this was very annoying, I hope it helps anyone that has the same problem.
cheers!
Nov 15, 2007 | Apple iPhone Smartphone
FA 501apple Iphone....
Being that this question is so old. I'm gonna answer it for those that may face this problem today.
For starters. The dimming of the screen.
The dimming happens under the control of the auto lock of the screen. When it dims that means it's gonna "sleep". However the phone is still 100% functional in Sleep mode.
To change this setting you want to go to Settings, then General, tap Auto Lock, and change it as you wish.
Now to making your caller id show up again.
Go to Settings, then Phone, then tap Show My Caller ID and make sure it's On.
Those are the methods to fixing that problem. If those have been done and the problem still persists, then there's something more wrong with the phone
Nov 11, 2007 | Apple iPhone Smartphone
Apple iPhone Smartphone Logo
10,718 people viewed this question
Top Apple Cell Phones Experts
Ekse
jacobcheatha
Level 1 Expert
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
