Question about D-Link 802.11g 108Mbs Cable/DSL Wireless QoS Router (NETWDLDI724U)
How do I block others from using my router without a password?D-link 802.11g\2.4GHz
    President:
  • 1,118 Answers
You can do MAC (ethernet) address filtering. You can set it to allow only specific MAC addresses to be granted access. For Windows PCs, you can get the MAC adress by firing a command prompt and typing 'ipconfig /all'. For WM, go to 'Start > Settings > System Information' (or something equivalent) select the network section and take note of the Wi-Fi card's MAC address. Anyway, with the MAC adresses of all the devices you want to grant access to your network in hand, navigate to its Web Utility (if it has not been changed before, the IP address is usually set to either 192.168.0.1, or 192.168.1.1, or 192.168.2.1). There, under the security section, you should find the MAC address filtering function.
Please, let me know if you need further details.
Regards, Carlos
Posted on May 28, 2010
I disabled the wireless connections how do i turn it back on
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Aug 29, 2012 | LG -Nortel Elo WR100T 108Mbps 802.11g...
How to blocked the wireless
You can change the wireless settings of the router and make it secured. So that no one will be able to connect to your wireless network without a password.
Do not share your wireless network password with anybody.
If you want you can also disable the wireless broadcasting at all.
For this you will need to access the settings page of the router and change the settings manually.
Connect the computer to the router with the Ethernet cable and open the setup page of the router using 192.168.1.1
Go to wireless tab and make it secured.
See Linksys router how to
Jan 05, 2012 | Linksys WRT54GR Wireless-G Broadband...
I have lost my password for D-Link DI-524 router? How can I reset the admin and user passwords without changing all other connection settings? Thanks.
fannyng
Unfortantly if you have forgotten the password to the router there is not any way to reset it with out resetting the router.
If you need help resetting the router let me know.
Issken
http://www.fixya.com/users/issken
Sep 01, 2010 | D-Link DI-524 4 Port Wireless-G Router -...
I tried to set up a password. no longer have access.
There is a small hole on the edge of the router, remove from power and use a paper clip etc and press this button for a bit. This will reset the router back to factory condition, the logon & password will now be reset to admin
Feb 09, 2010 | D-Link DIR-615 Wireless Router
How do I manage my network using a d link dir 655 wirless router, without buying network magic?
You can open a web-broswer such as Internet Explorer and enter the IP address of the router (http://192.168.0.1).
You may also connect using the NetBIOS name int the address bar (http://dlinkrouter).
Select Admin from the drop-down menu and then enter your password. Leave the password blank by default. Type in the graphical authentication code (if you cannot read it, click Regenerate).
You may click Setup Wizard to quickly configure your router.
If you want to enter your settings without running the wizard, click Manual Configuration.
In your rounter you can see who is connecting to your network and also block computers/devices from using your network.
Hope that helps.
Jan 15, 2010 | D-Link Xtreme N DIR-655 Wireless Router
I misplace the disc awhile back, and i want to put a password to block others form useing it. Is there another way to do this without the disc?
You need to log in to your router (http://192.168.1.1) and go to the Wireless section. You can set a secure SSID (Network Name) and also, and in the Security section you can set up further Security with any of several methods. All let you set a passcode to limit access to only those that know the passcode.
Nov 18, 2009 | D-Link DIR-625 (790069292637) Wireless...
I forgot my passowrd to my linksys wireless-G broadband router because I block it from being used without a password and I need help retrieving the password
I'm not sure anyone has any kind of password cracker yet for those routers, but if you don't mind losing all the settings on the router, routers can be usually be reset by pressing a button somewhere on it. You probably have to hold it down for a certain amount of time. (sometimes you have to power it on or off with the button pressed) I'd search for your router's model number on the internet to see if anyone has any other solutions.
Dec 02, 2008 | Linksys Wireless-G Broadband Router
Problem with D-Link wireless router!
try to reset your D-link router (press the reset button of at least 1min) reseting router will restore the manufacturer default router settings.
Note: Save or write any changes you made in your router if you customize it other than using the default settings.
Nov 24, 2008 | D-Link DIR-625 (790069292637) Wireless...
D-link wireless internet
It is always a good thing to start the different peripherals in an order. First, you start your modem. Wait 30 seconds. Then, start the router; wait another 30 seconds; then the computer.
Aug 24, 2008 | D-Link Wireless Cable/DSL 802.11G Router...
D-Link 802.11g 108Mbs Cable/DSL Wireless QoS Router (NETWDLDI724U) Logo
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
