Question about Whirlpool MH1141XM Microwave Oven
When attempting to cook, microwave lights up and the fan runs; however, there is no heat and the turn table is not moving. The sound with softer than normal as well
  • Whirlpool Master
  • 9,047 Answers
It's probably a bad door switch. See this file for tips and to order a switch.
You didn't mention your brand and model numbers, but you can find links to helpful exploded view diagrams and part ordering help for most brands here.
I recommend that you bookmark that link to your favorites.
We're happy to help you with free advice and we'd appreciate your
thoughtful rating of our answer.
Posted on May 28, 2010
Problem with KHMS1850S Stainless Steel 1000 Watts Microwave Oven
Possible that the Magnetron is powered off or is defective. You can check the main capacitor to the HT, check the leads, check the main board.
Also check the sensor which is mounted on the top or side of the cabin which is protector for overheat and can cut the voltage for safety.
If so also check the wave guides
Click on: Waveguides
Jan 30, 2013 | Microwave Ovens
Turn table does not turn when heating. Interior light does not come on during cooking, works fine when door is opens.
some microwave is have PCB control if pcs is shorted some parts light bult,fan or syncronus motor is on mode we need to replace the pcb but some problem is only is micro switch,if mocro swict is rusty or corroded that the time not working the turn table,but you said every time open the door the ligth is ok,if the turn table also running during open door have problem in your pcb board that we need for replacement,but check the price of parts and make it desicion if you want to repair or buy a new one if your unit is very old.
Dec 28, 2010 | Microwave Ovens
Samsung microwave -the electrical panel runs, the
it sounds like it one of your micro-switches inside that control the power to the doors, if one of the switches is bad, it would cut the power , the panenl will light, the turn table will work, the fan will turn on , but you will not get any heat at all, micro-switches run depending onthe unit from 5-10 bucks, when you open the unit you will see the one that is bad, is usually bent or the connector might be burn or melt, good luck..!
Nov 14, 2009 | Samsung MU3250W Microwave Oven
Microwave seems to run, but won't heat.
We have a similar problem! It sounds like a problem with the microswitch inside the unit that the door is suppose to engage when closed. If not engaged properly, it will not cook. We had the switch replaced last March but it has started acting up again. We can press in on the door and/or lift it slightly and it will cook. Try putting time on the counter and hit start. It the word "cook" appears then try moving the door slightly and see if the turntable starts turning. If not, then you may have a more serious problem. Good luck!
Oct 09, 2009 | Frigidaire FMV156DC Microwave Oven
Galaxy microwave works does not heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
uee
Nov 09, 2008 | LG MV-1444Y Microwave Oven
MICROWAVE NOT WORKING PROPERLY
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
Let us know if the hard reset does not fix it.
Otherwise, it sounds like a bad door switch or door switch mount.
Aug 20, 2008 | Daewoo Microwave Ovens
Microwave turns on, but no heat or turntable movement
The problem is that the magnatron is not getting power. Chance is that if could be a bolwn fuse inside the unit. If the fuse don't fix it then that leaves the charging diode, capacitor or the magnatron, or high voltage xformer of which without technical epertize I would not recomend attempting to replace. good luck
May 14, 2008 | Hotpoint RVM1635 Microwave Oven
Microwave does not heat.
The magnetron is the device that puts out the heat. In these units, that's the most common cause of a failure to heat. BUT - many of these units are subject to a campaign under which GE will replace the magnetron, stirrer and high voltage diode free. Check the bulletin to see if yours is covered: http://www.microwavedisplay.com/ge_mw_mag_kit_bulletin.jpg Even if yours is not covered by the bulletin, it may have coverage of the magnetron. If you have questions, call GE Customer Relations at 1-800-386-1215 (8-6 ET)
May 03, 2007 | GE JVM1850 1000 Watts Microwave Oven
Microwave Buzzing, Still Heats, but Turntable And Fan Not Working
This is not safe. If the fan is not running, the magnetron will quickly overheat and be destroyed. We answered this in more depth in the other place you asked it.
Feb 24, 2007 | GE JVM1441 Microwave Oven
Whirlpool MH1141XM Microwave Oven Logo
51 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jaime Hernandez
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
